NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Car Still Stalling
My car is still stalling after getting it fixed twice. I just replaced my gas filter to see if that would help and it doesn't help. I have had my throttle body position sensor replaced, my intake pendulum, IACV, MAF EGR valve, EGR Guide Tube cleaned,and my EGR temperature sensor replaced. He said he check to make sure my IACV is working. I took to another gargage and he just said there is nothing he can do and I should wait until it happens more often, so I am now at the point where I just stop listening to mechanics and see if anyone else with this kind of car experience this behavior. I know my catalytic converter is going, but that should make it stall. Has anyone experience their car stalling randomly when they idle or at the stop light? I have a 1996 Infiniti I30
I had that problem a year ago in my 97 maxima. turned out to be 1 ignition coil. i already knew which one it was .replaced it and the car ran perfect.
Is there a year that was best or that I should stay away from? I'm looking for a 98 or 99 but want to know if the older ones are any better/worse. I'm asking as a whole considering all aftermarket options for the motor and whatnot. I know on the G20 P11's, the 99 was the best cause of the computer. Same kinda thing here.
Z
Z
Replaced mine not too long ago. Use a vise-grip to hold the nut. Use lots of wd-40. Try clamping the nut onto that metal bracket that goes around it. You have to get it pretty tight, there's lots of torque on that bolt. Just be careful unless you plan on replacing the bolt too. Good luck.
Could? Yes.
Why not just get the correct motor? You'd have to swap over both the upper and lower intake manifolds, at least the rear valve cover (both is best), swap over the EGR system and most other emissions components, the coolant log, etc.
Hi, When ever I have something wrong with my car I always find answers on here. Thank you all so much for the help you’ve already given me. My new problem is a good one. Please Help, No car for almost a week. I have a 1997 Maxima automatic with 150k. Monday I drove to work no problems. That night I when I turn the key the car sounds like it's going to start but it didn't. I tried it many times; there is about 3/4 tank of gas. We tried to jump it but didn't work, the battery is 1 year old. I have had no problems with the car, no warning signs, all of a sudden it won't start. Sometimes when i turn the car on (start it) there is something lose by the ignition where I have to wiggle the key to get the radio & wipes to turn on. Oh, and the check engine light is on but it's been on for two years. I finally checked the codes manually by counting the check engine light. I counted them about 7 times each. Two codes came up undefined and told me to check them again so i counted each 3 more times and all the numbers were the same. I got 4 total codes searched the net for all the codes and found them on maxima.org. 0704 = P0450, 0215 = p1446, 0514 = p1402, 0304=P0325 I’m thinking the EVAP sensor code is going off because i opened the gas cap and heard the pressure release. Part of me thinks these may not be good codes anyways because the lights been on for over two years. The Car has always run like a champ, there were no warning signs with this problem. Just won't start.
this is a list of what we tried tonight on the car.
1. I put in a new air filter, just because the old one was dirty.
2. Checked the oil then changed it and replaced the filter. it was pretty much empty. After I drained it there was about 1.5 qts that came from the engine. I knew it was overdue but I’ve never seen it like that. Possibly a slow leak.
3. Pulled the hose from the top of the fuel filter to see if it was dry. There was plenty of gas in there and in the filter. I let the fuel drain from the top hose then i hooked it back up. tried to start the car and it didn't start. then i took the hose off from the top of the fuel filter again. it was full. i then sprayed starter fluid down the tube tried to start the car, it didn't start. I'm pretty sure the fuel pump is working because when i tried to start the car with the hose off gas came spilling out of the filter.
4. Next i tried to see if I was getting a spark from the coils. To do this I unhooked one coil stuck a screw driver down the coil and held it next to bare metal while I tried to start the car. I got NO spark, so I tried a different coil, Again NO spark. I have ONE ignition coil that I replace 1 year ago so I knew I had at least 1 good one. I pulled that one off and got NO spark.
5. I pulled all the old spark plugs and put in new NGK plugs. When i pulled the plugs they didn't look good, one caught my attention and for some reason i smelled it. there was a odd smell to it. i wouldn't say 'burnt' smell but something similar (if that makes since) Reconnected all the coils, tried to start the car and ... it didn't start.
6. took out one of the new plugs put it in the end of the newest coil and tried to see if i could see a spark from the plug. NO Spark. (Now I'm thinking we are checking for a spark the wrong way)
7. started checking fuses. got 1/2 way done and packed it up for the night.
OH, let's cover all the bases. The car at one point was stolen from a previous owner. the steering column was broken. when i put my key in the ignition and turn the car on (start it) there is something lose by the ignition where i have to wiggle the key to get the radio & wipers to turn on. and there is an alarm on the car. my brother has asked me if maybe there is some kind of kill safe on the alarm that could be making it do this. i dont think so because i can turn the car on listen to the radio, turn the lights on, windows, trunk, everything BUT start it. Like I said it turns over and sounds like it’s going to start.
