Another Almost Boosted 3.0
Old Feb 15, 2012 | 08:34 AM
  #161
chongher's Avatar
I would start with the fuses first before anything since it's the most easy thing to check. They might look good from the eye view but if you shake them sometimes thats how you catch it if it is bad. But GL.
Old Feb 15, 2012 | 08:41 AM
  #162
NSMO240's Avatar
Its a 96 so it doesnt have key problems, the alarm has not been armed for months now. I always take it off the battery then lock the doors to make sure it never accidentally arms itself then gets stuck there.
wow, for some reason i was thinkin it was an 01 or something. well nevermind on that then.
you double check all grounds?
Old Feb 15, 2012 | 09:44 AM
  #163
Crusher103's Avatar
Originally Posted by t6378tp
since you have fuel and no spark time to start testing everything from the plugs and work your way back to the ign switch.
have you attemped to pull a plug put it in the coil crank the car while grounding it to confirm there is no spark or atleast unplug a coil to see if your getting 12v, ground and a crank signal
yes, i did that. No spark.
Now its where to start with finding out what's wrong. im dumbfounded right now. Nothing i have done has made any positive results on getting it started again.
Old Feb 15, 2012 | 09:56 AM
  #164
Crusher103's Avatar
i have a multimeter that i might have to use to figure out what is not getting signal directly from the ecu, question i have is does the car need to be cranking or can the problem be found with just the key in the on position. That and what does the voltage need to look like?
Old Feb 15, 2012 | 12:27 PM
  #165
t6378tp's Avatar
Turbo 3.5
you'll power to check some stuff and cranking for the rest
did you check the coil harness for 12v while the key is on
Old Feb 15, 2012 | 03:46 PM
  #166
Crusher103's Avatar
I did not do that check, how do i do that one.
Old Feb 15, 2012 | 05:32 PM
  #167
Kevlo911's Avatar
Kevlo for President
da thick red wire on da coils
Old Feb 15, 2012 | 05:36 PM
  #168
t6378tp's Avatar
Turbo 3.5
yeah the coils have 3 wire 12v, ground and a signal wire from the crank sensor
you'll have to crank the car to check the crank wire
Old Feb 15, 2012 | 05:38 PM
  #169
t6378tp's Avatar
Turbo 3.5
btw the voltage from the signal wire should pulse
Old Feb 15, 2012 | 09:46 PM
  #170
Crusher103's Avatar
ok this is going to get complicated as i have never had to check for voltage before so if you guys dont mind could you walk me through it i can see this getting complicated.
Old Feb 16, 2012 | 07:25 AM
  #171
NSMO240's Avatar
you have a wiring diagram? or know how to read one? im sure someone will chime in with what color wires to test but if not your gonna need one, or access to alldata to find out which one has constant 12v power with the key on and the signal which i belive only gets 5v, but i maybe corrected on that statement.
On the coils, one will be ground, one will have 12v constant with the key, on and one will pulse to like i said the 5v, or 12v whichever it is, when cranking, or the engine is running.
As for checking the actual harness to all the coils, i would have to read on some stuff to let you know there.
take a small needle or pin and instert it into the back of the plug where the wires enter the coil, and hook up a DVOM, hook the black lead on the DVOM to ground and the red side to the pin, turn the key on, and check for readings.
If you get no reading, move to the next wire, if you dont get any readings either your not getting power to anything, or you dont have a good connection to that wire.
Old Feb 16, 2012 | 07:31 AM
  #172
cardana24's Avatar
Blown
I did not read though the whole thread again, but just wanted to throw this out there. How are your fuel lines run? It's easy to get them backwards.
Old Feb 16, 2012 | 07:45 AM
  #173
NSMO240's Avatar
he said its been running for a while but when he moved the vehicle around to reposition it in the garage, it died and now wont restart
Old Feb 16, 2012 | 09:47 AM
  #174
t6378tp's Avatar
Turbo 3.5
Like stated above there is only three wires. One should have 12v with the key, one ground and the ladt only while cranking or running. If your not getting 12v with the key check the ign switch, if your getting 12v but nothing from the signal wire while cranking then check the cps and harness. Last if the ground reads less than 12v check your grounds.
If everything is fine check your fuseable link in the harness and clutch switch on the pedal
Old Feb 16, 2012 | 09:56 AM
  #175
NSMO240's Avatar
If it cranks, wouldnt that rule out the clutch switch?
Old Feb 16, 2012 | 10:08 AM
  #176
t6378tp's Avatar
Turbo 3.5
Yeah that's why I said to check it last
Old Feb 16, 2012 | 10:09 AM
  #177
t6378tp's Avatar
Turbo 3.5
Plus encase it makes him remember something
Old Feb 20, 2012 | 01:56 PM
  #178
kzoosho's Avatar
Yea.
Sucks you are having issues dude. Im glad someone got use out of that manifold.
