Just a friendly reminder to you guys
Old Dec 5, 2001 | 01:51 PM
  #81
Lordrandall's Avatar
Originally posted by Jeff92se
Check and check. :P
Old Dec 6, 2001 | 08:14 AM
  #82
mykizism's Avatar
i belive that the vg motor is more than capable of making 14's im hoping for mid 13s with my vgt in this coming summer.
seems to me that a factory vg, with a lot of mods and tuning could break 14s just as bryan said earlier.
Old Dec 6, 2001 | 11:07 AM
  #83
male's Avatar
Definately, especially if you spend the money where it counts.. the heads. SOHC heads are much cheaper to port and cut multiangle valves into than DOHC. I was quoted a price of 750 for both all done. Forget the name, it was out of the back of Grassroots. Get the intake plenum extrudehoned($$$$) or at least port matched. Then any mods already there or to be made in the future will have a much higher benefit.
Old Dec 6, 2001 | 11:18 AM
  #84
mykizism's Avatar
jesus 750 to get the head dones? i could be rich if i had the time to port every one's heads and if i charged that kinda price..
tools:
die grinder = 10 dollars
standard abrasives = 30 dollars
time = weekend
new gasgkets = 70 dollars (all of them)
a lot better than paying 700 dollars
Old Dec 6, 2001 | 11:20 AM
  #85
Jeff92se's Avatar
I'm needing a caw
Note: the VE's 4-valve heads have much more valve area than 2-valve(sohc) heads.
Old Dec 6, 2001 | 11:34 AM
  #86
male's Avatar
tools:
time = weekend
True, but knowlege is priceless. The question is, CAN you port heads. Do it wrong and the hp and torque curve will be wierd. cut to deep...oops that's the water jacket or the valve guide. Now the head is junk. Figure this. You charge 15-20 bucks an hour for skilled labor. How long could it take an experienced individual to do a set of heads(disassemble, clean, plane, port/ppolish, cut seats and valves, clean again, reasseble, then check play and tolerances)? That's 12 ports on each head remember. 48 hours seems even a convervative time. 48 times 15 =720... I don't know man, that seems fair to me. Ruin a head and it will cost you a lot of money to no get ahead at all.. Plus, I've seen prices a lot higher than this.
True though, the 4-valve heads do have more area..Price a port polish valve job on those puppies! I am almost certain it will be more than 750
Old Dec 6, 2001 | 11:38 AM
  #87
Jeff92se's Avatar
I'm needing a caw
Yup! Anyone reading this? Learn something! And to add, you have to be able to port THE EXACT SAME WAY ON EVERY PORT! Or else each one will flow different. About the only thing a DIYer can do is just some simple gasket port matching and maybe some casting flash removal(but Japanese heads are one of the best cast heads avail).
Yeah headwork on 4 valve heads are high, good thing the VE ones are decent outa the box.
Old Dec 6, 2001 | 11:44 AM
  #88
mykizism's Avatar
amen to that!
Old Dec 6, 2001 | 09:39 PM
  #89
Bryan H's Avatar
porting is NOT for bone heads.
takes a lot of time and exact measurements before, during and after. paper work, math. and a brain.
don't think it can be done in a couple hours. a throtle body takes that, and thats just one port job.
i posted my mods for a reason. to help others to see it doesn't take much to make these things run
just think the VG has support in aftermarket cams, turbo's, ecu's and a host of other things. im suprised a vg max hasn't broke into the 12's
Old Dec 7, 2001 | 03:14 AM
  #90
Nismo87SE's Avatar
He is absolutly correct
It took me a couple hours to port match my 60mm TB to the intake collector. When I did my exhaust studs I did some very mild porting on the intake chambers. Even then it took about 7 hours, not only do you have to remove some material but it has to be smoothened out to. The only bad thing is I monkeyed the #5 intake valve seat so I didn't get full compression in that cylinder. I'm sure there is a 12 sec VG max somewhere.
Old Dec 7, 2001 | 09:25 AM
  #91
male's Avatar
Re: He is absolutly correct
I just scored a source for 60K mile custom turbo motor out of an 84-86 Z car for an excellent price. You know what this means? I will pursue 12's in the quarter full steam ahead! I'll keep you all posted as I progress through the upgrades.
Old Dec 7, 2001 | 10:48 AM
  #92
mykizism's Avatar
Re: Re: He is absolutly correct
what company are you buying this engine from? and how much did they qoute you?
my vg30et was 650
Old Dec 7, 2001 | 11:31 PM
  #93
JonnyMax's Avatar
Originally posted by Matt93SE
well considering the best VE auto I've seen runs 16.7, and stock VE 5 spd runs about .5 faster, I'd say a 5 spd vg should be into the 14s easy with the pile of mods that Nevin's car had...
badly driven stock VE 5spds run mid 15s... dont discount us too much there!!!!
Old Dec 8, 2001 | 03:46 PM
  #94
Bryan H's Avatar
worse then that man
when i first took my maxima to the track it was not pretty at all
with an intake and exhaust. {no other happy mods}
i went 15.8. 16.0 15.3 15.2 and a 16.2
then the next week
14.9 14.8 14.9. 15.0
i learned how to drive the week between track times
lets just say i sucked at driving
Old Dec 8, 2001 | 10:14 PM
  #95
And now you drive like a crazy person!
Don't ever lend your car to this person! hehe
worse then that man
then the next week
Old Dec 9, 2001 | 03:26 AM
  #96
Bryan H's Avatar
I can drive spanky!
i will hunt you down and po0p on your pillow
Old Dec 10, 2001 | 01:48 PM
  #97
I can drive spanky!
How many trannies did you bust in that Celica?
hehe, Poop! Don't make me poop on your floormats!!
Old Dec 10, 2001 | 03:32 PM
  #98
male's Avatar
Re: Re: Re: He is absolutly correct
my vg30et was 650
It is a private sale...cannot reveal my sources! 500 for complete engine( intercooler, turbo, ECU) and 300z tranny. I don't want the tranny though. He has the car complete, so I can snag the fuel pump too.
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
iflexsteel
Sep 2, 2015 08:04 AM
A32goldylocks
Sep 2, 2015 06:39 AM
