2000 cc !
Old Oct 10, 2003 | 02:29 PM
maxS
2000 cc !
Look at that!
http://images.cardomain.com/member_i...11_65_full.jpg
Old Oct 10, 2003 | 02:55 PM
matty's Avatar
what about it ???
Old Oct 10, 2003 | 02:57 PM
CullenJ76's Avatar
yes that is a picture of the cifero engine bay.
over seas it comes with a motor almost identical to the vq30de but with smaller displacement.
oh yeah, and the mevi is stock
Old Oct 10, 2003 | 02:59 PM
matty's Avatar
thing is probably slow as helll...2.0 v6
-matt
Old Oct 10, 2003 | 03:11 PM
PoePoe2797's Avatar
-matt
What makes you say displacement plays a big difference on speed? Yes it affects if a little, but not a whole lot. I had a 2.0 Jetta, and a friend had a 1992 1.8 golf and his car was about twice as fast.
Also, would you rather perfer a 2.0 4cyl or a 2.0 6 cyl?
CullenJ76's Avatar
not much low-end torque
Old Oct 10, 2003 | 03:14 PM
chris j vurnis's Avatar
I have driven a few of those in Korea with a 4-speed auto (identical to the U.S. spec transmission aside from the final drive ratio)
Actually, they are not that bad for driving around in the city.
The transmission helps it along quite well since the 2.0L engines get hooked up with a 4.40 final drive as compared to the 3.60 final drive for the 3.0L engines.
Also, all the Asia market VQ engines (2.0L, 2.5L, 3.0L) have the variable intake components.
A lot of times, the foreign mentality is better than the U.S. They tend to consider the whole powertrain system -- including the transmission -- to get the most performance possible. In the U.S., the buyers and manufactuers alike tend to focus only on the engine power without considering that the transmission can really sandbag an engine if it is not set up right.
The transmission setup is just as important as the engine setup.
matty's Avatar
I would prefer a 3.0 V6
-matt
Old Oct 10, 2003 | 03:16 PM
CullenJ76's Avatar
well actually, it affects it ALOT...
Torque
and about the VW thing...
the 1.8 is a TOTALLY different motor than the 2.0
the 1.8 is a 20 valve dohc motor(5valves/cylinder) and the 2.0 sohc 8vis a very outdated motor unless you are talking about the older 1.8 which is still a better motor
i'm not saying that the 8v 2.0 is a bad motor because i have experience with all three
Old Oct 10, 2003 | 03:17 PM
CullenJ76's Avatar
i agree completely
wish my max had closer gears sometimes
Old Oct 10, 2003 | 03:24 PM
mzmtg's Avatar
Minister of Silly Walks
The 1.8 is turbo charged with 170hp, stock. The 2.0 is NA and has 115hp.
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
