? for peeps w/20's
Old 11-28-2003 | 07:02 PM
C3nthusiast's Avatar
? for peeps w/20's
I have 19 X 8.5 in the front and 19 X 9.5's in the rear. I had to bend my fender up a little to accomodate the wider wheel. I want to step up to 20's but I'm not sure if I should get 9.5's or 8.5's for the rear this time. I have Intrax springs and would like some feed back from peeps w/ 20's and Intrax/sprint springs. What problems have you had and what tire size do you use. The last 4th gen I saw w/20's was running something like 245/35-20 and it looked like a 4X4.
Old 11-28-2003 | 08:43 PM
limsandy's Avatar
Hey, I'm really against 20 x 9.5 because it's gonna rub like crazy. I have a 5th gen which supposedly have bigger fender well than 4th gen, and I plan to use 225/35/20 in the front and 245/35/20 at the back. The reason is that I am also planning to go lower with Teins. But if you have rolled your fender in the past, I'm not sure how it'll fit now. Good luck.
PS: Here is a discussion about 20's on Maxima .
~limsandy
Old 11-29-2003 | 02:08 AM
foetray's Avatar
I run a 245/25/20 but that was the smallest they made at the time. Now Nitto makes a 225/35/20 in the NT555 and they look much better and should provide better fitment for lowered cars. $900 at www.tires.com
mclasser
22
11-12-2020 02:58 PM
_DRU_
04-22-2001 03:34 PM
krmaxima
62
04-11-2001 11:10 AM
nodoubt711
12-14-2000 07:17 PM
