pictures of my turbo build
Old Jan 19, 2008 | 02:04 PM
  #161
Grand_hustle17's Avatar
Originally Posted by absoundlab
ya I would say so, if you do forward feed y pipe or reverse feed y pipe the turbo sit about where the battery is located.
thanks for the info, ill let my mechanic knows ahead of time, not that he dont,
Old Jan 19, 2008 | 02:25 PM
  #162
kzoosho's Avatar
wow, you guys should own your own shops, yall do some amazing stuff, my only question is that, with every turbo setup, do you have to re-route the battery?
Not that you need to it just makes things easier. My turbo sets right where my battery was.
Old Jan 19, 2008 | 04:30 PM
  #163
Kramer2k's Avatar
Good God! I could look at these FI setups all day long. Nice work indeed.
Old Jan 21, 2008 | 01:00 PM
  #164
Tippy Toes's Avatar
absoundlab, are you making the west palm beach meet on march 16th? Be nice to see that baby. Good job if its done by then and what you've done so far
Old Jan 21, 2008 | 01:26 PM
  #165
kzoosho's Avatar
I may be there along with a couple other boosted people
Old Jan 21, 2008 | 09:09 PM
  #166
absoundlab
I didnt know about the meet pm me more info
Old Jan 22, 2008 | 08:56 PM
  #167
95BLKMAX's Avatar
its on SFMG homie, take a peek, lol
Old Jan 30, 2008 | 11:08 AM
  #168
absoundlab
all the intercooler piping is finally finished. all the piping is 2.5" and right after the maf is 3" going to the throttle body. greddy type rs blow off valve and 300zx maf
(please note these are just quick pictures I took, I know the t bolt clamps aren't on and the blow off valve flange isn't welded on yet.
Old Jan 30, 2008 | 11:10 AM
  #169
kzoosho's Avatar
Comming along man. NIce.
Old Feb 1, 2008 | 01:26 AM
  #170
jimmypronet's Avatar
Damn.... Looking good....
Old Feb 1, 2008 | 03:46 AM
  #171
secondtonone317's Avatar
nycnissans
lookin schweet
Old Feb 1, 2008 | 06:37 AM
  #172
Kevlo911's Avatar
Kevlo for President
I thought the Z32 maf didn't work with 5th gens? Also, it doesn't look like the maf adapter is metal, you should def get one.
Old Feb 1, 2008 | 11:40 AM
  #173
timmay5835's Avatar
I was actually checking your thread on tamparacing, i have seen your car around the area. good progress with the turbo build up. lookin good
Old Feb 1, 2008 | 12:16 PM
  #174
Tatanko's Avatar
Bacon Lover
Definitely. Plastic is no good for a boosted application (hell, I use metal on my NA car). I've heard too many horror stories.
Old Feb 1, 2008 | 12:24 PM
  #175
densetsu's Avatar
what happens to the plastic, does it warp?
Old Feb 1, 2008 | 03:35 PM
  #176
DrunkieTheBear's Avatar
Turbo'd Saab
it melts
heat is the enemy of all turbo builds
nice job so far
Old Feb 2, 2008 | 01:43 AM
  #177
densetsu's Avatar
Originally Posted by SilMax00
it melts
the maf housing and other various elements are plastic, how come they dont melt?
Old Feb 2, 2008 | 06:38 AM
  #178
Kevlo911's Avatar
Kevlo for President
The are a different grade of plastic, you can't honestly think a plastic maf adapter is gonna be higher quality plastic than OEM.
Old Feb 2, 2008 | 07:28 AM
  #179
kzoosho's Avatar
Aint that the truth.
Old Feb 9, 2008 | 10:31 AM
  #180
absoundlab
precision sc61
greddy products : oil catch can rs bov and profec b
color matched dash panasonic tv greddy profec b spec II ebc and apeci turbo timer
Old Feb 9, 2008 | 05:11 PM
  #181
shortyblu95's Avatar
did u buy the wrong size t bolts for some there?
Old Feb 9, 2008 | 06:14 PM
  #182
absoundlab
no they aren't installed in the picture
Old Feb 9, 2008 | 06:17 PM
  #183
yea i see that i just figured maybe you threw em on there for the pictures or w/e but then i noticed the compressor outlet one looks like it wont close enough to be able to get the nut on, no biggie. Good work btw looking like its going to be a great setup!
Old Feb 10, 2008 | 02:17 PM
  #184
absoundlab
Old Feb 10, 2008 | 02:28 PM
  #185
DrTySOUFMaX23's Avatar
looks nice...i like the set up!!
Old Feb 10, 2008 | 02:30 PM
  #186
Kevlo911's Avatar
Kevlo for President
Like I said, the maf likely won't work
5th gens+ are much better off using a bigger maf housing.
Old Feb 10, 2008 | 02:59 PM
  #187
absoundlab
I still need help finding a write up on how to install a 300zx maf on a 5th gen
Old Feb 10, 2008 | 04:11 PM
  #188
Torgus's Avatar
hot. good luck!
Old Feb 10, 2008 | 06:57 PM
  #189
Kevlo911's Avatar
Kevlo for President
It doesn't work from what I have read and seen, even with the EU...
http://forums.maxima.org/showthread....ht=z32+gen+5th
Is the closest I found? Search is weird, it shows the same threads multiple times haha
If I find the thread that has it test I will post it
Old Feb 10, 2008 | 08:14 PM
  #190
Tatanko's Avatar
Bacon Lover
o rly? Then what do the higher-HP 5th gen guys do? I know there aren't many of them, but there have been some.
Old Feb 10, 2008 | 09:36 PM
  #191
maxgtr2000's Avatar
KH3 by popular demand
On their cars they can simply go to a bigger maf housing using the same sensor. Land Rover maf housing seems to be the ticket, or somehow find a custom piece of metal tubing a little bit over 3 inches in diameter, not anything near 3.5 cause I heard there would be air reading problems.
Old Feb 10, 2008 | 10:16 PM
  #192
AceofSpds's Avatar
wat
5th gen MAF's are very fragile though :/
Old Feb 22, 2008 | 06:51 AM
  #193
absoundlab
I finally got the exhaust piping made
greddy tial wastegate (I know the oil drain hose is kinked)
Old Feb 22, 2008 | 06:52 AM
  #194
absoundlab
Old Feb 22, 2008 | 06:55 AM
  #195
95BLKMAX's Avatar
bahahahaha!!! weeeeeeeeeeeerd!!!!!!
SFLMaximas doing it big in 08!
Old Feb 22, 2008 | 07:09 AM
  #196
that looks F'in GREAT! Awesome work man!!!
Old Feb 22, 2008 | 07:46 AM
  #197
dfownz's Avatar
Just went through the entire thread and I LOVEEEE it.
Can't wait to see the dyno numbers!
Old Feb 22, 2008 | 07:48 AM
  #198
absoundlab
im going to be running 4 systems now :
boost nitrous meth and co2
Old Feb 22, 2008 | 05:22 PM
  #199
BigLou93SE's Avatar
Turbo looks exactly like the one I received in the mail today for my 240sx...nice.
After looking at your pictures, I've been reminded of all of my engine bay room...I respect you guys for cramming so damn much in there!
Old Feb 22, 2008 | 10:47 PM
  #200
streetzlegend's Avatar
Awesome dude. A recommendation though, get wing nuts for the cutout, make it ALOT easier to remove. also if thats a summit racing cutout, dont use the paper gasket crap, it dosnt work, instead on the plate make a cooper silicone gasket, thats wat iv done.
