Electrical question, trunk room light...help
Old Feb 22, 2006 | 06:24 PM
Dayle97SE's Avatar
My trunk courtesy light, located in between the speakers inside the trunk, has not illuminated in a few years, and it's quite annoying using a cell phone to light up my trunk at night. I've tested the and changed the bulb MANY times, so I KNOW it's not that, but when I recently gutted out the whole rear of the cabin, including the speaker/third-brake-light deck, and exposed all the wiring there, I tested the wiring for that light fixture and it's not receiving any current. Some nissan technician believes that the sensor that knows when the trunk lid is open is not recognizing an open circuit, therefore not turning on my darn light!. Please, anyone had this problem? ...know what to do? Any help would be greatly appreciated.
Old Feb 22, 2006 | 06:45 PM
vansskaterfreek's Avatar
did you check fuses????
Old Feb 22, 2006 | 06:57 PM
internetautomar's Avatar
mod or sell?
is this on a third gen?
Old Feb 22, 2006 | 07:23 PM
Dayle97SE's Avatar
Yes, this is for an '89, GXE...which fuse would cover that particular electrical component? I'm having no trouble with any other electrical devices.
Old Feb 22, 2006 | 08:43 PM
Dayle97SE's Avatar
All fuses were just checked (at least I checked all the ones on the fuse cluster below and to the left of the steering wheel). They're fine.
Old Feb 23, 2006 | 03:55 AM
Krannick's Avatar
check the trunk light switch to see if you get a different reading with the switch on or off
Old Mar 13, 2006 | 05:25 PM
Dayle97SE's Avatar
OK, got it...it turned out that the wires leading to the trunk lid were sliced! I have no idea why, but now it works....thanks for your help guys...
Old Mar 13, 2006 | 08:54 PM
gapboi210's Avatar
where is the switch and wires?
i am having the exact same problem
Old Mar 13, 2006 | 10:01 PM
PovCityHustla's Avatar
re wire it yourself
Old Mar 14, 2006 | 11:00 AM
Dougn's Avatar
I had the exact same problem. It turned out the wires were cut at the swinging hinge (driver side). From the look of it I thought some one had cut it but upon carefull examination I can see that the hinged could have slide it off. I just rewire it and tape it out of the way from the hinge and all is working now.
I also spent many hours tracing the wires/ fuses and gave up for a couple years before find this out.
shilov
Feb 19, 2024 09:40 PM
The Frye
Sep 2, 2021 11:03 AM
GregL65
Jan 17, 2020 08:01 PM
thenewguyy
Sep 12, 2015 11:12 AM
rbaker100
Sep 6, 2015 02:46 PM
