RWD 2nd gen Maxima..
Old Feb 5, 2011 | 05:11 PM
  #41
Big_E-Dog's Avatar
2nd Gen Boostinator
engine and tranny
Old Feb 5, 2011 | 11:35 PM
  #42
Hectic's Avatar
Turbo z?
Old Feb 6, 2011 | 09:53 AM
  #43
chrome91's Avatar
yep that looks like its out of a Z31 turbo
Old Feb 6, 2011 | 10:19 AM
  #44
Big_E-Dog's Avatar
2nd Gen Boostinator
yep 88 z31 turbo
its got the lil t25 turbo on it, thats ok though, i got a t3 and after it gets smogged and CaRB approved then ima ust the 2 turbos together as a sequential setup.
gonna be killer!!!
Old Feb 6, 2011 | 08:54 PM
  #45
CMax03's Avatar
Use 2 T3's not the T25, the T25 is too restrictive @ higher flow rates so no matter which way you connect it......in the front or the in rear!!!!
Old Feb 6, 2011 | 09:45 PM
  #46
keepitclean's Avatar
keep up the good work.cant wait to see pics/video after its all done.
Old Feb 10, 2011 | 03:34 AM
  #47
Big_E-Dog's Avatar
2nd Gen Boostinator
down time used to rebuild the engine it needed a head gasket,
check out my facebook
edward webster
Old Feb 19, 2011 | 02:56 AM
  #48
Big_E-Dog's Avatar
2nd Gen Boostinator
so now the engine is done partly, was welding the subframe brackets, ran outta wire, now its raining for 2 days straight, so no ground breaking progress, as of yet, just waiting on the weather.
Old Feb 19, 2011 | 05:15 PM
  #49
chrome91's Avatar
sweet
Old Feb 20, 2011 | 12:17 PM
  #50
Big_E-Dog's Avatar
2nd Gen Boostinator
ok just for the threads sake, more pics of the engine cleaning up process,
before
after
before
after
new valve stem seals some were shot to hell
bottom looks good
new water pump, head gaskets, manifold gaskets, valve stem gaskets, ready to go now.
Old Feb 20, 2011 | 12:23 PM
  #51
Big_E-Dog's Avatar
2nd Gen Boostinator
got the front subframe 91 240sx
had to drop the corolla on xrs springs since ima be rollin in it for a while, not too much though still gotta drive the parents and kids around, with a comfortable ride...
still wrking
Old Feb 20, 2011 | 08:14 PM
  #52
Big_E-Dog's Avatar
2nd Gen Boostinator
AS FAR AS IVE GOTTEN..
CUT OUT SUMMA THE REAR
NOT FINISHED BUT RELOCATIN BRACKETS IM WELDING IN
FRONT CROSSMEMBER BAR, DEFFINATELY GONNA GET REINFORCED, ALLREADY ONE BAR HOLDS 250 LBS
OTHER SIDE OF BAR WITH TABS MOCKED IN PLACE, WILL BE GUSSETED
GONNA DO MORE TOMORROW
Old Feb 21, 2011 | 06:33 PM
  #53
Big_E-Dog's Avatar
2nd Gen Boostinator
rear subframe is mounted, front crossmember is mounted as well, working on suspenson, and still gotta cut out the tunnel, gonna be a fun week.
pics soon
Old Feb 21, 2011 | 09:44 PM
  #54
chrome91's Avatar
hoooly crap lol
how long til its done?
Old Feb 22, 2011 | 12:56 PM
  #55
Big_E-Dog's Avatar
2nd Gen Boostinator
wait i got more pics.....
so the subframe i had a few problems, but an angle grinder fixed that.
subframe pics with the brackets welded in
so i loose fitted it and this is what i got
before maxed out
leveled out
maxed out in the other direction
got a 10" of travel, pretty good, heres the maxed out with the rims ill be running...
so now ride height is no problem!
custom springs ill be running, was running them before the rwd swap, theyre civic front coilover springs.
fitment with rotors and no spacers, pretty damn good if you ask me i got 1" spacers lying around here somewheres,
on to the front!!!
crossmember tabs welded in, crosmember mock bolted into place, with the complete setup itl all be high grade bolts/nuts ima get from the automotive store with plastic inserts
coupple of support gussets, gonna use these 2 new rails just to mount the crossmember, gonna mount the motor to the 2 large rails thats on the body
Old Feb 22, 2011 | 04:33 PM
  #56
Professor's Avatar
Cant wait to see the outcome of this project, keep up posted.
Old Feb 22, 2011 | 04:55 PM
  #57
gscars's Avatar
Damn, that rides coming together bro.i know it's gonna be clean bean
Old Feb 22, 2011 | 05:16 PM
  #58
CMax03's Avatar
Time for some DOT tubing and some .125" plate steel for adapting the crossmember to the existing unibody rails......I'll take a hand drawn picture of my Idea and post it.....you'll need a plasma cutter or Oxy-acetylene cutting torch......
