Someone help w/ seafoam please...
Any 4th generations have any write ups or FYI or pics about what to do with seafoam. I would really appreciate it your help and yes i know this should be in fluids and lub section.
I have a 95 with 108500+ on it. Thanks
Yes and I don't think there are many choices in regards to how to get it into the gas tank.
Originally Posted by NYR1199
If I put it in the gas tank, should I fill it up first? Also, what is the best place to put it?
Find the vacuum line going from the manifold to the brake booster. The brake booster is the round thing that mounts to the firewall and holds the brake master cylinder and the brake fluid reservior. The line has a c-clamp on it or something similar. If you disconnect it when the car is running, you will hear a sucking sound. Make sure the car is good and hot, put the Seafoam in a small cup and stick the hose down inside the cup. The vacuum will suck the Seafoam into the manifold, the engine will hesitate and bog down a little. Turn the car off and let it sit for at least 5 mins, start the car and let the heat blow out the Seafoam and crud. You can do it again after 100 miles or so. Change your oil after a couple of hundred miles.
220k+ A32
Sep 23, 2015 03:38 PM
neptunemax
Feb 4, 2004 06:04 PM
