*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Apr 21, 2009 | 11:19 AM
  #3401
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by Nick_Black
tanks alot for the info just asked becouse I have allready done some reading and it seams a bit more advanced then the Buik 3800 I'm familiar with. also I enjoy looking at what I have 2 work with before starting..
and on a side note.. is there no rep system on this site? (or else I would have given you a +rep..)
thanks
the 3.8 is actually easier to work on compared to a VG IMO.
Old Apr 21, 2009 | 11:27 AM
  #3402
peterliu's Avatar
Caped, responding back to you regarding the post I entered on thread below. http://forums.maxima.org/3rd-generat...uild-easy.html
Quote:
Originally Posted by internetautomar View Post
check your transmission fluid.
(these 3 posts should be moved to the n00b section next mod that sees this)
i dunno, sounds like normal T/C lockup to me. driving along at 2500rpm then drops after the tranny warms up. peter, when you are driving along at the higher rpm, teasing the gas pedal DOES slightly change the RPM (maybe +/- 150 rpm depending how much you tease the pedal) but question is, AFTER the rpm drops, does teasing
the gas pedal still have the rpm changing slightly or does it stay dead-on like a stickshift car?
When i tease the pedal before or after the RPM drops, the RPM acts as normal. press the gas the RPM will get higher, let go and rpm will drop. I had the tranny fluid changed not long ago in Feb but I'm assuming it did not empty all of the old fluid. Not exactly sure how much was drained or filled.
Old Apr 21, 2009 | 11:32 AM
  #3403
PMAX08's Avatar
hey guys,
im headin out to pick up some redline 75/90 GL4 rated oil for my tranny, how many litres do i need? is 4 enough or do i need 5? also this is the 5spd VLSD tranny
thanks
Old Apr 21, 2009 | 01:16 PM
  #3404
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by PMAX08
hey guys,
thanks
4.5, so you need 5qt
Old Apr 21, 2009 | 01:27 PM
  #3405
DanNY's Avatar
Ad·min·is·tra·tor
is the motor up to temp? (temp needle in the middle)
if you changed the fluid (drain and fill) it changes/displaces about 3.5 qts. the tranny i believe* holds 10-12 qts.
like everyone said the tranny sounds like is operating normally.
Old Apr 21, 2009 | 01:33 PM
  #3406
my friend has a 89 GXE that she might let me borrow to make a vid for you, so you can see if it does the same thing as yours does. I guess i'll do it at 55-60mph just like you were noting (which is good cuz i am right next to a very long 55mph-speed-limit road). I'll narrate it and say when it's in O/D non-lockup and when it's in O/D lockup.
Old Apr 21, 2009 | 01:44 PM
  #3407
DanNY's Avatar
Ad·min·is·tra·tor
Peter...drive with the OD off and hit 55mph and then press the OD button (to turn it on) and see/feel if you get the OD lock up/shift.
Old Apr 21, 2009 | 02:56 PM
  #3408
djfaka's Avatar
Hey would one of you kind gents be willing to throw up a quick step by step write up on both a front and rear valve cover gasket replacement on a VG engine? Possibly some pics (capedcadaver) of where the bolts are and stuff would be good.
I searched around and think I know what needs to be done but wasnt sure what parts I'd need if I got them from courtesy or if I could get them from like autozone or napa.
Thanks!
Old Apr 21, 2009 | 03:52 PM
  #3409
Thanks!
  • remove your intake pipe and everything that would get in the way of you removing the intake manifold (hoses and crap)
  • loosen the UIM bolts in this order (http://boredmder.com/FSM/Nissan/Maxima/1994/em.pdf page EM-20)
  • remove the distributor (turn engine until you are at TDC #1 with the rotor pointing toward the passenger headlight, then unbolt it and remove it)
  • then unscrew the valve covers
  • replace gaskets
  • reinstall valve covers (don't overtighten screws.. snug but not tight)
  • reinstall the intake w/ new gasket (tighten bolts in reverse order of loosening)
  • reinstall everything else you removed
Old Apr 21, 2009 | 07:48 PM
  #3410
HahitsKen's Avatar
As I was installing the intake I found a problem, for the intake pipe, which is 2.75" diameter to the MAF's 3.5" diameter, how would I possibly connect the two together. the 3" rubber cupplers won't fit around the MAF's 3.5" diameter. I was thinking of finding a 4" to 3" cuppler, but there aren't many around. How did you guys do it?
