2021 Maxima water issue
Old Jun 8, 2024 | 07:06 AM
jrseydev1's Avatar
I have a 2021 maxima and iam getting water in the driver side
front door. its inside the door panel. I dont know how its getting in there. door closed tight, windows up. and when i push and pull the door back and forth you can hear the water. unreal would this be under warranty anyone having or had this issue?
Old Jun 8, 2024 | 10:29 AM
RickSmith's Avatar
Do not dispair, a solution is at hand...literally.
Each of the four doors have small drain holes in the bottom of the door, which in your case are clogged with who knows what debris.
Bend, kneel, lie on your back... but with a small flat bladed screw driver in hand, somehow manage to look at the bottom of the door.
You should find the drain hole/s.
Use the small screwdriver to clean out the hole/s.
Problem solved.
Old Jun 8, 2024 | 11:08 AM
jrseydev1's Avatar
that's it. thank You
Old Jun 9, 2024 | 05:10 AM
robtroxel's Avatar
Problem solved.
Well said and done Rick!
soldierp91x
Jan 17, 2024 09:14 PM
Vg30ekid
Aug 20, 2018 06:52 AM
CauzinDrama
Oct 19, 2012 06:20 PM
Ka$hThaRipper
Mar 10, 2004 12:52 AM
Peter_98_SE
Feb 22, 2003 07:40 PM
