More SC HP...without losing reliability
#41
Re: Re: Re: Re: Re: Re: Test Pipe Smell?!?!
Originally posted by dashingMax
Did you really notice a big difference between stock exhaust & the Apexi? The Apexi comes with a 2.25" b-pipe & 2.5" Muffler
The Greddy is 2.5 all the way & technically should provide better exhaust flow... just curious if you dyno'd before/after APexi install
![Roll Eyes (Sarcastic)](https://maxima.org/forums/images/smilies/rolleyes.gif)
To be honest, I didn't feel much of a difference with the Apexi exhaust over the stock exhaust in terms of power. I might get a custom 2.5" bpipe setup later on to make the flow much better.
#42
![](https://maxima.org/forums/images/smilies/support.gif)
Bobby here is the part number for that wrap. Mardigrasmax saw it he said good idea since it has velcro it will be easy to remove. I got it from Summitracing
DEI-010417
you can go to the summitracing website and look at it.
#44
Re: Re: Re: Re: Re: Re: Re: Test Pipe Smell?!?!
Originally posted by JAY25
DEI-010417
DEI-010417
I hope this is atleast work 5 ponies
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
#45
Re: Re: Re: Re: Re: Re: Re: Re: Test Pipe Smell?!?!
Just took a look at it. Almost $60 out the door!
after you come home from work or go to the store pop the hood and touch that tube. Ouch pretty hot, ha, wrap her up a bit
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
#46
As you said above, you want more power under 5k. Tuning your air to fuel ratio is the best way to do this. The Vortech FMU is usually very rich in the low and mid rpms under boost. Leaning this out will increase torque as much as 10ftlb, it did for me.
But your best bet is to just change the pulley for more boost!
#48
Originally posted by 1MAX2NV
Swift racing technology. They located in my neck of the woods =) I seen their GS400 with a blower running at the track. I think it ran 11s.
![shock](https://maxima.org/forums/images/smilies/shock.gif)
![EEK!](https://maxima.org/forums/images/smilies/eek.gif)
A car as heavy as the GS400 running 11's?!?!?!
Is it the Rear wheel drive that gives 'em the edge over us Maxima's?
#49
Whoa!!
Whoa!!
Their edge is that they START with a 300hp V8 and just with the addition of the blower they are at nearly 400hp....
#50
You could also think about getting a Cartech Adjustable FMU, and never having to deal with a non-adjustable FMU again.
3 pulls on the Dyno with my Cartech, and I'm tuned at 12.5:1 in the low end, and 12.1:1 in the high end. I couldn't get it perfectly the same thoughout the band because the MEVI chnges the variables after 5k RPM.
So I decided to go just a little bit rich on the low end.
But here's the good news:
I gained 13hp after tuning the FMU.
IanS
IanS
#51
IanS
IanS
Sorry to jump on your post bobby, so is the apexi SAFC and the Cartech the same thing then or different?? Because Matt just said the samething you said to adjust the fuel/air ratio
#52
IANS
IANS
Basically, the same function as the S-AFC, but mechanical, not electronic.
IanS
#55
Originally posted by Y2KevSE
You have the ability to adjust fuel at RPM points with the AFC.
true.
They're selling APEXi S-AFC's for $305 shipped on groupbuycenter.com
IanS
mkaresh
03-12-2018 06:48 PM
