who still has there 2nd gen
Old May 15, 2015 | 02:56 PM
  #521
CMax03's Avatar
Originally Posted by vernk
after a little more drop, did that when I put new struts in, and new kicks. Never mind the grease hand prints on front I need to give her a bath...
Those 2000 Altima SE wheels looks good...
Old May 15, 2015 | 07:12 PM
  #522
aw11power's Avatar
I gotta find some of those Altima wheels...or some SER wheels...
Old May 15, 2015 | 09:09 PM
  #523
vernk's Avatar
thanks they are 2000-2003 Sentra se-r/ 2000-2001 Altima
http://www.allfactorywheels.com/prod...FQwcaQodi7cAEA
they were on when I bought the car, but thinking of finding another set for my 200sx.....
Old May 26, 2015 | 04:04 PM
  #524
seabob4's Avatar
Next week will be PM week. Ordered Cardone right and left halfshafts, Raybestos ceramic pads front and rear, and a Gates timing belt and tensioner today. Rockauto, $210 shipped, have it all Friday. Advance Auto and AZ wanted almost $40 per set for the Raybestos pads!!
201,300 miles, she purrs like a well fed kitten, going to keep her that way...
Old Jun 2, 2015 | 12:04 PM
  #525
vernk's Avatar
be mindful of the half shafts and be sure they don't have a thing where the grease seal cover disk goes, the last couple I have gotten have had a thing there so you can't tighten the nut all the way down or it locks the wheel up, just figured out what it was, if they do and you can't take it off you will have to tighten the nut till it gets to the point that you can still rotate the hub. I have to pull mine apart again and see if I can take that off and put the OEM seal cover on.....
Old Jun 2, 2015 | 12:24 PM
  #526
vernk's Avatar
How far would you trust your 2nd gen???
total stats:
5093.7 miles
178.37 gallons of fuel
28.56 mpg
$531.37 for fuel
1/2 quart of oil
1 oil change
1/2 a small bottle of power steering fluid
1 heal light lens, think I took a rock from a trailer carrying a ATV that they didn't sweep off the trailer before getting on the road, just has a pin hole on the outside but can see where it blew out the glass on the inside, so now I need to find a passenger side head light
Old Jun 6, 2015 | 04:16 AM
  #527
seabob4's Avatar
No issues on the half shaft swap, although that passenger side one is fun with that bearing carrier in the center of the car!! Put her up on ramps to get the clearance I needed underneath, removed the 3 carrier bolts, then jacked up the right side further to get the wheel off. Betcha they were the original axles, boots pretty torn up...but they still were in 1 piece!!
Interesting, my Haynes manual (not the best, but not bad) told me to drain the gear oil before doing the swap. $75 worth of Royal Purple, I was not in the mood to lose that chit, so stuck a pan under the tranny, and proceded onward. I MAYBE lost 1/8 of a cup of oil...
Old Jun 11, 2015 | 12:59 AM
  #528
vernk's Avatar
yea i'm running Red Line MT 90, and only had 20k on it, so I didn't drain it when I had to change my drivers side due to a rip in the boot when I got it from Rock Auto and I just patched it which worked for a while but then needed some duct tape and I didn't want to go on my trip with it like that....
yea those three bolts are kind of a pain, did you take the strut off or the ball joint?
Old Jun 11, 2015 | 04:25 AM
  #529
seabob4's Avatar
Removed the 3 carrier bolts first (while the wheel was still on), then jacked up the right side, pulled the wheel, removed the ball joint mount, the shaft pulled out pretty easily. New one slid in pretty easily as well.
The timing belt? What a PITA!!! Another Haynes F up. They say to remove the inner splash panels in the fender well (should gain you some access). Guess what Haynes...there ARE no panels on the right side, it's all metal!! Sure, there's one on the left side, but if you look at a Haynes manual, you have to figure, based on their pics, that they did the timing belt with the motor pulled...so they just assumed there are panels on the right side. Oh well, I've got plenty of time, just taking my time. WP and stat housing off, surfaces cleaned up, new WP, new stat, new serpentine belt will go in. But timing (new belt) is today's objective. Hope to get it right...the first time!
