Does it look like I over tightened this?
Old Apr 2, 2002 | 08:36 PM
JDwyer2821's Avatar
http://images.cardomain.com/installs...63_23_full.jpg When ever I hit a slope in the road I can hear the bushing make a squishing noise.
Old Apr 2, 2002 | 10:40 PM
Schmoo
First of all, I don't know what the hell I'm talking about.
But it sure looks to me like you've over-tightened it. I don't think the bushings are supposed to buldge out so much like that normally.
Old Apr 2, 2002 | 10:50 PM
Dummy's Avatar
apply a little oil or lube to the bushings before instalation(too late heh) they are probably dry that is why they are squishing.
i dont know if that is the problem but they said that on an episode of trucks i saw sunday heh, if you dont lubricate em they will make a squishy sound.
they look fine to me.
Old Apr 2, 2002 | 10:54 PM
Mike92GXE's Avatar
Where did you get those bushings from? How much did they run you?
Old Apr 2, 2002 | 10:55 PM
Matt93SE's Avatar
STFU n00b!
yeah, you squished them a little much, but you'll be okay if you just back the nut off a bit..
if you still have any of that white grease that came with the kit, squeeze some of that on all the bushings again. if you don't have any, just any really heavy grease will work. the thicker, the beter.
Old Apr 3, 2002 | 01:59 AM
JDwyer2821's Avatar
Thank you all for the info. I will un tighten them intill there is no bulge and white lithium grease them as much as possible. I did use the clear greas they gave me with the set but it seemed sticky as ****. I will attemped the rear one again this thursday.
Old Apr 3, 2002 | 05:15 AM
flyry110's Avatar
mine are actually tightened all the way to the end of the threads. so i can't tighten it anymore. yours look like mine do. i've never had a problem with noise. good luck though. Oh, when you do the back, be careful with the 2 main bolts on each side. i broke one on each side and ended up having to drill them out. it wasn't fun! anyway, let me know if you have any problems. i've got both as well you'll love em! best mod i've done so far. ..
Old Apr 3, 2002 | 06:30 AM
DanNY's Avatar
Ad·min·is·tra·tor
white lithium grease won't help too much. you need that stuff that looks like errr...whitish glue..sorta like snot and another bodily fluid.
it's very sticky. if it didn't come w/ the bar call up who ever sold u the bar and ask for it.
Old Apr 3, 2002 | 07:00 AM
blackandwhite's Avatar
To them I'm like an idol
I had this problem, I guy at a performance shop said to grease with waterproof grease, about every 6 months. He was right. It's been 6 months, and it started squeakung again, so I lubed it again, and it went away..again.
boomerbrian
Nov 8, 2015 05:10 PM
Noela
Sep 26, 2015 08:22 AM
thenewguyy
Sep 12, 2015 11:12 AM
ag90fox
Sep 9, 2015 12:22 PM
Maxboy23
Aug 11, 2015 11:59 AM
