2k2 maxima boost issues
Old Oct 9, 2014 | 09:41 AM
  #41
Douglas Tvrdik's Avatar
What should the gap be and I pulled my waste gate spring out and it's a 7pound spring so I moved the vacume hose to the intake manifold instead of the turbo and now it is way more consistent gunna try messin with the tune this weekend to see if it helps any.
And my base boost level went from 4 to 6 psi
Old Oct 9, 2014 | 05:27 PM
  #42
t6378tp's Avatar
Turbo 3.5
at that boost level .032 should be fine
Old Oct 9, 2014 | 05:31 PM
  #43
Well I'm shooting for higher boost in the 15 range so I can get to hp I'm shooting for
Old Oct 10, 2014 | 09:46 AM
  #44
CMax03's Avatar
Originally Posted by Douglas Tvrdik
ok it helped a little bit down low rpm ut it still wont really pull on the top end and once you hit 10pounds it just wont do much at all it actualy feels slower. could my intercooler piping be too small its 2in on pre intercooler then goes to 2.5 then to 3
I thought 2.25"-2.5" was ideal and should be used throughout the intercooling plumbing....Your intake can be 3"-4.5", but the changing of your piping size could be affecting the pressure entering the engine. You need to weld in or plumb in some tubing with pressure bungs made in so you can monitor actual pressure entering and leaving your intercooler! Then you can definitley know want you pressure drop is! Also sounds like an air leak in your engine or air system...Check your turbo bearigs for wear as well.
Old Oct 11, 2014 | 06:19 PM
  #45
I'm not having any problems with boost Its just not making more power with more boost is all
Old Oct 11, 2014 | 11:50 PM
  #46
WTF?'s Avatar
I tune a descent amount of LSx boosted cars. If the AFR's are clean, and the boost is there, then it's a timing issue. Does the car seem to run hot? Do you have water injection? How are you pulling timing? Is it rpm based, MAP based, just a guess at something someone told you? Who is tuning it, and how? Street tune? Dyno? If you are looking for 15 plus lbs, and you haven't got a water kit on it, then your tuner is really lacking in the experience department.
I would put the stock timing back into the car, lower the boost, and make some pulls. Get on ebay and order a coolingmist water kit for 200 bucks. HOOK IT UP. Set the hobbs switch for around 4psi, and spray Zero degree windshield washer fluid before the throttle body, after the Mass Air, and put the AIT sensor between the nozzle and the throttle body, make sure that the AIT sensor sees the water. That will keep the engine in "good" part of the ignition map. Now, hopefully you have a boost controller, and you can click a lb or two at a time, and make smart decisions based on the findings. I would imagine that with 1 M10 meth nozzle you can run a descent amount of boost on that thing before any timing pull is needed.
Get some answers on the tuning process, and we can probably help you a lot better. Good Luck.
ah2002
Mar 9, 2016 01:42 PM
Finkle
Sep 27, 2015 09:53 PM
stromm
Aug 27, 2015 04:13 PM
cheftoo
Aug 20, 2015 05:17 AM
acw
Aug 13, 2015 12:50 AM