Old Jun 11, 2015 | 12:32 PM
  #530
seabob4's Avatar
New timing belt (Gates) went on, tightened the tensioner down, went through two revs of the crankshaft...no resistance!! WOO HOO, my marks were good! Slapped the WP, stat and stat housing in (tossed the gaskets, blue RTV), will tighten up tomorrow, then put her back together.
So the old girl got new axles, new pads all the way around, new tires (205/60-15 Falkens), timing belt, serpentine belt (WP and PS), new WP, new stat, new NGKs. On to the next 100K miles!!!
Old Jun 17, 2015 | 11:48 AM
  #531
vernk's Avatar
why yes it is, but yea you should have a splash shield, at least mine has one, you might be missing it unless the metal covers the crank pulley there should be a cover that goes over that area and goes back with part of it going over the cv shaft.....
64838-16E00
http://www.nissanpartsdeal.com/parts...html?PNC=64836
that part, if you have nothing between your tire and crank you might want to see if you can find one......
but it does get a lot easier once you have figured out how to get in there the next time since you have way more of a idea where and how to get to the bolts for the timing belt cover and how to get the top part of the cover out and all the fun little things like that......
Old Jun 17, 2015 | 11:52 AM
  #532
vernk's Avatar
ummmmmmmm might want to not go for 100k more like 60k then timing belt time again...... but yea timing belts and oil changes and i'm sure 100k more isn't a big deal....
Old Jun 17, 2015 | 11:57 AM
  #533
vernk's Avatar
well made it back from my second trip which was
3140.6 miles
111.91 gallons of fuel
$413.12 in fuel
now at 227,157 miles on her
Old Jun 17, 2015 | 03:03 PM
  #534
seabob4's Avatar
Yes, basically what I meant, Vern. Obviously, the next timing belt is going to be a WHOLE lot easier than this one!!
Old Jun 17, 2015 | 04:08 PM
  #535
maximase86's Avatar
I love lamp.
I definitely do not miss doing timing belts. I still find myself fortunate that I lost the timing belt and didn't screw the motor up on my 2nd gen.....that was about 10 years ago now....
S
Old Jul 22, 2015 | 03:25 PM
  #536
Nismatic35's Avatar
I also brought my plenum cover back to life. A huge thanks to TransAmBandit for saving me hours by sandblasting it for me.
Old Jul 29, 2015 | 01:08 PM
  #537
vernk's Avatar
grrrrrrr wheel bearings, thought I could get away with just putting my other set of knuckles in, but the bearings in those are also bad, so thats going to be my Sat....
Old Aug 1, 2015 | 04:32 PM
  #538
delerium75's Avatar
I've been busy digging into the guts of my car. I've had a noise associated with the drive belts and for sure one idler pulley bearing is bad and the A/C pulley has a little bit of play.
In the process of fine tuning the idle, I believe the fast idle control solenoid is bad...with the correct warm idle set, turning on the A/C almost stalls the car, regardless of how much or little the adjuster screw is turned so I think I've discovered why it was high to begin with.
I still need to make a successful attempt at changing out the heater core (bypass elbow installed and not driven in winter) but I'm still trying to find a suitable offset screw driver to reach the screws on the side of the dash. Having just been laid off for a second time in 3 years, I guess I have a bit of time to hopefully get this car trustworthy.
Old Aug 2, 2015 | 01:58 PM
  #539
seabob4's Avatar
Are those the 2 screws on the driver's side? I assume you've pulled the door trim off. If that doesn't allow a decent shot with a "normal" screwdriver, take a short phillips head bit, grind it WAY down so it's a real stubby, then use a needle nose vise grips to grab it tight and just start turning. I just looked at mine, and that is DEFINITELY doable...
