(PAGING internet auto martor whoever can help)oil leaking on bushing
oil is leaking on my bushing after i changed my motor. i though it was coming from the oil filter but its not. can u tell me what kinda seal i need and also do u sell it. thanx in advance
Originally Posted by magicdonjohn
sorry bout that. the lower control arm bushing by the passenger side tire
There are 2 places you need to check for the leak..
1. Check your power steering pressure hose for a leak in the hose..It is on the passenger side behind the stut tower,it runs down behind the engine to the pump..
2. Check around the bottom engine pulley for oil leaking around it....
....and as long as you have to pull the crank pully... excellant time for a UDP install!!! You should be happy you now have an excuse for an upgrade!!! There are a few excellant writeups on UDP installs, sure made mine a breeze.
I got the UDP and replaced the seal
i have the same leak over the one bushing on the lower control arm. ever since i did the udp it has leaked and havnt the motivation to fix it
. do an udp its worth it especially since your there.
Mar 12, 2020 12:06 AM
ag90fox
Sep 9, 2015 12:22 PM