Old Apr 21, 2009 | 08:12 PM
  #3411
BenStoked's Avatar
Jesus was a Zombie.
something like one of these
http://cgi.ebay.com/ebaymotors/3-to-...Q5fAccessories
Old Apr 22, 2009 | 05:31 PM
  #3412
-ReLLiK-'s Avatar
Quick question: Just got fog lights from Autozone to install on my car. There were already fogs on it before it was hit (way before i had the car), so there is already a stock fog light button.
Can i just cut the connecter (plug) off of the wires on my car, and hook them up to the wires that came with the fogs? Or do i have to use the relay, and the switch that came with the fogs?
Old Apr 22, 2009 | 05:43 PM
  #3413
Greeny's Avatar
¯\(°_o)/¯
Yep, just cut/splice the az fogs into the stock wires..
Old Apr 22, 2009 | 05:44 PM
  #3414
-ReLLiK-'s Avatar
SHIZAM!! thx!
Old Apr 22, 2009 | 05:59 PM
  #3415
internetautomar's Avatar
mod or sell?
assuming that all he has is still good.
Old Apr 22, 2009 | 06:00 PM
  #3416
Greeny's Avatar
¯\(°_o)/¯
yes, assuming the wiring/switch is good..
Old Apr 22, 2009 | 06:05 PM
  #3417
-ReLLiK-'s Avatar
Gosh guys, just turn everything negative. Now watch ima do this tomorrow and my wires will be complete sheit! lol
Old Apr 22, 2009 | 06:18 PM
  #3418
Greeny's Avatar
¯\(°_o)/¯
Well, these cars are hitting the 20 year mark now, not mention, some of these cars have had many many previous owners, this usually= lots of stupid crap done to the cars by said previous owners..not really the cars fault, just a product of age..
Old Apr 22, 2009 | 06:24 PM
  #3419
BenStoked's Avatar
Jesus was a Zombie.
I was in the same position that you are in, right now (originally had fogs, but I got the car w/out, bought a set of cheapo autozone fogs).
my wiring was crap, but the switch was good, so I just ran a wire, and used the oem fog switch to illuminate them.
Hope your wiring isn't fubar'd.
(I may be one of the previous owners wayne just mentioned for that ghetto-ish rigging )
Old Apr 23, 2009 | 09:57 AM
  #3420
mod or sell?
if it has been missing for a while the wires can get corroded which will render them useless. I would recommend checking the wiring for power and ground with a test light before wiring anything up. Also don't forget to check to make sure you have a good fuse installed.
Old Apr 23, 2009 | 10:37 AM
  #3421
importboy34's Avatar
hey whats up i have a 91 vg auto. im getting 18 miles per gallon on the highway and i replaced plugs, fuel filter, oil, air filter and thermostat. the car makes a paapoof sound from the exhaust. if anyone can help that would be great. this is my second max and im stumped
Old Apr 23, 2009 | 10:48 AM
  #3422
mod or sell?
sounds like you have a miss, check the resistance on your injectors. chance are at least one is bad
Old Apr 23, 2009 | 01:00 PM
  #3423
like at idle warm or cold all u hear is paaapoof. i hooked up a scanner at skool to check my maf and w.e else i could and it came up with a fuel pump fault and coil. but the car runs fine. the right pressure is there and im getting spark. im just really puzzled. this is my second vg max and im honestly puzzled
Old Apr 23, 2009 | 01:19 PM
  #3424
with the car running disconnect one spark plug wire at a time and see if any cylinders make no change when unplugged. if you unplug a wire and nothing changes, then that cylinder isn't firing. having the iacv unplugged (as long as your idle screw is adjusted properly) can make it easier to detect cuz that way the ECU can't compensate the idle.
Old Apr 23, 2009 | 06:49 PM
  #3425
blown-n-boosted's Avatar
New guy
How many posts I need to start my own thread? I want to document my 94 Turbo Max build here instead of over at the Z site. Heres a link to it.
http://z31performance.com/forum/view...p?f=13&t=15732
Old Apr 23, 2009 | 07:01 PM
  #3426
jk just 15
Old Apr 23, 2009 | 07:59 PM
  #3427
Can I borrow a few? lol
Old Apr 23, 2009 | 08:06 PM
  #3428
-ReLLiK-'s Avatar
Well, i got the fogs hooked up. Look nice.
Didnt know that in order for them to come on, the headlights need to be turned on, and not just the side marker lights... Is there any way I can re-wire them so they work like that?
