*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Oct 15, 2011 | 12:00 PM
  #6641
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by 94beater
I didn't ignore it... I stated in another post that I had a fully charged jump box hooked up to the car.
hook the jump box directly to the starter lug, and a clean spot on the engine. see if she spins right, then.
Old Oct 15, 2011 | 01:48 PM
  #6642
chrome91's Avatar
yep you can hook up a booster pack to the starter and see if the starter turns
Old Oct 15, 2011 | 02:01 PM
  #6643
94beater's Avatar
Ok that's another good test ill try.. thanks! The starter that came today was also not correct... the solenoid was mounted too low and the cable would not reach the connection on the solenoid ... I have lost all faith in these reman starters... not that there was that much faith to begin with :-/
Old Oct 15, 2011 | 06:31 PM
  #6644
jbbons25's Avatar
Waiting on another starter right now.... Looks to me like the starter gear was definitely hitting the flywheel... Not sure if they are giving me the wrong starter or if the starter was built with the wrong gear it it.... Ugh I hope the next one works!
One thing to check while the starter is out is to look at the teeth on the drive plate and make sure there is no damage that would keep the starter from engaging onto it. What you can try to do is get a large enough screwdriver and rotate the drive plate and then re-install the starter and see if it will engage.
Old Oct 15, 2011 | 07:25 PM
  #6645
94beater's Avatar
I used a socket and turned the crank shaft a bit earlier today and it was still just clicking. I will update what happens when I get the next starter on Monday... for now ill be installing my new speakers and Kenwood head unit... old stuff was original and completely shot! Lol
Old Oct 16, 2011 | 07:12 PM
  #6646
Deolarte's Avatar
Originally Posted by BenStoked
you definitely popped a fuse. double check with a multimeter, you'll find it's toasted. (6th one down, closest to the door)
If it's still a no-go, I would warrant the theft ecu is toast. Happened to me, once, back when I was a total n00b. (I think I'm graduating to n00bish, soon)...
cover the end of the illumination wire with electrical tape, don't use it.
It was actually both, fuse and control unit, was fried, but fuse kept blowing, until illumination was capped off by itself. Thanks alot. Now I just need to figure out if speedometer or sensor is bad.
Old Oct 17, 2011 | 09:21 AM
  #6647
BenStoked's Avatar
Jesus was a Zombie.
nine times out of ten, it's the speed sensor. Per fsm, you can pull the speed sensor, put a multimeter on the pins, spin the gear quickly (fsm shows clockwise), you should get voltage (0.5v AC).
Old Oct 17, 2011 | 11:02 AM
  #6648
94beater's Avatar
Update on my starter problem.... IT'S ALIVEEEE!!!! Thanks for helping me troubleshoot this problem... I still cant be sure whether the problem was in the battery, or the starter... because I put the new starter in and a brand new battery all in the same shot this afternoon. Figured the battery would be a good thing to do either way because winter is approaching....
Anyway, it fired up first try about 10 minutes ago and I couldn't be more relieved! I'm closing on my first house tomorrow and my fiancee' need's her corolla back, we have been sharing her car for the past 3 months since I sold my Wrx.
Old Oct 17, 2011 | 02:29 PM
  #6649
danof150's Avatar
my name is dan, i just picked up a 94 maxima for a winter "beater". when i left for work this morning the car was fine at the end of the driveway. i come home and the left headlight is on, and wont turn off. the switch is off, and when turned on both lights turn on. i know i can pull the fuse to stop the battery drain, but wtf could this be.any help is GREATLY appreciated
Old Oct 17, 2011 | 03:47 PM
  #6650
BenStoked's Avatar
Jesus was a Zombie.
I suspect the switch is bad. try flicking the brights a few times, see if they will at least momentarily turn off.
It may also help to see if pulling the switch out, and unplugging it allows the lights to turn off. If it's not the switch, it's stuck relays or burned wiring :/
Old Oct 20, 2011 | 10:47 PM
  #6651
Sebatiao's Avatar
91 Nissan maxima
Can I retro fit a 92 cupholder into my 91 maxima?
