Can I plus size tire to 225/60/15 on 97 Maxima
Old Dec 9, 2005 | 08:03 AM
maxsthebest's Avatar
I am currently running 215/60/15 tires on my 97 Maxima and was thinking of going 225/60/15 (slightly wider tire). Will there be any issues with this setup?
Old Dec 9, 2005 | 08:06 AM
buttonhook's Avatar
go to a 225/55/15
Old Dec 9, 2005 | 08:11 AM
Poowill's Avatar
You're already running up a size from stock correct? Stock being 205/65/15.
Might try posting in Wheel/Tire forum though.
Old Dec 9, 2005 | 08:45 AM
hectorc's Avatar
Upper Midwest Wheel Whore
You can run that setup. It will be fine, I have to double check, but those numbers sound like the tires I have on.
Old Dec 9, 2005 | 09:09 AM
MaximaSE96's Avatar
Maxima Owner
OEM Size -215/60-15 215/55-16 depending year/trim
recomended plus sizes
235/45-17
235/40-18
245/35-19
the biggest thing to consider is overall diamter of tire so u want to make the proper adj. ments in aspect ratio according to width
so if u want to run a 225 tire on 15s i would 225/50/15s
now i run 225/50/16s for auto-x but thats totaly diff story...i am bumping up 235/45/16 for auto-x days....regualr driving i use 235/45/17
Old Dec 9, 2005 | 09:15 AM
the_3d_man's Avatar
stock is 205/65/15.
225/60/15 has the closest overall diameter if you just want to increase tire width.
Old Dec 9, 2005 | 10:24 AM
ManualMaxima's Avatar
5th Gen till she dies!
i had these hwne i first got my car, grandma tires
Old Dec 19, 2005 | 09:19 PM
Donald199's Avatar
If i go with 225/55/15 on stock rims and stock suspension would it look too retarded?(too small of a wheel/tire on a sedan, more like too skinny) because i am considering some tires that only comes with 225/55/15 being closest to stock sizes BTW it is a 96 SE with sawblades
I am also considering 225/50/15
Old Dec 20, 2005 | 04:31 PM
z32drifter's Avatar
I ran 225/60/15 on my sawblades no problems. They are a little fat for the wheel, but I had no issues with the setup.
ah2002
Mar 9, 2016 01:42 PM
MplsMadMan
Sep 4, 2015 02:23 PM
District
Aug 15, 2015 08:23 PM
Max8
Aug 15, 2015 07:06 AM
follyburr
Aug 12, 2015 08:57 PM
