Which HKS SSQV Flange? 50mm or 65mm?
Old Aug 27, 2003 | 11:53 PM
Chebosto's Avatar
RIceD OuT moDErAtor
Hey guys..
curious on which of you Turbo guys who DO have the HKS SSQV, which size flange did you get?
--Cheston
Old Aug 28, 2003 | 08:30 AM
BigDogJonx's Avatar
I got the 50mm flange and it didnt fit. I think they are made for 2" piping. the 60mm flange wouldve fit the curve of the 2.5" IC piping better. I ended up having to grind down the flange to make it fit better since I got the wrong one.
Dixit
Old Aug 28, 2003 | 08:38 AM
thebigsadler's Avatar
60mm fit perfectly on my 2.5" piping on the bend.
Old Aug 28, 2003 | 10:04 AM
Ramius83
60mm on my 2.5 inch piping as well.....
Old Aug 28, 2003 | 12:59 PM
BigDogJonx's Avatar
50 works well if you want to grind the shiet out of it
Old Aug 28, 2003 | 01:34 PM
hahahaha
Old Aug 28, 2003 | 01:55 PM
BigDogJonx's Avatar
Again when in doubt, hammer it into place or grind the shiet of out it to get it to fit. Its all about the fit man!
Old Sep 2, 2003 | 05:49 AM
PCGuRu2K's Avatar
I have an extra HKS flange if anyone needs it
Old Sep 3, 2003 | 10:11 PM
hooktup98SE's Avatar
Originally Posted by Chebosto
Hey guys..
--Cheston
60mm is perfect fit for my stillen SC kit.... and it's damn loud too! (under full boost)
Old Sep 4, 2003 | 09:41 PM
Chebosto's Avatar
RIceD OuT moDErAtor
this is for my TT for my Z..
so damn. 50 too small eh? the pipe diameter is like 3.25"
Old Sep 4, 2003 | 09:45 PM
BigDogJonx's Avatar
Shiet.... the larger flange still aint going to work on 3.25" piping, i say get the 65mm and get him to grind the edges and it will fit. Thats what the welder did on my 50mm for the 2.5" piping even though it was supposed to be for 2" or smaller piping.
Old Sep 4, 2003 | 09:46 PM
Chebosto's Avatar
RIceD OuT moDErAtor
the only reason why i went 50mm is because i'm probably only going to see like around 8 psi..
i didnt think the 65mm flange would be needed...
Old Sep 4, 2003 | 09:55 PM
BigDogJonx's Avatar
I thought the flange has nothing to do with how much psi you are going to run, I thought it has to do with the arc on the bottom so it can fit the piping for a clean fit and weld.
Dixit
Old Sep 4, 2003 | 09:57 PM
Chebosto's Avatar
RIceD OuT moDErAtor
flange size is the opening.. obviously the bigger boost levels you have, the bigger the hole you need to vent faster..
hence 50mm is for smaller boost applications.. it just so happens that the curvature of the piping causes trouble..
if all it takes is some grinding, then thats fine.. i'll just lop off the part where the SSQV bolts onto and weld a new connector piece to the bottom of it...
Jeff92se
Nov 1, 2001 12:14 AM
Dave B
Jan 11, 2001 05:59 AM
Dave B
Jan 8, 2001 09:57 PM
Loren00Miata
Dec 20, 2000 07:02 AM
Avalon Racing
Dec 10, 2000 09:45 AM
