RWD 2nd gen Maxima..
Old Mar 2, 2011 | 04:02 PM
  #81
vernk's Avatar
love what you did with the timing belt cover.
Old Mar 5, 2011 | 01:05 PM
  #82
Big_E-Dog's Avatar
2nd Gen Boostinator
more pic and updates..
made motormounts...
when i pull out the motor ima beautify them
suspensin is done, had to cut off about 3 inches on each side and brace the left side due to it being soo close to the sway bar bolts, the right side i cut at the welds so no need to brace there.
more goodness to come
Old Mar 8, 2011 | 08:57 PM
  #83
CMax03's Avatar
I've been thinking of doing something like that but not exact, more of an inspection panel....
Old Mar 9, 2011 | 05:43 PM
  #84
vernk's Avatar
or maybe have these poking out
http://www.z31parts.com/engineparts.html
Old Mar 11, 2011 | 02:33 AM
  #85
Big_E-Dog's Avatar
2nd Gen Boostinator
started building my tunnel today, will post pics, latah!
Old Mar 11, 2011 | 04:59 PM
  #86
CMax03's Avatar
Yeah, I thought about buying these same cam sprockets to give me optimum adjustability since I'm running Isky cams, Customized Pacesetter headers, Custom JWT CAI, AFR, Mallory Ignition, etc...running cams with a slight bit of advance is like nite & day especially down low and thru midrange rpm.....at any throttle position.....
Old Mar 11, 2011 | 07:16 PM
  #87
chrome91's Avatar
^ how hard are cams to install? considering getting some JWT VG30E ones
Big E needs moar pics
Old Mar 11, 2011 | 08:51 PM
  #88
CMax03's Avatar
Easy as hell out of the car....you might have to remove the Xmember and exhaust and jack the engine upward to slide them in......no removeable cam bearing....
Old Mar 11, 2011 | 08:52 PM
  #89
chrome91's Avatar
out of the car as in the engine out right? is it worth it?
Old Mar 11, 2011 | 08:54 PM
  #90
CMax03's Avatar
Let me see if you can insert from the rear of the head.......
Old Mar 11, 2011 | 09:09 PM
  #91
CMax03's Avatar
No them can only slide from the sprocket/timing belt side.....in> Yes it's worth it but I'm sure you can angle the engine upward enough to insert them....I love mine, they're The Isky .425" lift/256* duration...I purchased Thru Courtesy Nissan (Nissan Motorsport) they compliment the JWT ECU, and headwork really well, the beast is extremely tracteable and throttle sensitive.....step into it about 1/4" throttle and you're by yourself....I also run about 15* BTDC ignition as well! Sorry I'm taking over your thread E-DOG!!!!!!
Old Mar 12, 2011 | 03:44 AM
  #92
Big_E-Dog's Avatar
2nd Gen Boostinator
dont trip i got a thread reclaim photo coming soon!!
Old Mar 12, 2011 | 12:56 PM
  #93
Big_E-Dog's Avatar
2nd Gen Boostinator
the redemption!!!
tunnel shroud being mocked up,
rear part of the tunnel almost complete
the metal supply and goods/tools to keep me goin
still wondering what to do with this support frame might cut it and support it from the bottom
suggestions??
Old Mar 12, 2011 | 01:47 PM
  #94
vernk's Avatar
I say drill some holes along it and foam fill it.
Old Mar 12, 2011 | 05:14 PM
  #95
CMax03's Avatar
Time for some D.O.T. tubing or that wonderful square tubing!!!!! Ladder frame the floor....dude or lower that powertrain more!!!!!!
Old Mar 18, 2011 | 04:31 PM
  #96
Big_E-Dog's Avatar
2nd Gen Boostinator
bump!!!
tunnel is almost done!!!
Old Mar 18, 2011 | 07:17 PM
  #97
CMax03's Avatar
You don't think you need to box that lateral brace together and not relyon those floor panels to carry those forces....The floor will crack?
Old Mar 18, 2011 | 07:22 PM
  #98
CMax03's Avatar
Nice work though!!!!!
Old Mar 19, 2011 | 03:48 AM
  #99
Big_E-Dog's Avatar
2nd Gen Boostinator
right where the lateral bar is there is a brace on the bottom, i shouda took a picture of that, but since i got the tunnel figured out, im going to use a hoop design to continue the bar ovet the tunnel.
thinking about making a "X" member.....