Old Aug 2, 2015 | 03:54 PM
  #540
delerium75's Avatar
Hell yeah!!!! There's two screws on either side and it's the passenger side where they were a bit more buried than the drivers side. Thanks for the tip...I definitely do think that's doable!!
Old Aug 3, 2015 | 07:07 AM
  #541
seabob4's Avatar
delerium, you want to grind down the shank of the bit a LOT. As the screw backs out, it's going cause the bit to move closer to the door frame, and could wedge it up against the frame to where you can't get the screw and bit out.
You also might want to consider taking a die grinder and grinding a couple "reliefs" in the frame where the screws are to allow more room...or maybe even a straight shot with a normal screwdriver...
Old Aug 23, 2015 | 06:52 PM
  #542
rbarnes's Avatar
Grandma and Grandpa's Maxima
It was bittersweet when I inherited my Grandparents maxima this past year. They paid cash for it and bought it brand new in 1987. My grandfather took such good care of this car. Every time he drove the car he would pop the hood and raise it to cool the engine to preserve the wiring harness etc... My grandfather has since passed on and my grandmother quit really driving about four years ago. My mother let me get the car this past December and I have been fixing the little things Power steering pump was raising hell and I quieted that up with transx. I had the front rotors turned I scuffed the back rotors and I put ceramic pads on the brake calipers. I bought a new set of Michelins from Costco for it and I have been driving it to work. I got my old landlord to pull a vacuum and charge the ac system. He changed it to 134 without having to change fittings etc... and only charged me 75 bucks. The interior is spotless. I need to fix the passenger side mirror and it is time for a new timing belt.
I have changed the belt on a Toyota corolla but never on a maxima. I could use some advice/tips when I tackle this job.
Old Aug 25, 2015 | 12:20 PM
  #543
vernk's Avatar
biggest thing in changing the timing belt is going to be having the right tools to get to the bolts on the timing belt cover, there are a couple that you can't really see, a 1/4 ratchet with deep well or short extension comes in handy for those, you should do the water pump while you are in there.
if you have a impact wrench that will come in handy for the crank bolt or a 1/2 breaker bar which you will more then likely will have to put it on the bolt wire up so it stays then "bump" motor over with the starter to get it loose, be sure to pull the coil wire so engine doesn't start.... then a dead blow hammer to tap on the crank pulley helps sometimes it take a bit of time to work that off with a little prying and tapping......
it's easy just kinda a pain due to the lack of room in front of the motor, if you get a decent belt it should have marks to line up on the sprockets marks so makes timing super easy.
be sure to put the guide plate on the right way when you put it back together, and loosen water pump pulley bolts before taking belt off which a ratchet wrench is useful (10mm)
give yourself lots of time....
Old Aug 27, 2015 | 07:44 PM
  #544
rbarnes's Avatar
Thanks for the info VernK
Thanks for the info VernK. I do have an impact wrench and I will replace the water pump when I do the job. I buy lots of parts at autozone and some things from oreillys but I think I was thinking I should buy the timing belt from Nissan. What do you think? Thanks for all your help.
Old Aug 27, 2015 | 08:11 PM
  #545
rbarnes's Avatar
Strut question
VernK how did you lower your car? Was it just the struts and if so where can I find them? I really like the stance of your car and the rims are perfect.
Old Aug 28, 2015 | 11:31 AM
  #546
vernk's Avatar
the timing belt doesn't need to come from Nissan but if you do some price checking Nissan might be the best price, keep in mind there are two timing belts one with square teeth and one with round, I think you should have square but not for sure, but should get the right one with year make and model...... I think the last time I did mine I got it from rock auto as a kit with the water pump.
