Need seatbelt recommendations
I am currently using the stock seat belt with a belt clip made for child car seats; I think it's called a "Buckle Buddy". It works pretty well, but I still slide around quite a bit.
I seem to remember a discussion here a few years ago about racing style (maybe 4-point) harness that could be used in the Maxima without needing a roll bar for attachment points. Does anyone have any info on these or, more importantly, used one of these?
Re: Need seatbelt recommendations
I do not move with these harnesses and they were definitely worth the investment. I bought them at HMS Motorsports, who is one of the primary importers into the country for Schroth belts.
http://www.hmsmotorsport.com/newstore.php?m=12&sub=382
Thanks, that is what I am looking for. I appears that you can quickly remove the entire upper portion; the strap that goes to the rear and the upper part of the shoulder straps. Do you detach that section and just use the stock seat belts for everyday driving? If so, do the remaining parts of the racing harness get in your way or cause any discomfort?
Originally posted by Driven EF9
just remember to never use a racing harness unless you have a roll-bar, or some sort of roll-over protection...
Even though autocrossing is a low speed motorsport, i'd still avoid using it...
If you roll the car without a rollbar to protect you, your head will take all the impact because you are strapped in upright. With regular seatbelts, you can move to the side to avoid that. That's the primary reason.
Originally posted by iwannabmw
Yeah, why? Do you have any idea how many cars I've seen driven on tracks without a rollbar. The harness bolts into the same stock points as the regular belts, it just distributes the loads more evenly.
How is a roll bar going to make a differance. Your head will still hiy the roof?
without a rollbar: roof collapses head smashed. If you have regular belts you also have the ability to move to the side to avoid the roof coming in on you. If you are harnessed in, you can't move to the side.
with rollbar: car rolls but the point of the rollbar is to keep roof from collapsing - so as long as your head is below the level of the roll bar you should be OK whether you are harnessed in or not.
I also have the Schroth R3. Once disconnected the whole thing hides away great. The rear pieces can be slid between the rear seat cushions. The fronts can be slid under the drivers seat from the rear. Unless you look under the drivers seat you'd never know it's installed. I NEVER use mine for daily driving as you can't reach anywhere else in the car ie. glovebox, rearseat, etc. or hardly look over your shoulder.
DrivenEF9 has a point about rollovers. So just don't roll the car
Actually, the Schroth releases so fast you could probably unfasten it enough to slide down if needed. I never want to find out though.
This really is a huge Pandora's box, but sice someone has munched their car at nearly every track event I've attended, I would be inclined to err on the side of caution.
If you value your head, use the harness with a roll bar.
And to the guy who said he could undo it fast enough -- no way. If you have ever driven on a track and spun (forget about a real crash for a moment), there's no way you are going to have the wherewithal to get your harness undone. Sorry, it's just a completely unrealistic scenario.
And as far as the "I'm not going to roll my car" attitude goes, that's something you don't really have control over. I guarantee you none of the guys at the track events I've been to who rolled their cars planned on it that morning. By virture of the fact that you are on a track, or even an autocross, you run the risk of roll-over.
I was about to get one as well as I slide around too much. but every racer I know said NOT to get one unless I have a rollbar. You're better off getting a better seat.
It's not just your head you have to worry about, but your spine as well.
If you rollover and the roof crushees down to the level of the door and you are starpped in your eat with no room for movement, you are a DEAD MAN, or worse a QUADRIPLEGIC plain and simple.
No way in hell are you going to be able to release it on time, think about what happens in a rollover specially a highspeed one.
But hey it's your life do what you want.
Look at this thread I start asking the same question a whle ago, look at the bottom picture of the BMW. Imagine youself strapped to your seat and not being able to move.
MaxLvr21
10-17-2015 12:11 PM
DC_Juggernaut
09-28-2015 04:07 PM
sdotcarter
09-02-2015 09:53 PM
