help quick..my car wont go into gear
Old 05-10-2005, 02:40 PM
rimrocka0834's Avatar
Ok so it all started with me taking out the levoc auto shifter so i can solder the overdrive wires. I think that accidentally somethin small accidentally fell into the setup. By setup i mean the long metal bar that is hollow and the skinnier metal bar with the white head on top that is inside the hollow bar. taht skinny metal bar is suppose to go up and down very easily but since i think that i accidentally dropped somethin in their its now stuck which means i cant get the car to shift gears or anythin like that. now i need to know how to take apart that hollow bar to see if there is anythin stuck inside. PLEASE HELP.
rimrocka0834 is offline
Old 05-10-2005, 03:24 PM
dot dot dot ...
NmexMAX's Avatar
This thread seems wrong on so many levels ... And no I won't
First off, ware you missing any thing taht could be stuck in there ... check the cable, hollow bar . err ehh you mean shifter?
NmexMAX is offline
Old 05-10-2005, 03:31 PM
well wat i think taht fell in there is a little allen screw that was used to tighten the levoc **** to the hollow bar. I really dont know wat to do. where does taht hollow bar go, wat does it connect it? Can i remove it to check out why the bar tahts inside of it is stuck?
Old 05-10-2005, 03:43 PM
dot dot dot ...
NmexMAX's Avatar
Pull apart the surrounding interior stuff and use a flashlight to see is preventing it from moving, that's what I would do before posting ...
NmexMAX is offline
Old 05-10-2005, 03:47 PM
everything is apart...the center console is off and the box tthat shows wat gear your in is off 2...i still cant see what the hollow bar goes 2 or whats inside of it
Lakersallday24
03-20-2024 11:22 AM
Lakersallday24
06-16-2019 01:35 AM
Quickgtp
04-13-2017 03:30 PM
SmokinMax02
18
09-11-2015 12:25 AM
MikesChevelle
08-10-2015 10:53 AM
Quick Reply: help quick..my car wont go into gear
