Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
So whats the most HP anyone is puttin out on a N/A 3.5 ?
Old Sep 24, 2007 | 01:48 PM
  #121
One Crazy Max's Avatar
none, but i think he is cammed tho.
Old Sep 24, 2007 | 02:04 PM
  #122
Kevlo911's Avatar
Kevlo for President
Any graphs?
Old Sep 24, 2007 | 03:30 PM
  #123
nismology's Avatar
That's an internal modification. Which ones? Head work?
Old Sep 24, 2007 | 08:47 PM
  #124
i will have to get some info from him.
Old Oct 30, 2007 | 09:05 AM
  #125
Gooey's Avatar
I put out 279hp and 241tq with just an intake and exhaust heres my dyno graph. Runnin very rich for the first 5k rpms
Old Oct 30, 2007 | 09:08 AM
  #126
NmexMAX's Avatar
dot dot dot ...
I don't see an AFR curve? What were the SAE #'s? Got DRF's?
Old Oct 30, 2007 | 09:37 AM
  #127
Gooey's Avatar
those are corrected numbers and what is DRF? I dont have a copy of my a/f ratio but it was spiking towards 14.5-15.0 the first 5k rpms
Old Oct 30, 2007 | 09:40 AM
  #128
pmohr's Avatar
No more Maximas...
DRF == Dyno Run File.
I thought you said it was running rich? 14.5-15 at WOT is extremely lean.
Old Oct 30, 2007 | 09:41 AM
  #129
NmexMAX's Avatar
dot dot dot ...
DRF = Dyno Run File, since it's obvious it's a DJ.
I doubt your true AFR was that lean. Grab some OBDII software and log your stock WB's, or, the next time you dyno, get an upstream WB put in and be able to definitively say what the AFR is/was.
CAt convertors affect the AFR curve (lean)
Old Oct 30, 2007 | 03:33 PM
  #130
03BlkSETE's Avatar
Nice numbers for a 350Z.
Old Oct 30, 2007 | 04:01 PM
  #131
DasYears
vq35hr FTW
Old Oct 30, 2007 | 04:39 PM
  #132
redls1's Avatar
MAXIN' ON
Isnt there several NA 350z over 300hp ?
Old Oct 30, 2007 | 05:04 PM
  #133
DasYears
there are a few, i wouldnt say several
Old Oct 30, 2007 | 07:33 PM
  #134
NmexMAX's Avatar
dot dot dot ...
And to clarify, 300 whp.
Old Oct 30, 2007 | 07:59 PM
  #135
Gooey's Avatar
oh sorry i meant its running very lean. not rich. Yeah Im running no cats right now. maybe thats why??? I dont know but theres really nothing I can do right now. I just have to wait fora piggyback or standalone to fix that. Tried a safc but ecu juist resets on its own.
Old Oct 30, 2007 | 09:00 PM
  #136
nismology's Avatar
Did you intercept both MAF signals when you installed it?
Old Oct 30, 2007 | 09:08 PM
  #137
NmexMAX's Avatar
dot dot dot ...
And if so, did you use the correct split signal setting?
Old Oct 31, 2007 | 04:57 AM
  #138
Gooey's Avatar
they only plugged in 1 i believe
Old Oct 31, 2007 | 06:13 AM
  #139
redls1's Avatar
MAXIN' ON
Yes sorry , a few not many!!
Old Oct 31, 2007 | 06:31 AM
  #140
NmexMAX's Avatar
dot dot dot ...
Sounds like they could have done it better.
SAFCII has the ability to split the MAF signal for 2 MAF's in for scenarios, (a la R34/Z32TT).
IBRTFM
Old Oct 31, 2007 | 07:40 AM
  #141
Gooey's Avatar
we tried the safc but it does not work with the Z. the stock ecu overrides all the safc commands within 10min
Old Oct 31, 2007 | 12:18 PM
  #142
DasYears
thats why you only use it for WOT corrections if you have to...i must be missing something
Old Oct 31, 2007 | 08:39 PM
  #143
Gooey's Avatar
the safc does not work for the 350z. Nor do those other air fuel gadjets. The only piggyback system out that works for the Z is a utec, osiris, andi believe accessport
Old Oct 31, 2007 | 08:54 PM
  #144
NmexMAX's Avatar
dot dot dot ...
I read that it even overrides the UTEC after a while, noticed on 03-06 Z33's. With that said, the tuning market for the HR is very limited at the moment.
