Ignition Timing Retard Has Arrived For The Late Model Maxima!!!
Old May 24, 2002 | 03:25 PM
MardiGrasMax's Avatar
I just installed a J&S Electronics Ultra SafeGuard on my Maxima, I am in the process of putting it through its paces and will have more Maxima specific info shortly.
This unit is just what we have needed for sooooooo long for boosted and juiced Maximas. It will retard ignition timing based on the amount of boost pressure. It also has an auxillary input that can be used to pull a few degrees of timing when you hit the nitrous. The best part is that it monitors the knock sensor for knock and will pull timing if it detects any knock while in closed loop mode! It is also user selectable to pull timing on all cylinders or pull timing by the individual cylinder that is knocking!
I am so freakin psyched!!!
http://www.jandssafeguard.com/
Here is a picture, there are more on my home page. http://members.***.net/matchou/JansSPics.htm
Old May 24, 2002 | 03:28 PM
Confused's Avatar
Permanent Maxima.org Resident
like i said before... you are the timing retard... umm i mean, the man!!
Old May 24, 2002 | 03:32 PM
Jeff92se's Avatar
I'm needing a caw
Congrats, you have been stickied.
Yes, one of the best new mods by far.
Question. My quick glance only sees applications for 4 & 8 coil drivers(ie.. 4 & 8 cylinder cars) What do you use for our V6? An 8 coil unit w/ 2 inputs not used?
Old May 24, 2002 | 03:40 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
awesome man, awesome. great find, io'll let you know if it werks on 2k2's with dpi in several months/ how much is one?
Old May 24, 2002 | 04:42 PM
Three channel mode firing factory coils in wasted spark configuration.
Old May 24, 2002 | 06:01 PM
Anachronism's Avatar
A few questions --
Cost? OK, browsing the J&S site I found prices of $545/595, do they go for any cheaper?
Are there any potential performance benifits from this for N/A Maximas?
Would this eliminate the need for colder plugs with nitrous?
Old May 24, 2002 | 06:10 PM
Originally posted by Anachronism
A few questions --
Cost?
If you were to build a higher compression NA motor it would be nice to have the closed loop knock protection, but for stock it is not necessary unless you want to run really cheep gas
It may eliminate the need for colder plugs in nitrous'd VQ's. It depends how much nitrous, this would be a question you would need to investigate your self by using the unit and trying a few combinations.
I paid $525 shipped.
Old May 24, 2002 | 06:12 PM
desertmaxima's Avatar
A few questions --
Cost? OK, browsing the J&S site I found prices of $545/595, do the go for any cheaper?
No you would till need the colde plugs but this will releave a lot of my anxity as far as timing retard. Damn why couldnt ya have psted this bout 2 months ago when I had my max i could have turned up the juice a little
Old May 24, 2002 | 11:31 PM
Nealoc187's Avatar
SLOW
I'm assuming this couldn't be used to advance timing as well, only to retard it?
Old May 25, 2002 | 06:32 AM
Sorry, only retard.
Old May 25, 2002 | 06:37 AM
JAY25's Avatar
Re: Ignition Timing Retard Has Arrived For The Late Model Maxima!!!
Matt think youll need some type of help to install this? if yes I am off on Monday so let me know? tomorrow Sunday good too, but I dont know if you will do tomorrow!
Old May 25, 2002 | 06:40 AM
Jamie, I guess you missed the first line of my post
Its already installed, thanks for the offer.
Old May 25, 2002 | 09:14 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Good job Matt. Can't wait for the write up.
Do I see 2.62" in the future? Maybe a little nitrous wouldn't hurt either.
Old May 25, 2002 | 12:40 PM
CalsonicSE's Avatar
Yeah yeah, do it Kev! hehe Okay, 100shot here I come...eh..maybe not, I'm more concerned about my tranny than the motor. =P
Thanks Matt for the info.
Old May 25, 2002 | 06:14 PM
2.xx somthing for sure!
370cc injectors!
A bit more juice!
Hello 12's
Old May 26, 2002 | 05:54 AM
turbo97SE's Avatar
370cc injectors!
A bit more juice!
Hello 12's
Awesome! You got the wasted spark to work! Heheh ... pushing the edge!
Old May 27, 2002 | 08:14 AM
Screaminfast's Avatar
Awesome....thanks for the email on the update on this.....I kinda ran outta money because I've been spending most of it on my other hobby, computers....hehehe. Anyways, I'm definitely interested in doing something like this because it would be the perfect addition to let me run the higher compression pistons and still run a lot of boost.....still haven't picked up my engine yet, because they said it wouldn't fit in my jimmy..hehehe
-Mike
Old May 27, 2002 | 11:36 PM
axion's Avatar
Well, sorry but can somebody explain real quick what this allows us to do? Run higher boost or what? Either way it sounds great obviously.
Old May 28, 2002 | 08:39 AM
More boost and juice with out having to worry about to much ignition timing.
http://www.jandssafeguard.com/detonation.html
Old May 28, 2002 | 09:40 AM
1MAX2NV's Avatar
Good job Matt. I will wait for your write up. The last time I mess with the ignition system/ECU.....
Old Jun 22, 2002 | 11:04 AM
Group deal is ready to go
Group deal is ready to go.
http://forums.maxima.org/showthread.php?threadid=130453
Old Jun 22, 2002 | 03:39 PM
deezo's Avatar
After looking at the pics of Chungers plugs last week, he could definitely use this unit.
Max8
Aug 15, 2015 07:06 AM
Balkins
Aug 12, 2015 06:39 AM
xUNIxPanther
Aug 5, 2015 09:31 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
maxima297
Aug 3, 2015 12:50 PM
