Reason: why do you need NOS???
http://hotwired.lycos.com/animation/...ivera/hare_cut
Only $375 from JCwhitney for your maxima
http://www.jcwhitney.com/item.jhtml?ITEMID=49791
That was pretty good Sprnt.
Hey, guess what arrived yesterday?
BTW, i picked up a NX pressure gauge for $25 today & i found someone who fills right by me. hehe.
I dont know what NOS is but i do know what Guin-NOS is. (Sorry, inside joke between me and Chris91SE)
BTW, i picked up a NX pressure gauge for $25 today & i found someone who fills right by me. hehe.I dont know what NOS is but i do know what Guin-NOS is. (Sorry, inside joke between me and Chris91SE)
cool... install it and let me know..
i will use you as my test dummy
Hey, guess what arrived yesterday? BTW, i picked up a NX pressure gauge for $25 today & i found someone who fills right by me. hehe.
Well, for some reason, the NX gauge wont fit with the NOS Bottle. The guy at the store say it's universal and should fit.
I guess i will have to go back and see what they are talking about. I didnt see any type of fitting or adapters in the kit either. BTW, my kit came with 4 jets. They arent even labeled so how do i know which is which? Doh!Chris-about time you changed it and we shall let every1 see what we are talking about! hehe.
Okay Sprnt, i found out why the gauge didnt fit.. well i kinda knew just wasnt positive. Anyways, the NOS kit has 4AN fittings and the NX (Nitrous Express) uses 6AN fitting. Now.. i had to order a $15 adapter so i can use the gauge i bought. Doh! There is $15 i could of spent on something else. Oh well. I'm 1 step closer. I was also quoted $250 for the install. That is a good chunk of change. I might just do it myself. Take my time for it.
The NOS deal from JC Whitney will last until 6/01 (end of the month). It is for $375 shipped to your door. Ask either me or Sprnt for the codes. Just dont forget that you will need to find someone who fills it, installs it (if your not a DIY mechanic), buy gauges, gauge pod, purge kit (optional), window switch (optional but highly rec.), bottle heater or blanket (optional but rec. if living in colder weather).
no thats the link i posted in the first post of this thing
Hey, what was that link you gave me earlier that you made of videos? On my friends computer and want to show him some videos.
Re: nos
its pretty much simple.. but has to be done carefully..
you got 2 solenoids.. connect those, run hose from bottle into solenoid 1, out of solenoid 2 is another hose that goes to the intake (between the TB and MAF) this also has your spray jet(shot control) between solenoid 1 and 2 the connector has a third end.. that connects to the NOS fuel Pressure Regulator, that connects to a hose... the end of that hose connects to a T fitting.. that T fitting has two other ends.. as it has 3 and one goes to the NOS pressure gauge... the other two .. one goes to the stock Fuel Pressure Regulator and the other goes to the line that use to go to the Stock Fuel Pressure regulator.. apart from that..everything else is electrical.. keep in mind you will have to drill a hole into the Intake...
Thanks to Matt for the scanned pic
Originally posted by MaineI30
how easy is NOS to install?
what other modification considerations should be taken into account?
Re: empty?
Tank is shipped emtpy for obvious saftey reasons.. you will have to find a performance shop near you to fill it up for you.. it usually about $30 - $35 for filling the tank
plus they ship the NOS empty.. interesting.. who fills these things?
you see what i am talking about by that diagram now right???
Damn, cheapest i can find around me is 4lb here. Doh! I already started the electrical work... all i need to do is the "hard" work. hehe.
NOS Kit from jcwhitney
I ordered the 40-60 shot NOS for $375 but I'm not sure if I received the correct one. They sent me, according to the invoices, the 5124 which comes with only a 70 shot nozzle. I suppose I could buy a smaller nozzle or I guess I'll have to get all my gauges, probably a triple-shot of AutoMeter (A/F, EFP, and EGT)and new fuel pump before I try to run it at a 70-Shot.
Does anybody think I can still run the 70 with the stock fuel pump since the NOS fuel pressure safety switch SHOULD cut of the nitrous if the fuel pressure is not adequate?
Is it possible to adjust the fuel pressure safety?
How to you adjust the rpms that the nitrous turns ON and OFF?
Re: NOS Kit from jcwhitney
According to Synki.. and i trust his judgement very much.. the kit comes with 40, 60 and 70 shot...
well Matt ran in a little problem running a 60 shot and decided to go get the pump.. so i would say on the safe side.. DO NOT run the kit with the 70 shot with the stock fuel pump.. this is entirely up to you..
To have the NOS come on at certain rpm's.. you will need a RPM window switch.. range from $75 - $200 MSD being the cheapest priced one on the market and NOS being the most expensive.. i have my kit.. i havn't touched it yet.. because i have a 5spd and the install is not happening till i get the RPM window switch.. call me extra cautious
Re: Re: NOS Kit from jcwhitney
Any idea on how the fuel pressure safety switch works or is adjusted?
Yep, my kit came with total of 4 jets, but 1 of them is for the fuel pressure. The 3 jets are the 50, 60, 70 shot. At least that is what i got.
Sprnt is right, i would get a window switch regaurdless. It just prevents you from spraying at a low rpm and spraying at redline. Well worth the $$ when you play with NOS.
Re: Re: Re: NOS Kit from jcwhitney
To the best of my knowledge "it is suppose to shut down the NOS when the fuel pressure gets out of whack" ...
I was hoping for the extra nozzles but I only have 1 blue nozzle. The invoice indicates I have the 5124 kit and all documentation points to a 70-shot from the 5124.
RPM Limiter
Sprnt is right, i would get a window switch regaurdless. It just prevents you from spraying at a low rpm and spraying at redline. Well worth the $$ when you play with NOS. [/B]
I guess these 'chips' come in packs of 5. Anybody want to sell the RPMs chips they are not using?
Originally posted by JAY25
That was sprint when he had Nawz in his ride!!!
Sprint you werent a turtle you were a hare!!
cool video I am loving it [/B][/QUOTE] Hey! Put the shovel down and step away from the thread graves!
