85 Max won't start
HELP!!! I went to leave for work this morning, and my car won't start. It just cranks over, but does not fire. I have had a simular problem before. When this happened before I thought it had to do with weather conditions. Symptoms are the same, but normally only happened when it was raining out. Of course, I was always able to get it running before. If anyone has any thoughts, ideas, or suggestions, it would be appreciated.
Thanks!
Chad
Thanks!
Chad
Originally posted by JoshDonelson
Chad,
I had a similar problem with my '87...it was one of the ignition coils...it has 2 youll just need to figure out which one...
-Josh
Chad,
-Josh
Thanks for responding... I had done some diagnosing, and discovered that there was no spark. I contacted checker auto parts store to get a new coil. The neglected to tell me the coil came in two pieces. They only gave me the main coil, and did not suggest replacing the "power module". I found the power module in the chilton's manual. I contacted checker to get the part. The did not have it in stock, and it was fairly expensive. I contacted a local Nissan dealer that I trust, and they told me that they only sell the part as one unit. As it turns out, they said that normally if the coil goes out, it ruins the power module. I purchased the coil assembly from Nissan for $121, it was well worth the money... The car is running good now!
Thanks again!
Chad
hopefully ill get a respond to this im having trouble with starting my maxima its a 87 and the piece i got was just the black coil itself and not the metal bracket called the transistor where everything plugs into so if i change that will i get spakr because i already changed the cap rotar wires and plugs hopefully it works write back tom
![Stick Out Tongue](https://maxima.org/forums/images/smilies/tongue.gif)
It sounds like you had the same issue I did. I purchased the new coil from an auto parts store. I would contact your local Nissan Dealer, when they sell you the coil, it includes the power module. From what I understand, nine times out of ten, it is actually the power module that goes. I returned the coil I purchased from the auto parts store, and went to the Nissan dealer. The car started right up after that. I hope that works for you! My maxima is gone, the transmission when bye, bye!
Chad
Hey chad this is tom thanks for the quick feedback im only 16 and dieing to get this car started read my story about the car its on this page its called 87 nissan maxima no one replied to it ok thanks tom and i already have the black coil not the transistor.
I also had to change the timing belt in my maxima. As we pulled the old belt off, the cam shafts spunn around. We ended up having to get a manual to reposition the cam shafts. The marks on the timing belt
have to line up with the marks on the sprockets. Did you replace the timing belt tensioner?
Chad
how much does it cost????
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Feel free to e-mail me directly if you want.
Chad
why did you read my story about the car?? do you think i should replace the tensioner i already have the manual i just wanted to know the ignition coil price but thanx so how is your car???and what do you think about mine is it fixable it has 184,000
the timing belt didnt snap it just was missing teeth so the engine might be fine and if it runs ill change everything so how is this car on acceleration and my power steering is shot how much will it cost to fix
horse power than the 85. Mine had 160hp, with and automatic. The
cost to replace the powerstearing will very. Do you know if it is just the pump, or if the powerstearing rack went out. The rack started leaking in mine, a new one would have cost over 1000, and then about 800 to install. I contacted the local Goodyear shop and they were going to find a used one for me. It stopped leaking so I did not have to replace it.
its tommy chad write back
I now drive a 92 Eddie Bauer Explorer. Unfortunatley I do not have any parts for the maxima, the only thing I have is a repair manual. Not sure why I kept that. Oh, by the way, I live in MN.
o i live in rhode island little state lol damn you went from good nissan to ford geez
i hear yah i hope when i get the ignition coil she starts then i can get her going from sitten for about a year or more now
kjlouis
11-24-2018 06:09 AM
BobMax
08-15-2015 12:35 PM
