Advantages of DP with a 75-shot.
Old Feb 16, 2004 | 08:38 AM
Bluebird's Avatar
I am Roid Rage
Comtemplating a nitrous kit (who isn't ) and I'm debating the direct port kit vs. a regular wet kit. If I'm only going to use a 75-shot, what are the advantages of direct port, besides being safer for the engine. Do the advantages justify a $300 increase in the cost of the kit and a significant increase in cost of installation?
Old Feb 16, 2004 | 08:51 AM
Jime's Avatar
I have installed and helped to tune both and thats why I still have the wet kit. Tuning is much more difficult and installation likewise, especially if you use the SS hardline. Also had to buy an FPR for the DP, with a 75 wet you can run stock everything for the fuel.
Don't really believe you are any safer either, especially with only a 75 shot. For 100 and up yes but you want to make sure everthing is perfectly tuned in either case.
Good Luck
Old Feb 16, 2004 | 08:57 AM
plurco's Avatar
hey they do look cool
Bluebird's Avatar
I am Roid Rage
That pretty much addresses my issue. Thank you Jime, aka Jesus H. Christrous.
Old Feb 16, 2004 | 07:41 PM
Nismo's Avatar
wouldnt 75 wet be maxing out the stock fuel pump?
Old Feb 16, 2004 | 08:02 PM
DaThrillr's Avatar
that is y a FPR is needed..right? i think u are safe till about ~100 shot on stock pump for a dry shot i dunno about a wet. , nismo u could set up a feul cell with a new feul pump just for the wet kit
Old Feb 16, 2004 | 09:02 PM
MaxSpeedSE's Avatar
Ive been running a 75 shot on stock pump, FPG, and stock copper plus for months now with no problems
Old Feb 17, 2004 | 04:17 AM
plurco's Avatar
are you running an AF or EGT gauge? If so what are the readings under spray?
Old Feb 17, 2004 | 01:47 PM
MaxSpeedSE's Avatar
I have no gauges at the moment
gman214
Sep 25, 2015 03:03 PM
BigDogJonx
Apr 4, 2001 04:52 PM
theMax
Apr 2, 2001 12:51 PM
psing23
Dec 1, 2000 11:48 PM
CalsonicSE
Nov 8, 2000 05:45 PM
