Change My Oil and Oil Filter
Well I should wrap this up before I start to ramble.
I Changed My oil yesterday and the Oil Filter... I Installed a K&N Performance Gold Oil Filter. And now my car starts A lot better then before. Have anyone else experience the same Feeling or I just think that it is starting better????
http://www.knfilters.com/oilfilter.htm
what kinda oil did u use? I just recently started doing on own oil and i switched from regular to synthetic for the first time. WOW! what a difference car seems to have a lot more power and runs smooth as a motha!
I used mobil 1 5W-30 with a FRAM TP-7317 filter.
Oh yeah i was wondering if the mobil 1 filters are any better then FRAM or BOSH? is there a comparasion anywhere?
I use 10w-30 Mobile One synthetic Oil, It is Summer time and the weather is wormer then winter. In winter time I go back to 5W-30.
I find that the NAPA Silver oil filters are a good replacement because they have the diaphragm that holds a small amount of oil in them so that the engine oil system gets a "head start" when starting the engine. I use this combined with Valvoline Dura-Blend 10W-40 oil.
Check this link for all the specs of K&N:
Originally posted by Virus
The Mobil 1 and K&N filters are both made by Champion labs and both are almost identical inside. It doesn't matter which Fram filter you buy, they are all the worst filters on the market. Their expensive filters have the same filtering media as the cheap ones. The only difference is the outer casing which eludes you to believe your getting a superior filter. Keep reading here and you will find all the info you need.
You might be expert in Oil filters. but most Turbo cars that do 10-6 sec in 1/4 mile use the K&N oil filter. I don't have turbo in my car. When I went to English town, in June I spoke to couple of PRo racing team and they all said Use K&N oil filter even for regular driving they are really good. I don't know you might be right about the oil filters... but I kind of go with the Pro racing Team, which running a 7 sec car.
97_GXE
20
09-17-2015 08:12 PM
ag90fox
09-09-2015 12:22 PM
sdotcarter
09-02-2015 09:53 PM