For my coilovers I built them with parts from ebay.....
https://maxima.org/forums/1st-2nd-ge...attention.html
https://maxima.org/forums/1st-2nd-ge...pension-3.html
just be sure to watch spring rates, I have 500lbs which a lot of people will find a bit stiff, and you will want a kit with shorter front sleeves I had to cut mine down.
Old Sep 4, 2015 | 02:45 PM
  #547
vernk's Avatar
Heads up, front hub parts are on closeout on Rock Auto, I just got new bearings and hubs, seals all Timken seals and bearing for $101.04 shipped, be sure to cross check part numbers and all.....
Old Sep 13, 2015 | 09:47 AM
  #548
Evareut's Avatar
1984 Datsun Nissan Maxima with 77,000 miles for sale
I have my grandpa's old 1984 Datsun Nissan Maxima and I'm looking to sell.
It only has 77,000 miles on it and is in great condition.
It's navy blue with blue interior.
I'm located in the SF Bay Area, California.
Please email me at eva.l.reut@gmail.com if you are interested in it.
Thank you!
Old Sep 15, 2015 | 02:00 PM
  #549
vernk's Avatar
I made coil overs from ebay parts, info is in the "need new suspension" sticky
Old Sep 15, 2015 | 07:08 PM
  #550
Blkkn8's Avatar
I've got a 2nd generation maxima
I still have my 2nd gen
Old Oct 20, 2015 | 10:50 AM
  #551
vernk's Avatar
well I wore out a key, started not unlocking the drivers door, still worked in passenger door, I thought the lock cylinder had something wrong with it till I grabbed my extra key that is hardly used and compared them, and that one works fine so guess I should go have another key made.
Old Dec 15, 2015 | 07:39 PM
  #552
vernk's Avatar
you know the feeling when your 2nd gen puts a GTR in the rear view mirror
Old Dec 19, 2015 | 07:20 PM
  #553
CDD's Avatar
CDD
To anyone on this forum.
Yes I still have my 88 Se 5 speed with 384000 miles. A slight valve slap on startup but just will not die. One of the best cars I have ever had as far as dependability.
I have had this serviced continually for the past... well since 1993 with one clutch cylinder replacement when we thought the clutch went out so replaced the clutch at the same time. Belt always replaced with water pump at same time, etc etc etc Car currently plated insured but sitting in Kanab Ut. If any one interested call Doug 435-689-0254 before I just decide to do a classic motorsport rehab in 2016.
Old Dec 19, 2015 | 07:26 PM
  #554
CDD's Avatar
CDD
Mines at 384000
Old Jul 3, 2016 | 09:04 AM
  #555
majorpayne's Avatar
2 Genaration still on the road
Yes yes my 1987 maxima still on the road honking at the newer generation cars on the road just passing 133,000, RIDE TILL THE END. Thanks Majorpayne
Old Jul 3, 2016 | 09:12 AM
  #556
majorpayne's Avatar
Nice ill need that job soon,will try to attch photos next log-on thx majorpayne
Old Jul 3, 2016 | 09:41 AM
  #557
majorpayne's Avatar
Still on the road!
Hello i got it from grandpa ill keep it well maitained as he did till the wheels fall off right right. Thanks majorpayne
Old Jul 9, 2016 | 08:30 AM
  #558
majorpayne's Avatar
Wow
Old Sep 6, 2016 | 11:29 PM
  #559
1988's Avatar
I actually got mine yesterday, and I'm in love with it. It belonged to an old lady since new (1988) And it's pretty much mint- a few scratches, but everything works.
I wish I could get the problem with the alarm figured out... It's giving me a headache. I'll set the system, and the immobilizer will work, but the alarm doesn't go off.
Old Sep 7, 2016 | 03:16 PM
  #560
vernk's Avatar
does your horn work? thats where I would start, if that works start check wiring like see if it is sending the signal out of the control box in the trunk, not sure what wire it would be, but if you can get your self a FSM it should be able to tell you, not sure if the pins would be different though out the years but will also depend if you have keyless and such things as that.
