Punch 600a.4
Old Feb 7, 2002 | 09:58 AM
RICOiz704's Avatar
Punch 600a.4
I was wondering if anyone is familiar with that model..Im tryin to power two subs with it even tho it's a four channel.....any special ways to make it happen even if it could happen. Also im goin with one 12soon...Maybe the new DVC KICKER...and i was told since it was dual voice coil that I could use the Punch600a4 as well.
Any advice would be apperciated...and for the record it's gonna be pushing 2 10" pioneer premiers
Old Feb 7, 2002 | 04:54 PM
Micah95GLE's Avatar
To get maximum power from the amp, you need to use either one 4-ohm sub or two 8-ohm subs (if you are using only two channels for subbage). Anything else will be half power or will drive the amp at an unstable load.
Old Feb 8, 2002 | 05:50 AM
RICOiz704's Avatar
Ok so in idiot terms what does that mean...(sorry not super audio fluent) yes or no to the DVC Kicker...or yes or no to the pioneer premiers have in there now? Im just curious
Old Feb 8, 2002 | 04:14 PM
Micah95GLE's Avatar
Are you gonna use all 4 channels for the subs, or only the second channel pair (and use the first channel pair for the front stage)?
Old Feb 9, 2002 | 08:06 AM
Yellowbrother's Avatar
if i recall correctly...2 ohm stable at stereo...meaning using the amp as four channel....4 ohm stable bridged...meaning using the amp as two channel....if u get two 12's dvc...try to get one that is 2 ohms per coil...that way u have 4 two ohm coils and u can use all four channels...get the full potential power of the amp...correct if i'm wrong yo...
Old Feb 10, 2002 | 10:17 PM
CanuckAMP's Avatar
Correct....
Anyhow to answer his question, no he shouldn't get a pair of DVC Kickers to drive with that amplifier....
Old Feb 11, 2002 | 05:46 AM
RICOiz704's Avatar
O.K fellas...I was only gonna get ONE 12" Kicker DVC to replace the two tens and run off the punch 600a.4 is that still a waste of time?.....and Im only using this amp to push the subs....I have a different amp to run to the interiors...
Thanks in advance....
Old Feb 11, 2002 | 05:48 AM
in that case...get 4 ohms per coil....then bridge the amp into two channels...
Old Feb 11, 2002 | 05:53 AM
RICOiz704's Avatar
Can I get 4ohms per coil in one 12" speaker? Cause I got the amp for a favor and want to use it to it's fullest potential if it's possible to push decently...but I also want to cut down from two 10's to just one 12"..any suggestions...
Old Feb 11, 2002 | 06:01 AM
yes...make sure it is 4 ohms per coil tho...alot of writing on the manufacturers book can be confusing...
since the amp's full power is at 2 ohm stable and u only want to use 1 12's then u are only using 1/2 of it's potential...but neva fear...even at that u'll still sound good/good enough....
it can be done...
Old Feb 11, 2002 | 06:15 AM
RICOiz704's Avatar
Thanks eveyone...and Yellowbrother..coming from ya DarkerBrother
Old Feb 11, 2002 | 09:55 AM
CanuckAMP's Avatar
It won't be half his potential with one sub. When he bridges the 4 channel amp down to 2 channels the amp will still be performing at maximum power. Just be sure to match the gains on each amp section exactly or one coil will get more power than the other.
Old Feb 11, 2002 | 09:58 AM
RICOiz704's Avatar
So what saying Canuck what would be the best way to rum the amp..to what sub set-up?
Old Feb 11, 2002 | 10:04 AM
CanuckAMP's Avatar
Bridge the amp to 2 mono channels an then wire each bridged amp section to a separate coil on your DVC sub...unless you're planning on something else.
If you don't have a amp for your front speakers you could use the amp to drive a set of speakers and then bridge channels 3/4 for driving a SVC 4 Ohm sub.
Old Feb 11, 2002 | 10:46 AM
RICOiz704's Avatar
SO which would be better two more 10inch subs or 1 12inch sub (audio retarded forgive me) and if I was to go one 12inch with this particular amp..which one would u recommend?
Old Feb 11, 2002 | 11:03 AM
CanuckAMP's Avatar
A pair of 10's would have more cone area than a single 12" sub though 12's tend to have reproduce lower frequencies better than 10's. If you want more bass output cenntered around 80-120 Hz then I'd say go for the 2 10's. If you want lower bass response then go for the single 12. Then again this is a blanket statement and one thing to remember about car audio is there are no absolutes. There are some 10's that have lower bass response than some 12's. And if you get a single 12 that has a high linear travel (Xmax) it could actually deliver more bass than a pair of 10's that would have a lower Xmax.
That's what makes all the nerve racking, head scratching shopping all teh more fun...
Old Feb 11, 2002 | 11:13 AM
RICOiz704's Avatar
So which single 12 would u recommend..im tryin to avoid keepin the two Pioneer premiers....
Old Feb 11, 2002 | 11:17 AM
CanuckAMP's Avatar
What's your budget?
Old Feb 11, 2002 | 12:02 PM
RICOiz704's Avatar
for one 12 maybe 200-300 w/box
Old Feb 11, 2002 | 02:52 PM
um...guess my previous reply didn't come out rite...what i meant by half it's potential...i meant power compared to it's 2 ohm load...but by getting a single 12 with dvc and each coil is 4 ohm...with each coil wired to each bridged channel he would actually be using the full "stable" potential power of 4 ohm load...
Old Feb 11, 2002 | 03:25 PM
CanuckAMP's Avatar
I see you're referring to the amp being bridged into 2 Ohm loads? I wouldn't recommend that.
Old Feb 11, 2002 | 03:27 PM
CanuckAMP's Avatar
Is your goal sound quality or SPL?
Old Feb 11, 2002 | 04:21 PM
no that's not wat i meant....but nevamind tho...
Old Feb 12, 2002 | 05:48 AM
RICOiz704's Avatar
SQL
Old Feb 12, 2002 | 12:21 PM
CanuckAMP's Avatar
SQL
Then I'd highly recommend you look into the DEI CompX 12", Adire Audio Brahma, Image Dynamics IDMAX 12, Blueprint Driver 1203 and Audiomobile MASS.
Old Feb 20, 2002 | 03:27 PM
SuDZ's Avatar
Good bye ricoiz704.
SuDZ
Old Feb 22, 2002 | 04:59 PM
gtr_rider's Avatar
192.168.1.1
JRod28
Dec 29, 2023 09:56 PM
SCCA Solo2
Jan 22, 2001 01:04 PM
KnowledgeBorn
Jan 12, 2001 10:00 PM
SCCA Solo2
Nov 18, 2000 05:29 AM
AntGVR4
Oct 16, 2000 03:50 PM
