One of my HID went out......??
Old Feb 23, 2003 | 10:38 AM
Woo Cho's Avatar
I have Hanabi 6000K purple HID's and one on the driver side went out?? Last time this happened when it was raining and I thought water might've sunk in or something but I found out that the starter was bad so the guy sent me the another starter and it was working fine, yesterday I found out it went out again, just like last time yesterday it was raining like crazy. Did this ever happen to anyone who have HID's on their car????
Old Feb 23, 2003 | 10:46 AM
costcowholesale's Avatar
where did you mount your starters & ballest?
Old Feb 23, 2003 | 11:17 AM
ru4real's Avatar
One side of my HID kit stopped working a couple months ago. I thought it was the bulb at first, but after swapping components with the working side, I narrowed it down to a faulty ballast. I opened the ballast and found a couple solder joints that looked weak or burnt out, so I soldered them and the ballast worked again. It was a relief to save some money. Maybe you can do the same.
Old Feb 23, 2003 | 11:57 AM
thebigsadler's Avatar
water is not hid's friend.. make sure its in a dry place.
Old Feb 23, 2003 | 03:06 PM
Mishmosh's Avatar
What kit do you have? My Hanabi kit did the same thing. Unfortunately the ballasts are epoxy filled boxes. There is no way to service them... Sucked that I had to shell out $55 for another ballast but at least the whole kit was still useable. I think I'd go for a reputable kit the next time.
CW
Old Feb 23, 2003 | 03:30 PM
Woo Cho's Avatar
CW
I have Hanabi 6000k purple......I talk to the guy and he said they stopped making the 6000k kit. and he told they were only 30 days warrenty.......
Old Feb 23, 2003 | 04:07 PM
Mishmosh's Avatar
Yeah. I have the 6000k blue. The problem is more the quality control / reliability than the warrantee to me. I know definitely that my ballast/starter do not get wet at all. Can't say why the ballast failed except low quality perhaps.
Actually, now that I think about it, it was the starter that failed! The red box. Looks like this is a weak point with the Hanabi Kit.
Old Feb 23, 2003 | 04:21 PM
Woo Cho's Avatar
first time when that happen to me I found out it was the starter, so I sent the starter back to the guy I bought this kit from and he sent me another starter and it was working fine for about 2 month and here we go again......
Old Feb 23, 2003 | 08:26 PM
Ravq's Avatar
Finally I found a thread with some downsides to the Hanabi kit. I've been researching HIDs for some time and am hoping there is enough info floating around about the different kits to start a comparison of the different brands. Are they any other regrets/dislikes you guys have about the Hanabi kit?
Old Feb 23, 2003 | 09:23 PM
HTownMaxSE's Avatar
one of my bulbs went out one time for like 5 min then it turned back on.
Old Feb 23, 2003 | 09:59 PM
GoldenGlory
i am goin on 1yr strong on my 7000k Hanabi Kit
with no problems what so ever
ballast are hidden under the headlights!
Old Feb 24, 2003 | 12:06 AM
just as a note.. the 6000k kit with starter and ballast as seperate units seems to be the only weak hanabi kit.
Old Feb 24, 2003 | 12:12 AM
95emeraldgxe's Avatar
phillips, catz and hella manufacture the best quality kits, stick with them and you wont have these problems
Old Feb 24, 2003 | 02:11 AM
carnal_c30's Avatar
Former Sponsor
a good friend of mine just had his McColluch ballast go out this weekend... only had the kit for a month or so
Old Feb 24, 2003 | 06:01 AM
meccanoble's Avatar
Sports Button FTW
if water is getting into it, more than likely its where it was mounted.
Old Feb 24, 2003 | 09:00 AM
ru4real's Avatar
CW
Panasonic "Vision" kit. I think it is somewhere around 4500K-5000K. Their newer kits have hotter color temperatures.
I've had it for 19 months. Water didn't get into the ballast. I'm guessing it failed because the weak solder joint burned itself out, or vibration knocked it loose.
Old Feb 24, 2003 | 12:08 PM
GaMax97GLE's Avatar
I had the Hanabi 6000k blue. I had 1 bad starter on day one, so I sent it back and didnt have any other problems from then on. I since wrecked that car and shattered one of the bulbs in the process.
Anyone want to buy?
Old Feb 24, 2003 | 12:33 PM
deezo's Avatar
Geez, I never had one problem out of the year I had my 6000K kit.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
