00VI Installed :)
Old Jan 1, 2005 | 10:55 AM
Kevlo911's Avatar
Kevlo for President
00VI Installed :)
Special thanks to Krismax and Tilley for helping me.
I still need to install the RPM switch and the oil seperator on the PCV line. I also need to drain coolant and install my lower temp thermostat so the car runs cooler. Finally, I need to make it work with my PR Style CAI.
Old Jan 1, 2005 | 11:04 AM
RA030726's Avatar
I'm nutty for Nissans
looking good. what did you do for the egr?
Old Jan 1, 2005 | 11:07 AM
Nismo3112's Avatar
Custom User Title
Woohoo!! Rock on
BTW: where is the IACV hose connected to on the intake?
Old Jan 1, 2005 | 12:57 PM
Kevlo911's Avatar
Kevlo for President
It's on the midpipe, but it is tilted so you can't see in pics.
I cut the EGR guide tube and connected it with a hose so it would be longer and fit more snug.
Old Jan 1, 2005 | 01:26 PM
stephenlc's Avatar
hey I have one sitting in my room and I wanted to know where the vaccum lines from the 2 fuel pressure regulators go. What do they connect to?
Old Jan 1, 2005 | 01:27 PM
stephenlc's Avatar
also where do you get the oil seperator?
Old Jan 1, 2005 | 01:30 PM
Kevlo911's Avatar
Kevlo for President
On the Fuel Rail, the one closest to the front of the car, replace with this http://www.sx7r.com/fuelfitting.htm
In hte middle of hte manifold, there are 2 elbows, one for PCV and one for vaccum. The small one for vaccum can be used for the FPR or you can use the stock vaccum source.
Also I got hte oil seperator from WalMart for 11 bucks. It is where they keep hte air tool stuff.
Old Jan 1, 2005 | 01:35 PM
deezo's Avatar
Good going Kev.
Old Jan 1, 2005 | 01:51 PM
stephenlc's Avatar
do you have to replace the first fuel rail fitting with that?
Old Jan 1, 2005 | 01:54 PM
Kevlo911's Avatar
Kevlo for President
I don't know if you have to, but it makes it more like stock and I think that is better. But my fuel rail didn't come with anything on the front one so I had to get it. Also my car is not running rich, or at least I can't tell it is.
One more thing to add, stock Midpipe doesn't fit
Old Jan 1, 2005 | 02:10 PM
stephenlc's Avatar
was it hard to sodder the wires for the injectors?
Old Jan 1, 2005 | 02:19 PM
Kevlo911's Avatar
Kevlo for President
No, that was one of hte easy things.
Old Jan 1, 2005 | 02:29 PM
kraimer21's Avatar
awesome!!!!!!!!!!!!!!! can't wait till it gets a bit warmer here so i get mine in as well!!!!
Old Jan 1, 2005 | 09:06 PM
RA030726's Avatar
SO you kept the stock EGR? thats wonderful! I really didnt want to remove it.
i have the "oil separator" you speak of and its not to be used with sythetic oils.....which i just switched to. the oil reacts with the plastic bowl and chages color. it may be eatting away at the bowl. ive been empting it out and keeping a close watch.
NO stock mid pipe?!! DOH!
Old Jan 2, 2005 | 06:02 AM
Kevlo911's Avatar
Kevlo for President
Oh, Thanks for telling me, I have been running synthetic for a few years now.
Yeah, all the brake stuff is in hte way on the right side, so stock one will not fit.
Old Jan 2, 2005 | 12:30 PM
EZEMaxima's Avatar
I've noticed your throtle cables are not aligned properly..Hope it doesn't start sticking on you especially during WOT...is that a PF tb you're running?
Old Jan 2, 2005 | 01:57 PM
MAX2000JP's Avatar
Thats a cool swap, but the 5th gen VI is poorly engineered in terms of reliability. I have had mine fail 2 seperate times and it is happening to a lot of people in the 5th gen forum. The good news is that there is a pretty simple fix for it.
Old Jan 3, 2005 | 11:16 AM
Kevlo911's Avatar
Kevlo for President
I already put JB Weld on it, it wasn't broken either.
As for the cables, it is not 100% alighned, but I will fix that today. It doesn't stick either.
