BIG Problem
Old Feb 13, 2018 | 04:48 PM
klt2000's Avatar
BIG Problem
This is the biggest problem I have ever had.
1989 Nissan Maxima. I have no inside lights or radio or anything. Turn the key on still nothing...nothing works. I start the car and everything works...radio everything. Also the alternator is not charging the battery. The alternator has been removed and bench tested and passed.
The ignition switch was been changed with a new switch...no change.
The relays on the fuse panel have been changed around with no change to the problem.
I am driving the car by charging the battery with external battery charger. Everything works (blinkers, radio, all lights inside and out) as long as the car is running.
Please does anyone have any idea?
Old Feb 13, 2018 | 09:45 PM
DennisMik's Avatar
I would check all the fusible links and fuses in the fuse box that is under the hood between the battery and the fender.
Old Feb 15, 2018 | 08:09 PM
klt2000's Avatar
No interior electrical of any kind
I have checked the fuses in the box under the hood next to the battery. All are ok...I ohm tested each one and all pass. The two relays seem to be ok also...each passes ohm test on the circuit that is not a switch.
So far I have checked, the main fusible link,
all the fuses and relays inside the car, and I have replaced the ignition switch.
But everything works once the car is started
Old Feb 17, 2018 | 04:10 AM
Hectic's Avatar
If the biggest problem you have ever had, is no power when you turn the ignition switch on a 1989 Maxima, consider yourself lucky.
Old Feb 22, 2018 | 12:22 PM
Vg30ekid's Avatar
Check the radio fuse on the back of the head unit for the radio is what I would for that but for the rest of the lights inside the car I don’t know.
Old Mar 11, 2018 | 04:54 PM
klt2000's Avatar
I am still having the a major problem with my 1989 Maxima. There is absolutely nothing electrical working in the car, no door lights radio, automatic shoulder strap, until the car is started, then everything works. Even turning the key on before starting nothing comes on. The problem that happened at the same time this problem happened is that the alternator is not getting to the battery. I have taken the alternator off and had it bench tested and it passed.
All fuses have been checked in the car and under the hood next to the battery....all ok. It would seem that a bad fuses wouldn't work either before or after the car was started.
I have checked the battery cables and all seem to be ok.
Shift_my vq
Jun 16, 2004 10:49 AM
chinaonnitrous1
Jan 5, 2003 02:12 AM
tennis5luv
Oct 24, 2001 02:16 PM
Matt93SE
Aug 3, 2001 04:58 AM