I still haven't seen definitive proof that the SAFC or any other AFC doesn't work, i.e. WOT AFR logs comparing the same corr% performed on different dates to see if there is a change back to 'stock'.
Old Oct 31, 2007 | 09:43 PM
  #145
Gooey's Avatar
We tried hookin up a safc to my car. It couldnt do anything.
Old Nov 1, 2007 | 07:15 AM
  #146
NmexMAX's Avatar
dot dot dot ...
Your posts are a little vague, got any detailed technical information relative to the subject?
If so, PM me, since I don't want to clutter this thread more than it already is.
Old Nov 9, 2007 | 07:29 PM
  #147
NiSmOVQ35's Avatar
SleeperI35 put out 301WHP on his Vq35.
Old Nov 9, 2007 | 08:09 PM
  #148
nismology's Avatar
Any proof? Mod list?
Old Nov 9, 2007 | 10:07 PM
  #149
liqidvenom's Avatar
brotherhood of tq
was this in a I35 or some other vq35 car?
if so then i'm shocked. i could see 301 chp but 301whp is a serious car that must have gone unnoticed
Old Nov 10, 2007 | 06:51 AM
  #150
NiSmOVQ35's Avatar
It was a I35.. AUTO... fully built with cams and all.. i believe he was running JWT cams. Ill ask him this weekend.
Old Nov 11, 2007 | 08:44 AM
  #151
98MaXeDouT's Avatar
Yeah he had a 100mm over bore....custom phenolic spacers....cams blah blah blah
and yes it was a sick setup
Old Nov 11, 2007 | 10:31 AM
  #152
NmexMAX's Avatar
dot dot dot ...
100mm overbore? Jesus.
Old Nov 11, 2007 | 05:21 PM
  #153
NiSmOVQ35's Avatar
98maxedout..shutup... you know nothing about "sick" setups with your stock 3.0 with a intake and junk yard exhaust.
Old Nov 12, 2007 | 10:37 AM
  #154
95BLKMAX's Avatar
excuse me? So if I owned a beater Max bone stock are you gonna tell me that I dont know anything about building and tuning motors?
Old Nov 12, 2007 | 10:58 AM
  #155
pmohr's Avatar
No more Maximas...
You do realize that 98maxedout is 3.5 swapped, right?
So either NiSmOVQ35 is joking around, or he is an idiot.
Old Nov 12, 2007 | 11:04 AM
  #156
NmexMAX's Avatar
dot dot dot ...
Sounds like they're flirting.
Old Nov 12, 2007 | 11:11 AM
  #157
nismology's Avatar
I'm assuming the block was sleeved? If not, that engine was on borrowed time. It just seems strange that someone would spend money on overbore pistons and rock JWT cams.
Are details too much to ask for? It's like pulling teeth for some of you guys.
Old Nov 12, 2007 | 11:12 AM
  #158
95BLKMAX's Avatar
Well having a 3.5 swap means your handy and you know what you're doing with the Maximas, lol. Doesnt NECESSARILY mean you know how to take a motor (be it a VQ, a BMW M52, or a 350 small block) apart and building it back up from scratch- I say that since most people just drop the motor in and hope everything runs how it should, lol. Not to put down the swappers (myself included), but really once you look back, the swap is pretty easy if you do the prep work and know how to follow instructions, lol (at least this is my opinion).
Yea I hope its an inside joke of sorts . Because mods on your car=knowledge of your car just doesnt quite compute.... "Error 404"
Old Nov 12, 2007 | 01:30 PM
  #159
liqidvenom's Avatar
brotherhood of tq
nyc guys are fond of the whole hush hush manner of outting together cars and bragging about it but not how or what they did to get there.
the weekend battle forum is full of it
Old Nov 13, 2007 | 10:46 AM
  #160
98MaXeDouT's Avatar
Far from the truth. Some people live in areas where stolen cars are rampant...I myself have gotten things stolen immediately after posting them on the forums. So it's more of a preventive measure. By all means feel free to do it through PM's. I have gotten a ton of knowledge on my build through pms, for fear that people will come looking if I reveal the details of my setup.
So just because we don't make a thread with pictures detailing everything we have...doesn't mean we don't have it. I have offered a ****load of information in the other threads, some things that people have never done.
Yes NismoVQ35 is jokin....he's my boy.
Nismology...I would love to give you some more details, I'd have to ask the owner, as I don't know exacts...if your interested shoot me a pm and I'll see if I can call him.