Old Oct 21, 2011 | 05:04 AM
  #6652
BenStoked's Avatar
Jesus was a Zombie.
yep, have one in mine.
Old Nov 4, 2011 | 02:21 PM
  #6653
Red1bklyn's Avatar
Hey guys just bought a 91 maxima not sure of the engine type. I only have had it for a month and since its getting cold i noticed that when i turn on the heat after the car has been warmed up that its temp gauge shows that the car is getting cold. I have no idea what it can be. I also have a very high idle on this car. It idles between 1,200 & 1,500 rpm's in park & 800 - 900 rpm's in drive. It has dropped to regular idle about 3 times since i had it around 900 in park & 400 in drive but rarely. I think it has something to do with the throttle body or tps but again not sure. Some help diagnosing it would be great. I don't want to go thru replacing a bunch of stuff if i don't have to. I would like to thank any & everyone for any help in advance. I have had a lot of help with my g35x on the infiniti forums & feel really confident that u guys will do the same.
Old Nov 4, 2011 | 05:58 PM
  #6654
chrome91's Avatar
91 no matter if its a GXE or SE you have a VG30E
your temperature gauge could be bad, mine went as well as the tach and both would work for about half of the time and thats it. could be a bad wire behind the cluster or the cluster itself. how far does it dip down?
high idle could be a bad vacuum line
Old Nov 4, 2011 | 07:14 PM
  #6655
max_overdrive's Avatar
hello i just got a 1991 se 5spd and it has a misfire, new plugs, wires, cap, rotor, and fuel filter .
i pulled the plug wires one at a time and i found one that doesn't change the idle,(front middle cyl i think its number 4?)i also pulled the injector connector on that one and that doesn't change it ether .
i changed the plug on that cyl and no change so im guessing the only thing left is the injector? that plug was coal black but the other plugs are perfect tan.
o and would a misfire make the knock sensor pull timing?
thanks.
Old Nov 4, 2011 | 07:47 PM
  #6656
chrome91's Avatar
could be the injector, theyre known to be a problem on VG30E
Old Nov 5, 2011 | 07:25 AM
  #6657
ok if i go to the junkyard can i use any vg injectors or only early years? i read something about colored dots?.
Old Nov 5, 2011 | 11:39 AM
  #6658
chrome91's Avatar
theres 2 different kinds, would have to look at the injector threads (should be many) for the color codes, i never had to do an injector on mine so i dont know the color codes
Old Nov 6, 2011 | 03:47 PM
  #6659
as a follow up ,i replaced the injector and it fixed it. runs good now. thanks.
Old Nov 10, 2011 | 10:18 AM
  #6660
1gepetto's Avatar
i just did an engine swap and have 4blue and 2 black dots that seem to be doing just fine. did try 1/2 fuel rail from j/y i got for cheap, but only 1 injector ohmed out good.
Old Nov 12, 2011 | 05:21 PM
  #6661
Rambosliice's Avatar
Do they sell/make headers for a 94 se maxi 5 spd
Old Nov 12, 2011 | 05:38 PM
  #6662
BenStoked's Avatar
Jesus was a Zombie.
no, custom is the only way to go.
Old Nov 12, 2011 | 06:04 PM
  #6663
So I should just get better piping then?
Old Nov 12, 2011 | 06:06 PM
  #6664
Old Nov 12, 2011 | 06:12 PM
  #6665
BenStoked's Avatar
Jesus was a Zombie.
as in cat-back? it's always beneficial.
another point to look for is the warpspeed y-pipe. nothing but raves from the people using them.
