*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Either a bad clutch master cylinder(top left hand corner on the firewall),or the operating cylinder(on the transmission bell housing) are most likely your problem.
new guy with a 92 maxima gxe vg30e.
im looking for a digital cluster and the AAC or HVAC, wutevr u call it.
where can i find one online???
nd in order to put in the digi-cluster, do i need that extra part that goes onto the dash and reflects off of the windshield, cause i dont wanna go into all of that if i dont have to.
ehh, why not, anyone with some rims nd tires for sale, PM me, i'll buy.
pics coming soon
pics coming soon
i had white ones in there, but my father had a 94 se w/ white faced gauges nd it seems played out now, so i wanna go digital.
back to my ??, do i need that extra gauge that goes on the dash and reflects off the windshield. im not if i dont have to.
To answer your question, no, you do not have to have the HU display. But most people seek that mod.
---->http://forums.maxima.org/faq.php#nothreadJust post your 3rd gen maxima related questions in this thread..
New Kid
I am planning to buy a 3rd gen Maxima and this will be my first Nissan. I'm making this switch from a 1995 Honda Civic. I'm new to the Nissan market and I'm asking where I could buy a VG30DE and what modifications would I have to make to the car for the motor to fit. Also, what quick bolt-ons are there for some cheap horsepower, where I live Hondas rule the road. I'm wanting to create a Maxima Sleeper that would burn Civics on the street
Reliable horsepower is not cheap,ever.
A turbocharged 3rd gen makes for a nice sleeper..No,there is not a bolt on turbo kit available for our cars,It all has to be pieced together,along with much exhaust welding/fabrication.
good luck..
quote=Kelz 10;6242841]whats up guys....im new here and im trying to post a thread but it won't let me .... can someone tell me what im doing wrong ??[/quote]
youre 14 posts away from starting your own thread my fellow newbie
The VG30DE will not fit into the maxima engine bay,period.
good luck..
good luck..
where could i find a kit that would work with the fabrication?. and how much would the kit cost
FIT
the 92-94 SE had a vE30de, that swap has been done to other 3rd gens..
no kit, or anything will make a vgde fit. period. it is too big.
wanna make it go fast? strip it down, reducing weight everywhere. add a turbo, doing your own fabrication. throw a JWT ecu, and cams in. regear the tranny. add nitrous.
same **** as a honduh, 10 years ago, before everybody was fast and furious
after that add a UDP, Y-pipe, Flywheel, light weight wheels some suspension mods and you're go to go.
Sub mount
Well I have a 12" sub in the back of my max, but It is in about a square foot box. At the current time it is not mounted, because of my lead foot I have a tendancy to have it flop around the back of my trunk witha resounding THUMP. it has a tendancy to come unpluged to my dimay, has anyone else mounted a sub in the trunk of their maxima? if so how did they mount it down, Just wondering?
______________________
- What the speed limit is 65? but officer its the Highway?
Well I have a 12" sub in the back of my max, but It is in about a square foot box. At the current time it is not mounted, because of my lead foot I have a tendancy to have it flop around the back of my trunk witha resounding THUMP. it has a tendancy to come unpluged to my dimay, has anyone else mounted a sub in the trunk of their maxima? if so how dis they mount it down, Just wondering?
Some strips of velcro(hook side) mounted to bottom of the box will work also,but the L brackets will work better in the long run..
You can create your own signature by going into your user cp function at the top left of the page..
Rough idle? - car vibrates when I stop
I have been having this problem where my 1994 nissan maxima sohc would vibrate sometimes a little bit and sometimes a lot whenever I was stopped but the car was stilll running .. at times the yellow check engine light would come on and te car from the inside had a noticable putt putt sound along with the vibration. At first I thought I had a case of bad gas so I used both the fuel injector cleaner and some Heet product to remove any water from the gas .. this seemed to work where the engine check light went off and the putt putt sound and vibration eased .. but the check engine light did not come on but i still had the vibration ..... I had the spark plugs changed, but still had the vibbration, changed the spark plug wires and the vibration eased up but soon returned so I had the rotor and cap replaced and at times there is no vibration and other times the severe vibration is back and the check engine comes on sometimes .. what does yall suggest be the next step and please speak in a lil detail as I donot understand what certain abbreviations are like maf, etc ... Thanks
Just wondering wats wrong wit my bose speaker
in da rear driver side the speaker makes thumping sounds n some high pitch noise
im just wondering if its still any good?
wat size is the replacement speaker ?
Click-----> http://forums.maxima.org/search.php?f=8
Never found what I want here....
I gotta say, I've never found what I was looking for here at Maxima.org,,,
Oh I find plenty to read and enjoy for hours on end, lot's of good info tucked away "for some other time".
Today I'm looking for a schematic of the headlamp/directional switch, no way dude! I've the right low beam out. Everything else works. I know it's not the bulb. No "juice" getting to the plug at the head lamp. Already cleaned the contacts in the switch. I ran a jumper/wire from the switch to the lamp (which actually worked for 2 days). I know which poles are open/closed in any/all positions on the switch, but I need to know which wires go to what.
The "click" out to the manuals at Kragens, (or where ever?), has everything under the sun, except a "91 Maxmima". My Haynes and Chiltons manuals are "clear as mud".
Frustrating. I could go start buying and swapping parts in and out, but that's expensive, time consuming and the shop may/may not take back the stuff I find I don't need, cause it's electrical.
If I could ask or get the answer to this question I'd be a happy camper. "When I have headlight switch ON, in position 2 and lowbeams, I should have continuity thru the switch at which posts"??
Mucho-Tired out in Phoenix. :-)
1989
The max I'm planning to buy is a 1989 model... is there anything for that year that would resemble the parts for the 92-94 SE?
you can with alot of fabrication however install a VG30E+T and have some phun.
RE :PACESETTER HEADERS VG30E got the ceramic coat Or ARMOR COAT that pacesetter claims that it wont rust and resist up to 2000F of heat. Mine is coming with a Y Pipe, did ANYBODY FROM THE ORG GET THE ONES THAT ARE NOW MADE IN THE USA/ I think most of the people that complained and bashed these headers because they got the ones that used to be made in Mexico( they were crappy) . Any suggests on a hi flow cat brand that works well?
as for the pacesetter...
I need a hi flow b/c i believe the stock cat is clogged and effecting my idle/ I heard Random Tech make good cats?/ my idle stays steady at about 800 rpm but when you are driving and come to a full or almost a full stop it stays at about 2000 rpm for maybe 3 to 5 seconds before going down again and the car shakes as the rpm goes back to normal. I have a good feeling that it has to do with exhaust flow. anybody have or had any similar issues with their idle.
