Another Almost Boosted 3.0
Old Mar 14, 2012 | 07:16 PM
  #201
Flava_24/7's Avatar
Boosted Panda
Any luck?
Old Mar 14, 2012 | 09:46 PM
  #202
Crusher103's Avatar
Nope i have been **** out of luck. i have to test everything for continuity now.
Old Mar 26, 2012 | 02:28 PM
  #203
Crusher103's Avatar
OK just going to compile everything i have done to try and find this problem:
Tested all 6 cylinders for spark-No spark.
changed the crank position sensor&harness
changed the cam position sensor
tested CKPS for continuity.
ECCS fuse-Good
ECU i have 2 of them both good.
The car just turns over and doesnt make an attempt to start.
Old Mar 26, 2012 | 02:35 PM
  #204
t6378tp's Avatar
Turbo 3.5
Ign switch, clutch switch, ecu, ecc fuse, alarm
Old Mar 26, 2012 | 02:44 PM
  #205
Crusher103's Avatar
thanks for the reminded me, ECU and ecc fuse. Checked those they are good. clutch switch is fine because the car is turning over with out problem but it will not turn on. Ignition switch is about 4 years old. And i have not been driving this car everyday for the bast 3 years pretty much i havent driven it so for it to go bad, possible but very unlikely.
Old Mar 26, 2012 | 02:56 PM
  #206
Kevlo911's Avatar
Kevlo for President
does it start if you spray starter fluid in the IM?
Old Mar 26, 2012 | 03:19 PM
  #207
Crusher103's Avatar
I have not tried that. I will go get some and try.
Old Mar 26, 2012 | 04:17 PM
  #208
t6378tp's Avatar
Turbo 3.5
electronics can go bad at any time
Old Mar 26, 2012 | 04:18 PM
  #209
t6378tp's Avatar
Turbo 3.5
At this point I would check everything
Old Mar 26, 2012 | 04:20 PM
  #210
chrome91's Avatar
is your ignition timing correct?
Old Mar 26, 2012 | 05:07 PM
  #211
Crusher103's Avatar
True. I havent checked the emanage settings but maybe it reset itself.
I have been using the FSM, using the ignition signal diagnoses(EC 122), i have done just about everything on that list. The only sensor i haven't touched so far is the crank ref sensor. But iirc if thats bad it wont stop the car from starting.
Its on stock timing, 4th gens have coilpacks there is no distributor.
Old Mar 26, 2012 | 05:29 PM
  #212
Kevlo911's Avatar
Kevlo for President
crank ref will keep the car from starting
Old Mar 26, 2012 | 05:33 PM
  #213
Crusher103's Avatar
Cool. Replacing that tomorrow.
Jesus christ i hope that is the problem.
Old Mar 26, 2012 | 06:33 PM
  #214
Kevlo911's Avatar
Kevlo for President
did you try the starter fluid?
Old Mar 26, 2012 | 07:22 PM
  #215
maxima2fst4u's Avatar
man i hope u get it up and going after all that hard *** work u done..wish u the best of luck im having issues to mine aswell but not as dramatic as urs
Old Mar 27, 2012 | 04:17 PM
  #216
Crusher103's Avatar
^No luck. Replaced the crank ref. No luck there either.
The car might end up at the shop from the way things are looking right now. Something i didnt want to do but im too confused.
Old Mar 27, 2012 | 04:54 PM
  #217
Kevlo911's Avatar
Kevlo for President
time to burn it
Old Mar 27, 2012 | 05:00 PM
  #218
t6378tp's Avatar
Turbo 3.5
time to burn it
depends on how much its insured for
Old Mar 27, 2012 | 05:19 PM
  #219
Crusher103's Avatar
Oh that car is on full comprehensive, I got the gas somebody get me the matches.
Old Apr 11, 2012 | 03:37 PM
  #220
vipervadim's Avatar
I like Maximas
matches?? i don't think so, but if you really want to..
i think i found your problem, not sure why nobody else noticed it (how many people actually build vq's here?)
you're using a 3.5L upper oil pan, but you're still using a 3.0L crank sensor (by the flywheel)
the 3.0L crank sensor is too short and does not read the teeth on the 3.0L flywheel very good. you had luck starting the car the first time..
you can shave the 3.5L oil pan where the bolt for the crank sensor is, but WHY grind at all?? you're only going to mess it up and make the pan uneven and eventually rust in the area..
instead -- use a 3.5L crank sensor + 3.5L crank sensor harness and splice it into the stock 3.0L crank harness
there's only 3 wires:
Black = GND,
White = Crank Signal,
Red = +12VDC
no need for any grinding, sensor bolts right in the hole, and it works perfectly as it should.
I first did this on my 3.5L swap back in '07 (donor engine was from a 4AT so no need to swap to 3.0L oil pan unlike the 3.5L 5ATs).. fast forward 5 years and a LOT of hard driving/racing, still works perfect to this day
try it, what have you really got to lose??
I was actually in Virginia by Silver Spring visiting relatives 3 weeks ago..
