5spd flashing O/D light?!! hmmm
Well i did a 5spd swap A LONG TIME AGO...and i have a 5spd ecu....everything is fine, i have been having some problems with my TPS sensor, keep getting the code even with a new sensor...check all the wires continuity and resistance...perfect...adjusted new tps using voltage AND resistance...just incase lol....everything is within spec...
I was messing around with a different tps...and for some reason when i went inside for 2 seconds i came back and my gauge cluster lights werent turning on...(CEL, BAT, etc.) i blew 2 fuzes... replaced em....still getting the damn tps code, and now i have this crazy blinking....
1 long and 16 short.... im assuming this is what it is refered to in the stickies:
"1st flash longer than others = Revolution sensor is shorted or disconnected. "
first of all, isnt that for A/T sensor? if not what the h3ll is it? lol
Well what i did was take the fuze out for it lol..
I blew the meter fuze (gauges) and i forgot i put a blown fuze in the place of the A/T module when i did the 5spd swap....i guess i have to take it out..
were there any wires that you had to re-run as a result of removing the ATCM?
Maxima30
Sep 7, 2015 06:13 PM
