Got my CD Changer installed - almost
Old Jan 3, 2002 | 06:37 PM
2DMax's Avatar
I got it hooked up to the stereo and the cable run to the trunk...just have to mount the charger somehwhere.
Got to leave something for tomorrow !
Love it, finally a CD changer....it only took me three years !
http://forums.maxima.org/showthread.php?threadid=80898
Old Jan 3, 2002 | 06:46 PM
Bill Wattison's Avatar
How did you run the cable to the trunk? Is there a guide somewhere?
Old Jan 3, 2002 | 08:39 PM
Nismo's Avatar
What I did was removed the door sills and lifted the carpet up and ran the cable under the carpet and also removed the bottom part of the rear seat so you can run the cable through the arm rest and into the trunk. You dont have to but I took out the passenger seat so I can run the cable straight to the Fm modulator which is located under my ECU.
Old Jan 4, 2002 | 09:42 AM
pocketrocket's Avatar
Welcome to the changer world !!!
Just curious, how come you didn't go with the in-dash changer? Cost about the same, and it's within reach. Have fun.
Old Jan 4, 2002 | 10:18 AM
SuDZ's Avatar
Yeah vinipux has a good deal on changers. I think I might pick one up from him someday. Have any troubles installing it?
SuDZ
Old Jan 4, 2002 | 10:33 AM
2DMax's Avatar
No problems on the install. I think it took less than 2 hours.
There was a link for instuctions on how to remove the center console, and that worked great !
I pulled the little panel off at the foot of the passenger well, ran the wire under the glove compartment and down the A pillar.
Then pulled the door sills off the front and rear door. Also removed the rear seat (real easy-no tools required-just two ring, pull and the seat releases).
There was a wire duct along the passenger side of the car, you just have to pull the carpet back a little. I ran the cable along the duct to the rear, with the rear seat removed you can see a huge hole going to the trunk.
Bingo....remove the cheesy panels from around the trunk and mount the Changer.
I have the non-bose stereo, this deal came around, so I just jumped on it.
What are the in-dash changer units going for? Not that I am going to change now......
Old Jan 4, 2002 | 11:18 AM
ejj's Avatar
ejj
Where in the trunk did you mount it? I mounted mine up top (under the rear deck) and it was a bit of a pain because it didn't line up with any of the factory holes.
Old Jan 4, 2002 | 11:42 AM
jiaxima96's Avatar
Me and my sister's 96 GXE have the in-dash, 6-CD genuine Nissan changer, from Grubbsauto.com about half year ago. $119 including shipping that was an unbelieveable good deal to me. The only complaint from me, if any, is the time interval between any two CD's. It takes 20 seconds. Perfect otherwise.
Old Jan 4, 2002 | 01:27 PM
2DMax's Avatar
That is a good deal...and a long time.
This one is not that bad, less than 10 sec between disks
Old Jan 4, 2002 | 01:28 PM
2DMax's Avatar
I plan on mounting in on the rear deck, and will drill new holes to get it where I like it. I noticed the other holes don't line, go figure !
Old Jan 4, 2002 | 01:31 PM
ejj's Avatar
ejj
Ah, I misunderstood. I though you had already mounted it. Sounds like a good plan, that's what I did and it worked fine.
Old Jan 4, 2002 | 01:36 PM
SuDZ's Avatar
Where does it get mounted in-dash? Does it take over that little drawer under the bose setup?
SuDZ
Old Jan 4, 2002 | 02:20 PM
jiaxima96's Avatar
SuDZ
Well my GXE is not a Bose one, but a cheap, standard 4-speaker system.
Below the original radio/tape unit and above the flip-down storage, there was a pocket. I took it out and put in the in-dash CD changer.
Old Jan 4, 2002 | 03:34 PM
SuDZ's Avatar
Oh ok gotcha now.
SuDZ
Old Jan 4, 2002 | 03:57 PM
Ditto, same setup. I've got a 95 SE w/ the non-Bose.
Has the stock 1U-DIN cassette (made by Clarion), and I put the changer in place of the open-pocket. Kept the flip-down pocket
Yeah, there's about a 15-20 second delay between discs, but I prefer the delay over having to change the discs in the trunk. Too much trouble IMO.
Old Jan 4, 2002 | 06:39 PM
2DMax's Avatar
Ran the wires and connected everything last night, just had the changer sitting on the trunk floor...till tonight.
Just finished mounting it....done !
Rock on !
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