Old Feb 23, 2012 | 09:48 AM
  #179
Crusher103's Avatar
weather has not been on myside this past week(its 70 outside right now and 3 days ago there was snow on the ground.....go figure )
Ok i have a little over 12Vs with the key in, so im assuming thats spot on but i have .232v from the signal wire to be exact with the ignition off when i put the key in the on position it dips to .113v then when the car is cranking .09vs and it never fluctuates, so im assuming problem is the CPS. Harness is fine im certain so that leaves that actual sensor itself.
Question being how would i check the sensor for its voltage to be certain because i can pull on off another car the problem is, since i have a 3.5s oil pan it has to be modified to fit so i dont want to go shaving it and then find out, that is not the problem.
I know im more than ok with grounds, both heads are grounded, the transmission is grounded, the timing cover is grounded, the Intake manifold is grounded, the block has 3 grounds. i wanted to make sure that was never an issue.
Old Feb 24, 2012 | 06:09 PM
  #180
t6378tp's Avatar
Turbo 3.5
may off topic but why r u using a 3.5 oil pan thought you had a 3.0
You can switch your multimeter to ohms and check the resistance than compare it with the fsm for specs
  #181
t6378tp's Avatar
Turbo 3.5
The cps sensor
Old Feb 24, 2012 | 07:50 PM
  #182
Crusher103's Avatar
Its from my botched 3.5 swap, the VQ30 im using when i got it had no oil pan, no valve covers, no timing or its covers, cams, intake manifold, it had been molested in favor of another 3.5. So i just pulled everything off the 3.5 and slapped it on the 3.0, its why my 3.0 revup cams and an SSIM on it. Temporary solution turned permanent.
The cps sensor
as in cam position sensor?
Old Feb 25, 2012 | 12:26 AM
  #183
HomerMAC's Avatar
Donating i30 Owner
do you have the FSM for your car? this way we can reference page #s etc.
Old Feb 25, 2012 | 07:21 AM
  #184
Crusher103's Avatar
yep, cant do anything with out the FSM
Old Feb 25, 2012 | 10:18 AM
  #185
t6378tp's Avatar
Turbo 3.5
sorry meant crank
Old Feb 26, 2012 | 10:53 AM
  #186
Crusher103's Avatar
sorry meant crank
imma swap em both today and see what happens anyway.
Old Feb 26, 2012 | 01:39 PM
  #187
Crusher103's Avatar
Still nothing, changed both the crank and cam position sensors and it still will not start.
Old Feb 26, 2012 | 02:53 PM
  #188
Kevlo911's Avatar
Kevlo for President
you change da ecu's?
Old Feb 26, 2012 | 02:55 PM
  #189
Crusher103's Avatar
i knew i was forgetting something...
Old Feb 26, 2012 | 03:00 PM
  #190
Crusher103's Avatar
I would go back out there but i have already started drinking.....it cant end well.
Old Feb 26, 2012 | 05:05 PM
  #191
t6378tp's Avatar
Turbo 3.5
Lol
Old Feb 26, 2012 | 06:35 PM
  #192
Kevlo911's Avatar
Kevlo for President
sounds like da same problems when you work on it sober
Old Feb 26, 2012 | 06:37 PM
  #193
Crusher103's Avatar
most likely....
Old Feb 27, 2012 | 09:59 AM
  #194
Crusher103's Avatar
bad news and even worse news.
Tried my other ECU, nothing changed. The worst news is my key broke off in the trunk.
Old Feb 27, 2012 | 10:44 AM
  #195
t6378tp's Avatar
Turbo 3.5
If you was sober I'd try drinking before making another attempt at the car, lol
Old Feb 27, 2012 | 07:08 PM
  #196
Crusher103's Avatar
ok any other suggestions, at this point im considering parting this thing out and selling the shell if i cant find the problem.
Old Feb 27, 2012 | 08:19 PM
  #197
maxgtr2000's Avatar
KH3 by popular demand
The cps on the front of the motor should measure anywhere from 470-570 ohms. On the pos sensor by the starter unbolt it but leave the harness plugged in. With the key on, stick the voltmeter leads in the back of the jack so you can get voltage from the wires with the harness still plugged into the sensor, touch the tip of the sensor with a screwdriver, it should read 5 volts, slowly pull the screwdriver away, the voltage should remain at 5 volts.
Old Mar 6, 2012 | 01:39 PM
  #198
Crusher103's Avatar
Question, if i get consult, will i be able to just plug it up and figure out what is going on, this is obviously an electrical problem, i just went through the FSM ignition signal BS still cannot find the problem, voltage on the CKPS checked out, its harness is fine, changed the ignition condensor, and it wont start. Im very close to just scraping the whole project and getting another car.
Old Mar 6, 2012 | 03:04 PM
  #199
t6378tp's Avatar
Turbo 3.5
for ***** and jiggles you ever check inj switch
Old Mar 6, 2012 | 03:06 PM
  #200
Crusher103's Avatar
i have replaced that stupid thing before, not long ago either. i'll could give it a shot.
