Noise On Cool Day
Old Sep 10, 2002 | 01:50 PM
AUSTIN618's Avatar
Noise On Cool Day
I have a 92 GXE making some weird noise when the temperature cool outside, like after a rain or in the winter. It sounds kinda like a clattering type of noise. I think it is coming from the front of the car and usually occurred at start up or over a bump. At nornal cruising, it's not there. Does any one out there has this same problem. If so, what was it? What was done to make it go away?
Old Sep 10, 2002 | 02:06 PM
James12345's Avatar
Re: Noise On Cool Day
Originally posted by AUSTIN618
I have a 92 GXE making some weird noise when the temperature cool outside, like after a rain or in the winter. I think the noise is coming from the front of the car and usually occurred at start up or over a bump. At nornal crusing, it's not there. Does any one out there has this same problem. If so, what was it? What was done to make it go away?
You'd kinda need to describe the noise if you want any help...
Old Sep 10, 2002 | 02:58 PM
NOMAD92SE's Avatar
does it go snap crackle pop? it's probably your cv joint/axle, usually the dust boot tears and it slings grease everywhere and it will get dirt in the joint and cause it to fail.
Old Sep 10, 2002 | 03:01 PM
SecretAsianMan's Avatar
I have a 92 GXE making some weird noise when the temperature cool outside, like after a rain or in the winter...What was done to make it go away?
You say it happens after a rain, in the winter or when you go over a bump, so I think you need to check your belts. When the belts get hot they don't slip as easily.
--SAM
Smackasmith
Feb 1, 2016 12:40 AM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