Old Jan 3, 2005 | 11:18 AM
Nismo3112's Avatar
Custom User Title
Ive had mine for about a week, zipped tied on high end, today I tried it closed, and wow low end is pretty amazing.... punching it in 1st 1600 all you get is wheelspin
Old Jan 3, 2005 | 02:52 PM
Dave B's Avatar
Not DAVEB the parts guy
Wow. Nice clean install!!!!!!!!!!
Old Jan 3, 2005 | 02:56 PM
Kevlo911's Avatar
Kevlo for President
I got hte PR style CAI to work so that is good. It kinda feels better.
Old Jan 3, 2005 | 03:48 PM
Taken2DaMax's Avatar
Great going Kevlo, nice to see more and more people doing this.
Old Jan 4, 2005 | 12:24 PM
4DRSpeed's Avatar
Project Ruby......
Very nice!! I hope to do this in a couple of months!!
Old Jan 6, 2005 | 02:42 PM
95stillenmax's Avatar
how hard of a task is this 00vi to take on?
thanks Brandon
Old Jan 6, 2005 | 05:00 PM
Kevlo911's Avatar
Kevlo for President
You gotta know what you are doing, not fgor everyone.
I zip tied the VI open and damn. I can feel it pull like crzy after 5000 RPM. I LOVE it
Old Jan 6, 2005 | 08:27 PM
I have a MEVI but would like to have my torqe back
Old Jan 6, 2005 | 08:33 PM
Nismo3112's Avatar
Custom User Title
Ahh the zip tie method. You are right about the d@mn part. I really believe it has a better top and than the MEVI.
Old Jan 7, 2005 | 09:15 PM
sean05's Avatar
is the vi really worth it? How much does a 200 vi cost ya? i would like to get some more go out of mine but i love my low end.
Old Jan 11, 2005 | 12:53 PM
goodhead's Avatar
kevlo911 can you make a diagram or list of the whjat you did with the different fittings on the manifold, i think we talked about this before but i wanted to see what you ended up doing as final results and compare to my own plans
btw it looks like one of your screw on the im is loose
Old Jan 11, 2005 | 01:02 PM
Kevlo911's Avatar
Kevlo for President
I plugged up the vaccum line on the right side of the TB inlet neck. On the top vaccum inlet, I put a bigger elbow so the 10mm hose would fit in it. I got hte TB adapter block made and I install the 00+injector connectors.
Old Jan 11, 2005 | 01:07 PM
goodhead's Avatar
what are you using to plug those fittings with?
yeah i noticed the top fitting looks a lil different from stock, where is that one goign to?
Old Jan 11, 2005 | 01:20 PM
Kevlo911's Avatar
Kevlo for President
The top fitting goes to some EVAP thing. I filled in the hole with JB Weld.
Old Jan 11, 2005 | 01:23 PM
goodhead's Avatar
cool damn y didnt i think of that jb weld so easy i overlooked it
Old Mar 30, 2005 | 05:12 AM
NOZMaximus's Avatar
Ok, I've read most of things so far about the VI swap. I'm just a little un-clear as to whether the VI can be moved over without any customizing. No home made TB adaptors, no soldering.... etc.
Is it possible. I have a complete 2k block, so all parts are available to me
Old Mar 30, 2005 | 05:53 AM
Kevlo911's Avatar
Kevlo for President
Swap the engine, that is what I would do...
Old Mar 30, 2005 | 05:32 PM
ptatohed's Avatar
Licensed to Spell
Kevlo, any chance of a detailed write-up with pics, part numbers, etc.?
Old Nov 28, 2005 | 07:48 AM
Timz96SE's Avatar
Iacv And Throttle Body Adapaters
Who made the IACV and TB Adapater, if you know could you please send me info so i can purchase, thanks..
Old Nov 28, 2005 | 01:09 PM
Kevlo911's Avatar
Kevlo for President
Krismax made it, I dont think he makes them anymore. I had to modify it.
Old Nov 28, 2005 | 04:17 PM
Nickel's Avatar
what dose that do 2 your car?
MorpheusZero's Avatar
SWEEEEET... I seriously need to start reading up on this soon so when I have the dough I can tackle it!
There isn't really a complete writeup anywhere, is there... I bet quite a few people would kill for one...
MaxLife17
Jun 27, 2019 01:37 PM
t6378tp
Sep 29, 2018 04:27 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
