BIG Problem
BIG Problem
This is the biggest problem I have ever had.
1989 Nissan Maxima. I have no inside lights or radio or anything. Turn the key on still nothing...nothing works. I start the car and everything works...radio everything. Also the alternator is not charging the battery. The alternator has been removed and bench tested and passed.
The ignition switch was been changed with a new switch...no change.
The relays on the fuse panel have been changed around with no change to the problem.
I am driving the car by charging the battery with external battery charger. Everything works (blinkers, radio, all lights inside and out) as long as the car is running.
Please does anyone have any idea?
No interior electrical of any kind
I have checked the fuses in the box under the hood next to the battery. All are ok...I ohm tested each one and all pass. The two relays seem to be ok also...each passes ohm test on the circuit that is not a switch.
So far I have checked, the main fusible link,
all the fuses and relays inside the car, and I have replaced the ignition switch.
But everything works once the car is started
I am still having the a major problem with my 1989 Maxima. There is absolutely nothing electrical working in the car, no door lights radio, automatic shoulder strap, until the car is started, then everything works. Even turning the key on before starting nothing comes on. The problem that happened at the same time this problem happened is that the alternator is not getting to the battery. I have taken the alternator off and had it bench tested and it passed.
All fuses have been checked in the car and under the hood next to the battery....all ok. It would seem that a bad fuses wouldn't work either before or after the car was started.
I have checked the battery cables and all seem to be ok.
chinaonnitrous1
01-05-2003 02:12 AM
Matt93SE
08-03-2001 04:58 AM
