Blinker is blinking very fast
Old Mar 31, 2005 | 10:10 AM
KNYFE's Avatar
Hey, I changed out my rear blinker bulbs for LED's and now it is blinking VERY fast. Anyone know why or how to change it?
Old Mar 31, 2005 | 10:24 AM
skeetch's Avatar
Edited for too much Blah Blah Blah.....DMvd pointed out below (need to match your current draw with the stock bulbs).
More info here;
http://www.bettercarprices.com/corve...206166060.html
Old Mar 31, 2005 | 11:34 AM
MaDMvD's Avatar
Did you use resistors? 'Nuff said.
Old Mar 31, 2005 | 12:59 PM
BEJAY1's Avatar
Conecarver
I know nothing about LED's but my wife's Jeep had that problem with bulbs and it was a short between the bulb and the harness.
Old Apr 1, 2005 | 06:33 AM
Dr.Monkey1313's Avatar
BEJAY1: I did the same and here is what I id to correct the problem and get the LED bulbs back to the normal speed. Very easy to do. Buy one for each side and install. Problem solved.
www.superbrightleds.com
RL-650 Load Resistor kit
6 Ohm, 50 Watt load resistor kit
Solves most LED turn signal problems
Connect one across each LED turn signal bulb to simulate filament bulbs
$ 4.95
Old Apr 1, 2005 | 07:17 PM
illmortal's Avatar
LEDs dont draw as much power.... so it doesn't have to build energy for it to light up an LED... I wouldn't mind having a fast blinking turn signal, as long they are LEDs (fast on and off, instead of phasing out and on)
Old May 22, 2012 | 10:04 AM
corbryant's Avatar
$ 4.95
You just install a load resistor on each side of the car? Or each bulb? I replaced front and rear signals with LEDs and the website is telling me to add a resistor at each bulb. Is that right? Or do I just install a resistor on each side at only one bulb?
Old May 22, 2012 | 11:23 AM
VQ'rInWLA's Avatar
Resistor on each bulb
Old Sep 8, 2012 | 10:46 AM
corbryant's Avatar
Thanx. I finally got the lights out of the back and I just got back from Radio Shack with resistors. Didn't want to wait for em to come from the online store. Don't know wtf I was thinking, but I came home with .50 Ohm 5 watt resistors instead of 50 watt 6 Ohm. Wired one up and the light didnt blink at all. LOL Duh.
On my way back to Radio Shack. I'll eventually get this done.
220k+ A32
Sep 23, 2015 03:38 PM
pears
Sep 18, 2015 05:25 AM
BrandonCause
Sep 14, 2015 10:41 PM
dcardello
Sep 3, 2015 11:44 PM
