NOS gages
Old Dec 19, 2001 | 07:21 PM
nigelcmf's Avatar
NOS gages
Hi I just got a NOS kit. I want to make sure I do not blow up my engine by running to lean. What's a good A/F gage I can use? I asked a guy at my local performance shop, he said autometer's are OK but move very erratically and probably would not be accurate. Is there an alternative?
Also are there any other gages you would recommend? Fuel pressure? I will be searching the other postings, but any help would be appreciated.
Old Dec 19, 2001 | 07:36 PM
Sprint's Avatar
ok this is how it works
First Step
http://forums.maxima.org/search.php
Second Step
type in Keyword gauge select Forum General Maxima Discussion and hit submit
then comes this...
http://forums.maxima.org/search.php?...der=descending
Third Step
Scroll down for what you want..
then boom
http://forums.maxima.org/showthread....ighlight=gauge
and
Old Dec 19, 2001 | 08:05 PM
hlh0501's Avatar
First Step
Second Step
then comes this...
Third Step
then boom
and
beautiful, couldn't have said it better myself.
Old Dec 20, 2001 | 12:06 AM
DOM's Avatar
DOM
Here is what I want for Christmas...
http://www.speedpeople.com/cart/cart1.cfm?SubCat=Gauges
Old Dec 20, 2001 | 05:17 AM
nigelcmf's Avatar
Thanks everyone. I really appreciate your help!
Nigel
Old Dec 20, 2001 | 05:56 AM
Sprint's Avatar
Nigel
Old Dec 20, 2001 | 07:06 AM
VE30DE POWER's Avatar
Re: NOS gages
cyberdyne is a good one along with jumptronix "best in my opinion"
Old Oct 3, 2002 | 09:36 PM
SpicyTuna's Avatar
Where do you tap for an afr (jumptronix) guage? @ the ecu? or @ the actual o2 sensor?
Old Oct 3, 2002 | 09:55 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
So, when is Nigel going to use his rice juice with the turbo?
Old Oct 4, 2002 | 03:00 AM
Sprint's Avatar
if the gauge doesn't come with an additional wideband O2 Sensor then it won't be as effective.. if it does.. then put that O2 Sensor in the y pipe and connect it to the gauge..
if the gauge comes by it self.. you can connect it to the O2 sensor.. but keep in mind that the readings will not be accurate
Old Oct 4, 2002 | 08:03 AM
mtrai760's Avatar
'Trynna' is not a word
sx7r (Thomas) has a greddy a/f gauge for sale REALLY cheap in the for sale forum...
Old Oct 4, 2002 | 09:38 AM
TellschMax02's Avatar
I am curious as to why connecting to an exisitng o2 sensor is not accurate? All it is measuring is the o2 voltage right?
Here is some general info for anyone interested.
Here is a good link for A/F Information
Here is another good link on the A/F EGT debate (not specifically written for the maxima - but you get the idea). If you search google or whatever you will find other good info. Click Me
Brian
Old Oct 4, 2002 | 10:25 AM
Sprint's Avatar
not too sure.. but it appears that the car uses that one and it must be doing other stuff.. because when i tapped my O2 sensor off hte ECU it moved like and equalizer.. up and down.. but everyone recommends using an additional O2 sensor for more accurate readings
Brian
Old Oct 4, 2002 | 11:03 AM
theblue's Avatar
the reason why the stock O2 sensors are bad on a maxima is because they are not wideband. They only read rich, lean, or normal so you won't get a good reading. Get an EGT
Old Oct 4, 2002 | 11:20 AM
SLC I30t's Avatar
Dont waste your time with A-M. It only give you a metered signature till about 4k rpms. If you want to see what your car is really doing, go and buy an 02 sensor and install into the Y pipe collector just before the flex. That way its not effected by the open/closed loops dilemas you'll face on one of the bank sensors.
Old Oct 4, 2002 | 11:30 AM
Wideband = $$$$
I agree and have always preferred EGT to A/F but one needs to consider that just because the A/F Gauge comes with a separate o2 sensor - it does not mean it is a wideband gauge (the greddy unit is not a wideband for example). Wideband gauges are very expensive (700 and up) and are probably not too common for Maxima owners.
So I guess bottom line - it is up to you on which one you prefer. There are arguments for both of them.
Brian
Roymg
Aug 17, 2015 02:44 PM
Cumalot
Nov 28, 2000 09:38 AM
Cumalot
Nov 26, 2000 04:30 PM
ereet
Nov 26, 2000 03:44 PM
Slickismax
Nov 5, 2000 08:51 PM
