Owners of Pioneer P-930 Head Unit
Old May 1, 2002 | 03:38 AM
RalphW's Avatar
Hey all,
My display alternates between black background/green numbers/display then goes to green background and black numbers/display. Is this normal? I don't like it changing all the time. Do you know how to stop it from doing this?
RalphW
Old May 1, 2002 | 12:14 PM
D_Warbucks's Avatar
Re: Owners of Pioneer P-930 Head Unit
Originally posted by RalphW
Hey all,
RalphW
If its what I think it is, the deck is in demo mode. I had a Pioneer 8000, the grandfather of the 930 and it had the same thing. On mine all you had to do was hold down the 5 or the 6 key(radio preset keys) for a few seconds and a beep would confrim. One of those cut the clock display on and the other toggled the demo on and off. See if this does the trick, if not get back to me and Ill do some research on it.
Warbucks
Old May 1, 2002 | 01:12 PM
climaxima's Avatar
sounds like demo mode to me.
go here and register and download the manual from them directly and you should find out how to take it out of demo mode.
here
Old May 1, 2002 | 07:59 PM
ny96max's Avatar
Its definitly not demo mode!! mine does the same thing, its just the way Pioneer designed their newer screens. But I hope there is a way to stop it from goin black-->green all the time. It gets kinda annoying. Ill call my rep and see what he says
Ant
Old May 1, 2002 | 08:13 PM
Punch84's Avatar
My friend has a 9300 and his doesnt do that, but he's in a Pathfinder. I have a 9200 and I had a similar problem. On mine there's this tiny button in the lower right corner that only a pen tip or something small like that can fit in. It's the reset button I think, but that solved my problem.
Old May 2, 2002 | 07:38 AM
D_Warbucks's Avatar
Ant
Im about 90% sure that it is the demo mode. I was thinking the same thing when I saw it on my HU...why would Pioneer make it flash like that from green to black? I called Pioneer tech and they said its a demo mode that is designed to be used in stores where the deck is on all day everyday...helps protect the screen. Same concept as a screensaver on a PC. Look in your owner's manual or contact Pioneer for exact instructions on how to toggle the demo on and off.
Warbucks
Old May 2, 2002 | 10:55 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Demo mode, it can be shut if by hittin the #5 button when you first turn on your radio. #5? I think #5.
Old May 7, 2002 | 10:24 PM
RalphW's Avatar
Did you talk to your rep? What did he say?
RalphW
Ant
Old May 8, 2002 | 05:45 PM
PATRICK94SE's Avatar
On my P7200 I just had to press the #5 button with the HU off but with the car on
Old May 8, 2002 | 06:44 PM
AndyXXL's Avatar
Yep. I had Pioneer 9200 and it did that every few seconds, ****ed me off. My friends were curious if the display changed its color in relation to speed.
Then finally I found that small button and it was over.
Old May 8, 2002 | 07:09 PM
Carl2k2SE's Avatar
I've got the DEH-P9300 and I was irritated with it when I first got it. I read the manual cover to cover several times trying to figure out how to change it and was ready to send the radio back. I called Pioneer and asked to speak to the tech department. The tech guy was really nice and said he gets 2 or 3 calls a day on this. He admitted the manual didn't do a very good job of explaining this and the radio is factory set in "reverse (demo) mode". To cancel it, make sure the ignition is on and the radio is off, then press button 5.
Mar 12, 2020 12:06 AM
Forge277
Jun 13, 2016 09:26 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
ivorton23
Sep 28, 2015 09:08 PM