And also, one fog light is dimmer than the other. Can this be because of poor contact between the wires?
Old Apr 23, 2009 | 08:07 PM
  #3429
-ReLLiK-'s Avatar
you know anyone selling a turbo off of a Z31?????????
Old Apr 23, 2009 | 08:55 PM
  #3430
yep. snip the red/yellow wire coming out of the bottom of the Fog Lamp Relay's socket and splice it to one of the red/yellow wires on the nearest (i assume driver side) corner lamp harness.
Old Apr 24, 2009 | 05:13 AM
  #3431
I have a complete t25 setup off a Z. Ecu, harness, injectors, ect.
Old Apr 24, 2009 | 10:22 AM
  #3432
mark3681's Avatar
94 Max clutch question
Clutch loses compression. It might be fine for days, but then, like today I did a lot of start and stop driving, lost all compression. Had to let it cool down for about 15 minutes before I could get anything out of it, and then just barely got going in 1st gear.
Any ideas?
Old Apr 24, 2009 | 11:58 AM
  #3433
Your clutch is bad. If your clutch was recently replaced I would suggest that your rear seal is leaking and you have a glazed clutch. But it definetly sounds like a bad clutch.
Old Apr 24, 2009 | 12:13 PM
  #3434
mark3681's Avatar
Yea. I was afraid of that. Clutch was not recently replaced. Had it done about 3 years ago.
This does suck. I have 250,000 on her. Was hoping to get another 50K out of it. I hate to put any more $$ into it at this point.
Thanks for the reply.
Old Apr 24, 2009 | 01:44 PM
  #3435
wowhesawesome's Avatar
help
Hey i have a 94 maxima, i have a question concerning the cold air intake. I've seen a many pictures on here where people simply worked around the MAF sensor, by replacing the intake pipe before and slapping a cone filter after. Seeing as how i cant seem to find a kit with an air sensor adapter for under $200, i would like to inquiry the best way to go about installing a cold air kit, while working around the air sensor as i see most of you have. I would greatly appreciate any info you could give me.
Old Apr 24, 2009 | 05:15 PM
  #3436
Greeny's Avatar
¯\(°_o)/¯
--> http://forums.maxima.org/3rd-generat...f-adapter.html
Old Apr 24, 2009 | 07:33 PM
  #3437
It fits!!
Old Apr 24, 2009 | 07:56 PM
  #3438
It fits!!
[IMG]http://i204.photobucket.com/albums/bb10/z31pook/Project%20Maxima/maximapics019.jpg[/IMG/]
[IMG]http://i204.photobucket.com/albums/bb10/z31pook/Project%20Maxima/maximapics021.jpg[/IMG/]
[IMG]http://i204.photobucket.com/albums/bb10/z31pook/Project%20Maxima/maximapics022.jpg[/IMG/]
[IMG]http://i204.photobucket.com/albums/bb10/z31pook/Project%20Maxima/maximapics023.jpg[/IMG/]
JESUS CHRIST DUDE!!!!
get rid of that rustbucket car! that car isn't safe to be driven stock, let alone boosted!
or at least let that be a hack-up parts car that you are test fitting crap on.... not your actual street car.
o and btw i see your tranny there, automatic..... boost will eat that for lunch.
Old Apr 24, 2009 | 09:03 PM
  #3439
chrome91's Avatar
holy crap is that just a parts/test car or a actual project? boost it and all i see are hundreds of rusted parts flying off
Old Apr 25, 2009 | 06:17 AM
  #3440
First off heres a pic of the car before I tore it apart.
Look no rust! Unless you've already pulled your rad and condensor and fixed this yours it has it too in some way shape or form. Heres a major rust problem in a 90 max se.
I'm far from a noob and just installing a turbo should prove that. all maximas owners would be going turbo if there was a kit involved but there isn't. Ive only owned this car for 2 weeks and have already done more to it than most maxima owners will do in years. Wait another week or 2. I've already got all of my parts this last week. Spent more than $2000 on parts alone. Seriously I'm curious how many people are running Nistune on their ecu? I have mine. My parts list is huge and when I get these damn 15 posts you guys can watch the build too. Auto trans yea right.
Pedal and clutch master is in. Still need to cut auto brake pedal.
I'm probably the only gold 94 gxe owner that has full black interior. All the upper cloth crap on the interior was pulled out and rewrapped in black vinyl.(fresh install still dusty)
