why are 99 ecus so different than the 95 ecus
Old Jan 20, 2005 | 05:51 PM
One Crazy Max's Avatar
i really want to know the answer to this question. why is it that there are uprgraded ECU's for 95-97 but there is none for the 99. what is the difference between the two. i along with many other 99 owners would like to know in detail the difference in the ecu's for the 99 vs. the 95-97 ecu.
info would be greatly appreciated for research. thank you.
Old Jan 20, 2005 | 06:05 PM
Ant96GLE's Avatar
Different emissions system. I know 97+ have a different rear 02. Even though they are in different places the 97+ have 4 wires instead of 3 on 95/96's
Old Jan 20, 2005 | 07:17 PM
emmas97's Avatar
yeah it is only 95-96 that are reprogrammable, and i know that some 99's have the cali-spec ecu's which are made specifically for, duh, california emissions.... thats about all i know at this time....
Old Jan 20, 2005 | 07:21 PM
eng92's Avatar
long answer - start around post #50
http://forums.maxima.org/showthread.php?t=348679
short answer - you can get your 99 to work with a 96 ecu if you do not mind modifying your wiring harness. I can send you a list of the terminals that need to be moved. You will have multiple codes to deal with after switching ecus. To my knowlege, no one has performed this mod.
JClaw
Nov 16, 2004 12:54 PM
jmrader
Oct 6, 2004 05:02 PM
studman
29
Dec 6, 2003 08:09 AM
Chebosto
Dec 12, 2000 08:51 AM
Chebosto
Oct 16, 2000 02:37 PM