Thanks in advance for your help!
So this mourning, was about to stall, so I parked and it didn't stall but it was barely idling, like between 450 and 250 rpms. So I popped my hood and disconnected my MAF and it start idling normal except it was around 900 rpm, but it was steady and didn't shut off. So is it safe to say that I need a new MAF sensor?
just put a ws SS y, magnaflow hi flow cat, and pacesetter monza cat back into my 96. all i can say is the thing is beast. definitely feel gains in power and the sound is great, a low deep growl. ill have to start keeping track of mpg
Newbie here so I guess I will just try posting here first. I just recently picked up a 97 GLE with 93k on it. I have just finished changing all the struts on it and will be replacing the tires on it soon as well. I do have a few questions and would like everyones opinion. I am thinking of doing Kumho Ecsta asx or lx platinum tires and wondering if anyone else has used them before. Keep in mind this is just a daily driver and will always be 100% stock as it is for my wife and kid. Also what grade of fuel do you guys use? The previous owner always used premo and full synthetic oil. I do see that it does say premium is recommended but does the pcm retard the timing if I just run regular or am I going to get knock? Is there a colder range spark plug I can run to help with that or what is the best plugs for these cars?
Another issue that I believe is fairly minor at this point is that from time to time it will have a longer than normal crank before starting. It always starts and doesnt miss or run rough anything but I was wondering if that is a common problem and if there is a simple repair. I will start simple and just clean the throttle body and decarb it. I know the newer models are notorious for those crank sensors as well.
Another minor annoyance is the clock display. It does not hold time and will intermitedly fade in and out and flicker. Im guessing its just a bad display but was wondering if there is a common fix for a poor ground or bad connection ect..
Also what is the best weight oil to run in the 3.0 engine?
1997 Maxima Radiator Fans Question
Hello Group!
First, what a fantastic site. I am so happy to have found it. I recently purchased a used 1997 Maxima (3.0) with 135K on it. I love everything about it so far and am in the process of buying a repair manual for it (Haynes?) so I am can become self-sufficient with it.
Second, my apologies if I am not posting my first question correctly. I am quite the computer newb as well as new to the site.
And third, my question: Am I correct that the two radiator fans only come on when a certain temperature is reached or have I been given bad information from the previous owner?
Thanks to any and all that have a second to share their wisdom. I appreciate it and sorry if I am not following protocol.
Regards,
Mike in San Diego
Regards,
Mike in San Diego
Hello Group!
Regards,
Mike in San Diego
Regards,
Mike in San Diego
Haynes is a pretty good repair manual. If you want a more comprehensive repair manual, get the FSM (factory service manual) for free (downloadable) or purchase from your local Nissan dealer.
Yes, both rad fans kick on at the same time once the specified temperature is hit.
I have a '95 Maxima that won't start. I already went through the threads and tried several things. A few months ago it wouldnt start and I replaced the ignition switch and it worked. Now it wont start again. I have tried replacing the switch again (from autozone-lifetime warranty) but it didn't work. I had the starter tested and it tested fine. The starter wont engage when I turn the key. All I hear is one loud "click" when I turn the key. Battery is good. Jumpstart had no effect. Is there a relay or fuse in line that would cause this problem? Any ideas would help.
Still sounds like the starter solenoid considering you've swapped the ignition switch. I'd take the whole starter out and get a few free tests done on it at various Autozones, PepBoys, Kragen etc. They've been known to mis-diagnose these things.
Z
Z
New Question: Stumped
Sitting at a stop light suddenly power steering started screeching. Fluid at low mark, topped off, noise still continued.
Auto-stethoscope used to pinpoint noise around pump body/pulley.
For testing pulled alternator belt.
Noise still there
Replaced with new power steering pump and serpentine belts.
Exact same noise continues......
Replaced Autozone pump with a pump purchased from salvage yard.
Tried 2 separate pulleys; ran salvage pump with no lines attached.
Put Autozone pump back on, took to Nissan
dealership for diagnosis.
Service dept. pulled harmonic balancer and determined no problem (incorrectly?)
Service dept. concluded it was the power steering pump
Replaced with second new pump from Autozone
Exact noise continues - no change in pitch etc..
Quick test, no belts no noise...
Replaced high pressure valve.
What next? Any ideas help appreciated
Video/audio of maxima problem in link below
http://www.youtube.com/watch?v=_D7dERsoEpI
Noise still there
dealership for diagnosis.Service dept. pulled harmonic balancer and determined no problem (incorrectly?)
This was an alignment issue. Apparently exacerbated by Grubbs nissan, perhaps intentionally, pressing the crankshaft pulley on a little further than specs. What caused this is perplexing and my best guess is a shifting of the adjusting bracket. Shimming, quite a bit, has solved the problem.
