how often do you change your mobil 1?
Is there any process for changing over from refined oil to synthetic? since blends are available anyway I guess there is no problem swapping back and forth with each change. Couple more questions:
-After how many miles did you shift to synthetic?
-What brand and viscousity are you using?
-How often do you change your synthetic?
I went synthetic @ 35kvmiles. if your car is still new, break in the engine with refined oil (castrol GTX is highly recommended) then switch to synthetic after 10k.
5w30 mobil 1 supersyn...it depends on the environment of where you live.
every 4000 miles. I did an oil report @ 3000 miles drain period, the TBN was 12. blackstone recommended to extend the drain period.
Re: how often do you change your mobil 1?
2. 58,000
3. Mobil 1 5w/30
4. Usually 4k-5k. Last oil change was about 7500. Oops.
http://forums.maxima.org/showthread....hreadid=227996
Originally posted by buzek
Good Question! I would also like some replys on oil consumption, how much over how many miles do you guys experience? I seem to use alittle more than a quart every 3000 or so. I also use Mobil 1.
There are tons of opinions on when to changeover..consensus is no sooner than 10K miles or so. I switched over to Amsoil at less than 5k miles and now have 56K total on Amsoil and lately Mobil 1 5 or 10W 30. I have used STP 6941 oversized filter and 5000 mile oil changes since the first switch to synthetic. No problems, no noises, no oil usage, 23mpg average per tank (70/30 city/highway mix).
Originally posted by billy_corgan
I just changed my oil with Mobil 1 5W-30 and to my surprise only 2.25 old qil was drained. I consumed about 2 quarts of oil! I have a 99 SE with 44,000 miles. should I be concerned or should I not be using synthetic yet?
I am switching to Mobil1 SuperSyn at the next oil change. My objective is to have longer oil change interval and I specifically chose Mobil1 for the 10k mile interval. How long have you been using Mobil1 and how often do you change your oil filter and what brand did you use? Have you noticed any drawbacks from going this long between changing the oil? What did the oil look like after 10k? Any feedbacks are greatly appreciated.
Originally Posted by maxfanfromohio
I use Mobil 1 and change my oil every 10,000 miles. I drive about 90 miles per day to and from work all highway miles.
I've got two maximas, so...
2000:
59k switched over (73k on it now)
5w-30 mobil 1 super syn
every 5000-6000 miles with the OEM filter
97
77k switched over (85k on it now) (both cars I bought used)
5w-30 mobil 1 syper syn
every 7500 miles with OEM filter, no replacing of filter mid-interval
In fact, I am going to be doing the 7500 interval on both cars going forward, and not replacing the filter mid-interval. This is the "schedule 2", according to the manual of both cars. My driving fits schedule 2 characteristics, and since S2 is speced out for an OEM filter with conventional oil (The manual makes no allowance for synthetics), my using the OEM filter with a synthetic should be more than adequate. I was thinking of doing the 10k drain with a filter change at 5k, but the overall price is simlar, and I just can't be bothered to **** around that much.
I go through a quart every 3-5k miles on my 00 max, and less than that on the 97. When I changed the 97's oil recently at 7300 miles it was still fairly nicely colored on the dipstick. The 00 seems to darken its oil a bit quicker.
I have service records for the 97 and its oil was changed every 3k since its inception with conventional oil. I bought the 00 max at 37k and did the 3k change with a syn blend (wasn't going to run mobil 1 through it at that price, and I needed frequent changes for warranty reasons). I've no idea of the 00's history.
2000:
97
I use M-1 5W-30 and change every 5000 miles. Blackstone said I could go 6000 miles so I did this past oil change. Will post the report soon.
Changing every 3000 or 4000 miles with synthetic is a waste.
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
ag90fox
09-09-2015 12:22 PM
