Is my Viper 591xv alarm stupid?
Old Mar 10, 2012 | 08:34 AM
00 Max's Avatar
With this and most alarm systems the doors when the ignition is engaged. When I unlock the doors with the car running to let passengers in or out I need to manually relock the doors or I am now riding around with the doors unlocked. That makes total sense from a security system. When I pull my car out of the garage spot to let my gf in it annoys me to always remember to lock the doors. Most of the systems I had in the past re locked the doors after the door closed or once the car hit around 10mph. Dei is a zillion $ company, I can't imagine there is not a hopefully easy fix for this. Thank you. Brian.
Old Mar 11, 2012 | 08:48 AM
installer's Avatar
hi im a proffesional install all DEI system do ingnition controlled locks when you start the car they will lock and when you shut it off the will unlock they dont have any programming to make the car lock at a certain speed thats a setting on some cars from the dealer but i dont think they did it in 2000.
Old Mar 11, 2012 | 07:32 PM
00 Max's Avatar
I agree the speed sencing locking is an oem option. It was on my 98 Mark VIII, a different kind of car. The keyless entry system side of the unit should sence the ignition is on & relock the door after it is unlocked, opened & reclosed. I sold original style Clifford (the best) & Dei security products 10 years ago. Even an old cheap Omega unit I had did it. This just doesn't make sense.
Old Mar 12, 2012 | 10:48 AM
installer's Avatar
yea i agree but they changed the systems over time cause people were getting out closing the door to run insaide and the car would lock itself causing an issue so they dont do it anymore only done by dealer speed sense
Old Mar 13, 2012 | 08:40 PM
00 Max's Avatar
You are prob right. Is Ford the only one that has it & is it a seperate module or built in the bcm?
Old Mar 14, 2012 | 05:48 AM
installer's Avatar
no about 75% of manufacturfers do it now
Old Apr 16, 2012 | 07:28 PM
00 Max's Avatar
I was in a new Honda on vaca & what a difference. I wish this was an easy fix???
kmitchel
Oct 28, 2015 09:46 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
pears
Sep 18, 2015 05:25 AM
A32goldylocks
Sep 16, 2015 01:33 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