Old Apr 11, 2012 | 07:21 PM
  #221
Crusher103's Avatar
I knew that, and i did that a LONG time ago(Aluminum can rust btw?) The CKPS is not the issue. I did all the modifications to the oil pan and CKPS and it works. I did drive the car and i did for a long time on that 3.0 CKPS+3.5 oil pan without starting issues.
Just so you know the back story the car had been starting with out issue for the past couple of months. I had even driven it to the point i got well into boost.
So i figured cool time to wrap this project up turned the car on and drove it up my driveway to turn it around. Got to the end of my driveway and the car stalled. And from that time the car has not restarted from that stall. The problem seems to be the coilpacks are not getting signal but all my sensors from what i have tested are working.
Old Apr 11, 2012 | 08:15 PM
  #222
streetzlegend's Avatar
This **** still not running?
Have you tried to bypass the Emanage? I have seen an emanage die for no reason, Actually Jime sent me an emanage once that was completely dead, and I tested another Eu that soemone else had issues with, Dead, no start.
Old Apr 11, 2012 | 08:31 PM
  #223
Crusher103's Avatar
With those injectors i have never been able to get the car to start without the emanage.I have pulled the emanage and its pnp harness to test it for continuity. So if there is away i can check to see if the emanage has malfunction, because the lights still power up and im still able to go through the E-01 and adjust its setting.
Old Apr 12, 2012 | 01:21 PM
  #224
Unklejoe's Avatar
FWIW, I've had an E-Manage blow on me out of no where.
I was driving and the car just died and would not start. I could still connect to the EU via USB, indicating that it powered on. It would just not run the car.
I bypassed it and the car ran fine.
I ended up replacing it and Ive been running the new E-Manage for over a year now.
Old Apr 12, 2012 | 03:21 PM
  #225
Kevlo911's Avatar
Kevlo for President
Check the injector ground on the EU, mine came loose once
Old Apr 12, 2012 | 03:42 PM
  #226
Crusher103's Avatar
that would explain a lot if it was the Emanage.
Old Apr 12, 2012 | 10:10 PM
  #227
Try finding some stock injectors or dek injectors, something to try to start the car without EU, or with ur current injectors, lower the pressure as much as you could, bypass EU and try to start. The bad EU i tested once, I was able to hook up to it via USB, everything looked fine, but was dead.
Old Apr 15, 2012 | 04:55 PM
  #228
Crusher103's Avatar
pulling those injectors back out will be painful, one thing i will do is test for spark with the emanage disconnected. If i get spark then im going to be damn sure it was the cause of the problem.
Old Apr 16, 2012 | 08:09 AM
  #229
Product_Of_Korea's Avatar
I have a few suggestions.
I know you said earlier that you went over the grounds in depth, but have you checked out the 2 grounds that use to go to the 4th gen lower intake manifold. If those are not hooked up or have a good solid ground that will prevent a spark.
And also when the key is in the ''on'' position does your CEL light come on? Although this is usually associated with a bad ecu it would also indicate a bad electrical issue(which you obviously have came to that conclusion) But its somewhat of a step into the right direction
Good luck
Old Apr 16, 2012 | 06:13 PM
  #230
do it!
Old Apr 24, 2012 | 03:21 PM
  #231
Crusher103's Avatar
ok mystery solved, it was the emanage. After doing some searching i found this and the car got spark after the emanage was disconnected:
http://www.lexusownersclub.co.uk/for...howtopic=19825
Old Apr 24, 2012 | 04:09 PM
  #232
Kevlo911's Avatar
Kevlo for President
Old Apr 24, 2012 | 04:27 PM
  #233
Crusher103's Avatar
Your ing??? I was damn near in tears when i replaced the cam ref sensor and the car STILL didnt start. I thought the Gods had turned their back on me.
Old Apr 24, 2012 | 05:27 PM
  #234
t6378tp's Avatar
Turbo 3.5
glad to hear
Old Apr 24, 2012 | 06:10 PM
  #235
Unklejoe's Avatar
good deal man.
ps i love the language they use on that forum ...
"check the voltage settings for the sparkies..."
"the problem is we cant find the problem..."
"any advices? how to fix this problem..."
Old May 4, 2012 | 01:13 PM
  #236
t6378tp's Avatar
Turbo 3.5
update
Old May 4, 2012 | 05:37 PM
  #237
Crusher103's Avatar
Another Emanage has been bought should be here either tomorrow on on Sunday. Now i know i cant use the ignition adjustment. Just leave that **** alone.
Old May 7, 2012 | 09:56 AM
  #238
Crusher103's Avatar
ugh back to the drawing board. This is becoming one of those situations where its not worth it to contunie. Here is a video, new emanage, new coilpacks, all new sensors(Cam/Crank pos&ref). And here is what happens when i try to start the car:
Old May 7, 2012 | 05:59 PM
  #239
maxgtr2000's Avatar
KH3 by popular demand
Either your battery voltage is low or that starter sounds a little slow...
Old May 7, 2012 | 06:35 PM
  #240
t6378tp's Avatar
Turbo 3.5
+1 on a low battery