Old Feb 23, 2011 | 03:05 AM
  #59
Big_E-Dog's Avatar
2nd Gen Boostinator
ill just stick to my angle grinder thank you very much, but do post your drawing, interested to see what you got, will take all suggestions/tips
Old Feb 23, 2011 | 09:18 PM
  #60
CMax03's Avatar
those nuts you're looking for with the plastic are called "nylon lock nuts" I'll working on that drawing for you still....I'll try to post it tomorrow ok!
Old Feb 24, 2011 | 03:12 AM
  #61
Big_E-Dog's Avatar
2nd Gen Boostinator
aight gonna cut out room for the tunnel tomorrow
Old Feb 24, 2011 | 06:00 PM
  #62
BenStoked's Avatar
Jesus was a Zombie.
zeeohmygodwhatthe****barbecuesauce.
this is why I don't visit this section. because big e-dog does stupid ****.
just kidding, that's f'in' sick. where will your madness end?
Old Feb 24, 2011 | 07:10 PM
  #63
chrome91's Avatar
it will end when he takes it to Japan and wins drift competitions
Old Feb 25, 2011 | 01:56 AM
  #64
a33_ridah's Avatar
simply amazed. where in sd area are you? im in north county.
Old Feb 25, 2011 | 03:41 AM
  #65
Big_E-Dog's Avatar
2nd Gen Boostinator
down in lemon grove
well i just started cutting for room to the tranny tunnel and hit a minor speed bump!
$HIT!!!
ill post pics of it tomorrow, might have to do some bracing
as for going to japan.......not too ar in the stretch of my imagination
Old Feb 25, 2011 | 06:47 AM
  #66
CMax03's Avatar
Here's my drawings, of your situation:
Old Feb 25, 2011 | 11:57 AM
  #67
Big_E-Dog's Avatar
2nd Gen Boostinator
ok i like that, plus i got some extra bar lyng around here anyways, ima do a quick sketch now....
applied....
red is steel and blue is welds
what you think?
Old Feb 25, 2011 | 12:44 PM
  #68
CMax03's Avatar
I would place reinforcement gusset/doublers on the inside & bottom frame rails to strenght the material your welding too.....to prevent cracking.....that bar doesn't need to be ran all the way to the front, it's gonna take up alot of room....
Old Feb 25, 2011 | 02:16 PM
  #69
Big_E-Dog's Avatar
2nd Gen Boostinator
well from looking at it, ill have a lot of room there, ill be mocking up the engine monday or sunday night.
Old Feb 25, 2011 | 03:23 PM
  #70
Big_E-Dog's Avatar
2nd Gen Boostinator
the speed bump...
but i got it out!!
Old Feb 25, 2011 | 03:44 PM
  #71
CMax03's Avatar
Can't even compare the FWD tunnel to a RWD tunnel......RWD as alot going thru it...FWD has the exhaust system and maybe a few lines.....I'll sent you a updated drawing that boxes that engine X-member to the frame rails......and an entire boxed in X-member system......
Old Feb 26, 2011 | 03:48 AM
  #72
Big_E-Dog's Avatar
2nd Gen Boostinator
well lickly all the lines in the maxima setup os off to the side, not too much to **** with except for the parking brakes, the exhaust will prolly be on th lower part of the tunnel but well see might have to go with oval pipes for clearance
Old Feb 26, 2011 | 07:03 AM
  #73
CMax03's Avatar
E-Dog.....I think if you boxed the crossmember adapter/framing into the frame rails you will have full strength in all axis vertically & horizontally.....The fully boxed fixture should be far more superior to the drivetrain's torsionally and tensionally forces....I'm not sure if you fitted the engine in the engine bay first, but I would to locate the engine @ it's most desireable position fore/aft and up & down and side to side....... Here's some more ideas regarding some boxed in designs:
Boxed with reinforced tabs.....
Boxed in with DOT tubing used as bushing for thru bolts
Or a completely boxed in X-Member from Rail to Rail
Old Feb 26, 2011 | 01:13 PM
  #74
Big_E-Dog's Avatar
2nd Gen Boostinator
depending n where i gotta mount the engine, i might use the last sketch to hold the engine and prolly teh first one for the crosmember
Old Feb 26, 2011 | 04:26 PM
  #75
CMax03's Avatar
That's a three piece design kinda like a door hinge with a large heavy duty thru bolt.......in the round section
Old Feb 28, 2011 | 04:13 PM
  #76
Big_E-Dog's Avatar
2nd Gen Boostinator
MOTOR MOUNT TIME!!!!!
more cutting needed!!!
Old Feb 28, 2011 | 07:11 PM
  #77
xX4DSCXx's Avatar
u are a crazy mo fo!!! i love it, keep up the good work!!
Old Feb 28, 2011 | 07:13 PM
  #78
chrome91's Avatar
Old Feb 28, 2011 | 07:31 PM
  #79
Buck96's Avatar
I hope you'll be putting down 600+ rwhp for all that trouble, good luck with the front steering rack & suspension geometry
Old Mar 1, 2011 | 05:15 AM
  #80
Big_E-Dog's Avatar
2nd Gen Boostinator
well now that i had to lift it into the body nore i can still use the stock fwd swaybar, control arms, suspension, since its the same engine i can stil ust the same springs with a few helpers as needed.
as for horsepower, well see how far i get, there is room in here for a vg30dett, hell even a vh45