Old Mar 19, 2011 | 04:51 PM
  #100
CMax03's Avatar
Originally Posted by Big_E-Dog
right where the lateral bar is there is a brace on the bottom, i shouda took a picture of that, but since i got the tunnel figured out, im going to use a hoop design to continue the bat ovet the tunnel.
Yeah that's the ticket...the hoop design will maintain the unibody rigidity in the flooring
Old Apr 17, 2011 | 08:27 PM
  #101
Big_E-Dog's Avatar
2nd Gen Boostinator
bump....
bay sprayed with rubberized undercoating, seam sealed the tunnel and sprayed the bottom
Old Apr 21, 2011 | 04:30 PM
  #102
Big_E-Dog's Avatar
2nd Gen Boostinator
fiberglassed and carbon fibered the tunnel
oh **** LOL!!
dont think ima wrap the entire tunnel in carpet, gonna let some of the carbon fiber shine.
Old Apr 21, 2011 | 06:49 PM
  #103
Dhunterx's Avatar
Dude, do you s*** out carbon fiber? I always see you using a crazy amount for other goodies on your car. It's coming out nice btw, very nice work.
Old Apr 22, 2011 | 08:13 AM
  #104
t6378tp's Avatar
Turbo 3.5
nice work
Old Apr 24, 2011 | 08:44 PM
  #105
Big_E-Dog's Avatar
2nd Gen Boostinator
awwwh hell might as well finish the tunnel, gonna give it a few days to cure then ill put in rivets to atach it to the tunnel more securely
as it sits now with the valve covers removed for paint
Old Apr 24, 2011 | 09:12 PM
  #106
CMax03's Avatar
What are those 2 black hoses fuel lines or coolant heater hoses?
Old Apr 24, 2011 | 09:57 PM
  #107
FlawleZ's Avatar
But why do the DETT when you can make 600+ with the VG30ET? Simply sick man. I've always wanted to see a RWD Maxima.
And please tell me this is on Z31P. I don't recall seeing it but I suppose I missed it somehow...
Old Apr 25, 2011 | 12:31 PM
  #108
Big_E-Dog's Avatar
2nd Gen Boostinator
the ones with the AN fittings are for the cooler and the other 2 are for the filter relocation, just havent cut it yet
Old Apr 25, 2011 | 04:06 PM
  #109
CMax03's Avatar
That looks like a VG30ET or a VG30E with a Different intake!!!! It's definitely a SOHC V6....not a DOHC!
Old Apr 25, 2011 | 08:33 PM
  #110
chrome91's Avatar
its a VG30ET from a Z31
Old Apr 26, 2011 | 02:50 PM
  #111
CMax03's Avatar
So what is the OP talking about in #107?
Old Apr 26, 2011 | 02:58 PM
  #112
Dhunterx's Avatar
Must have confused the motor? They two are pretty different in looks though, no idea.
Old Apr 26, 2011 | 11:21 PM
  #113
chrome91's Avatar
yeah im lost too with post 107, the 2nd gen was a FWD VG30ETT and now its going to be a RWD VG30ET with a Z31 turbo engine
Big E has legendary Maxima status lol
Old Apr 27, 2011 | 12:09 AM
  #114
K-Ryder's Avatar
This is crazy, another person turning FWD to RWD. Keep it up man.
Old Apr 27, 2011 | 08:02 AM
  #115
FlawleZ's Avatar
Old Apr 27, 2011 | 08:04 AM
  #116
FlawleZ's Avatar
I know that. Read his original posts. He talks about doing the VG30ET now and the DETT later on.
Do none of you guys read?
ppl said the same thing when i said i was gonna go twin turbo.
heres the plan, swap in a z31 turbo vg30et and tranny get the project up and running, then move ing on to bigger and better things, vg30dett.
i love a good challenge!
Old Apr 27, 2011 | 08:27 AM
  #117
Snypa's Avatar
Cant wait to see the video of it running..
Old Apr 27, 2011 | 05:32 PM
  #118
CMax03's Avatar
I guess not everyfreakin word to the "T".....lot's of orgers kinda float around and check up on things like I do!!!!!!
Yeah from post#9....just saw it guess I forgot about that small post.....
Old Apr 28, 2011 | 09:05 PM
  #119
Sam o nela's Avatar
Man this is coming along great bro!! I look forward to the next update!!!
Old Apr 29, 2011 | 03:34 PM
  #120
High5maxi!'s Avatar
My maxima is RWD lol this is one sickk build. cant wait to see some drifting videos or somthing hahah