Old Nov 12, 2011 | 06:34 PM
  #6666
chrome91's Avatar
yeah if you want a upgrade get the MES mandrel exhaust system and WarpSpeed Ypipe, i did the full mandrel exhaust and Ypipe at the same time and it was a HUGE difference
Old Nov 14, 2011 | 01:16 PM
  #6667
1991dohcswap's Avatar
vg30e performance
i have a 91 maxima gxe with the vg30e i have been looking for performance paarts for the motor and i havent had any luck i cant even find a cold air intake for the car
Old Nov 14, 2011 | 04:48 PM
  #6668
chrome91's Avatar
best bet is the full mandrel exhaust from MES, WarpSpeed Ypipe, and a K&N air filter
if youre good with engines, you can take the turbo parts from a Z31 turbo with VG30ET and turbo a 3rd gen, but you would need to beef up the tranny or use a VE 5spd because a GXE tranny wont last long
Old Nov 17, 2011 | 07:02 AM
  #6669
Marcomarco's Avatar
Many thanks for this forum. My 1990 maxima has rough idle when you start it cold..it goes up to 1500rpm...it seems it doesnt have right air-fuel combination...i can smell unburned gas from the exhaust...after some time like 5-10min, when it gets warm the idle goes down to 700-900. i can tell something is not right.. and my gas mileage is heavy as compared before.. Just wanna solicit your expertise with this before i mess up the sensors and all..Thanks again
Originally Posted by Greeny
Ok folks,This thread is for new members/w under 15 posts to post their questions regarding the 3rd Generation Maxima
Before asking questions,please READ the general maintenance sticky---> CLICK HERE
Please do not post ***** in this thread
ALL MEMBER RESPONSES MUST BE A QUOTE OF THE ORIGINAL QUESTION
Old Nov 17, 2011 | 11:54 AM
  #6670
Laevateinn's Avatar
I accidentally crossthreaded my PCV valve in my 93 SE. Anyone knows the tap size for this?
Old Nov 17, 2011 | 04:32 PM
  #6671
http://www.obxracingsports.com/products.php?pk=1788#
What about these for headers?? And that mes system
Old Nov 17, 2011 | 04:41 PM
  #6672
chrome91's Avatar
http://www.mandrelexhaustsystems.com...ima/Categories
this is the mandrel exhaust, you just need a muffler and a resonator. cant remember what length of resonator though
Old Nov 17, 2011 | 08:00 PM
  #6673
BenStoked's Avatar
Jesus was a Zombie.
there's a design flaw in those headers; no flex section before the cat. not too difficult to remedy, but a warpspeed y-pipe would offer better gains for the price.
and Chrome posted the link for the exhaust.
Old Nov 18, 2011 | 05:05 PM
  #6674
chrome91's Avatar
i found old pics of mine, im pretty sure it was a 20" OBX resonator i used and i had a GSX-71 fart can. i ditched the cat converter too, i dont know if they worked out the kinks with the exhaust though because some minor changes had to be made
ive got a vid of how it sounded if you care, crappy camera though so you cant hear it well
Old Nov 18, 2011 | 06:23 PM
  #6675
image man's Avatar
i got a 2000 maxima and i just got a set of ace 18s and my ABS light keeps going off
Old Nov 18, 2011 | 06:36 PM
  #6676
chrome91's Avatar
you want the 5th gen section but you probably have a busted ABS sensor
Old Nov 19, 2011 | 07:50 AM
  #6677
Thanks for the vid now I know there isn't too many videos of the 3rd gen max on YouTube but I found one on a 4th gen max that I really like sound of let me know what you think.. So what I've come to with all this is the mandrel piping with a muffler and a 20" resonator now would it be better to keep the cat or just go with a test pipe instead??
http://m.youtube.com/#/watch?v=xIH-uQeyIJQ
Old Nov 19, 2011 | 12:04 PM
  #6678
Sorry chrome that post above was intend for you sorry this iPhone mobile page is confusing haha
Old Nov 19, 2011 | 02:06 PM
  #6679
chrome91's Avatar
personally i would ditch the cat converter, to me theyre a pain. i took it off the 3rd gen, and when the truck goes for a new exhaust right away and the Supra goes for a new exhaust in the spring both are getting the cats removed. depends where you are though, in the states i know it can be illegal. in Alberta its not illegal
Old Nov 24, 2011 | 09:58 PM
  #6680
Nissan370Z's Avatar
OBD1 questions
I'm working on a 94 Maxima, and I got trouble codes 47 and 82, and from one list that I found online, they both refer to crankshaft position sensor. Why is there more than one code for the same part? Also, I got code 44, and I can't find this one anywhere, could anyone tell me what this code is for?
Thanks for the help in advance.