Nissan diagnosis was not correct, it was not the pump(s)
I hope this helps someone from installing pumps needlessly; as I have done.
Oh, and thanks for 'all' the help
Welcome to the site Mike.
where can we get one of these free factory service manuals from on pdf?
I have a 98
Hardwiring a neon light to my 12v system?
My uncle gave me two street glow neon light strobes that he never used. I would like to put in my 98 Maxima under the dash. It says I can plug it into my cig lighter or hardwire it my 12v system. Does anyone have any experience with this?
I know obviously one wire will be grounded. but where to do I stick theo ther wire?
Throttle Stop Screw gap not set right
The Basic Info: I bought a 1999 SE 5 spd (cali spec) with 110000 miles three weeks ago.
Mods according to previous owner:
Injen intake
Custom exhaust
D2 Coilovers
Warpspeed Y pipe
B & M Short Shift Kit
Exedy clutch
Codes:
P0155 Oxygen Sensor Fault Bank 2 Sensor 1
Symptoms: A few days ago car would start, get to 1500 rpms for less than a second, then die immediately (even if I open the throttle). After two to three attempts of this it would just crank and not start at all. I am not worried about the oxygen sensor code because I read somewhere here that they should not affect startup.
The Catch: I was able to push start the car by popping the clutch. Ran it for 20 mins all through the rpm band, no misfire, no additional codes.
Attempted fixes:
Cleaned MAF, and TB, checked IAT, vacuum hoses,
as I continued troubleshooting when I checked the Throttle Position Sensor specifically the wide open/closed throttle switch portion, it did not pass the test according to Haynes Manuel (there was always no continuity regardless of throttle position.)
The Problem:I ordered a new TPS and when I came to the portion for adjusting the new TPS I found that there is a way bigger gap between the throttle lever and the throttle stop screw.
A .012 in. (.3mm) is supposed to indicate continuity at the CTPS
A .016 in. (.4mm) is supposed to indicate no continuity at the CTPS
My Gap is aprox .047 in. (1.2mm) way too big for the listed adjustment values.
The Question: Is there any way to change this gap between the throttle stop screw and the throttle lever besides adjusting the throttle stop screw (something I have read you are not supposed to do because it is set at the factory?)
I read somewhere that the throttle stop screw sometimes is adjusted after the install of an after-market clutch (aka the exedy) has anyone heard of this?
Why else would the previous owner adjust the throttle stop screw?
Would it be ok for me to adjust back to the values listed in the Haynes manual and is there anything I will need to change if I do this?
Despite this out of spec gap the idle was within spec 1400 -1500 rpm when cold 800-900 when at operating temperature.
I did search before posting and only found this link which seems to confirm the information in my Haynes manual.
http://www.lyberty.com/car/Maxima_A3...NTB99-053b.pdf
Here are some images I took of the gap with the larger feeler gap in the space (so you can see the extra clearance):
Let me know if I should include any other info and thanks in advance for any help/insight.
Injen intake
Custom exhaust
D2 Coilovers
Warpspeed Y pipe
Exedy clutch
Codes:
Attempted fixes:
Looking at the 2nd picture you posted it appears the coolant hose is attached to the TB? If there's a gap between the throttle plate and throttle stop screw on a warm engine then you'll have to adjust that screw. I adjusted mine and she's now idling fine. Read over post 2 of this thread for instructions on 'Adjusting the Default Idle Speed':
http://forums.maxima.org/4th-generat...gas-start.html
Getting the TP switch to read continuity with 0.012" inserted and to not read continuity with 0.016" inserted is all you need to focus on when setting the TP switch.
Again thanks for the help I guess I will keep on troubleshooting my engine cranking but not starting problem (apparently a common problem as I keep reading through the forums) and I will post back with updates.
That hose is the coupler for an injen CAI (from autozone guess the old one wore out with the previous owner). I read your linked thread the problem is I can not get the engine to start in order to get it to operating temperature, although by reading through it looks like a faulty TPS would not keep the car from starting... however what you are saying is that it is ok for me to adjust the throttle stop screw to the correct gap? That is once I can get the car started again and follow the instructions outlined in that link...
Unless you bypass the FITV/FIC (Fast Idle ThermoValve/Fast Idle Cam) you'll always have a larger gap between the plate and screw on a cold engine.
If not. hold the two outside buttons for around 20 seconds or so. Then hold the one you want to program while pressing the remote button till the light blinks rapidly. If it a rolling code there's a bit more I'd have to look up.
Have a huge problem. I sprayed out my engine bay today and now there is a problem. It worked fine at first, but now on start up the engine revs fine but after about 10 seconds it will not. If given gas it will not rev past 1500 rpm. Its almost like a maf but i have checked and it looks fine. Plaese help!
The car is a 2002. Electric throtle body maybe. Have the car with no nevative terminal on for now drying in the sun.
