NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Oct 15, 2008 | 04:40 PM
  #2121
Nismozx720's Avatar
What's up with this 2.0?
http://www.jcwhitney.com/TURBO-SPECI...0935_10114.jcw
Old Oct 16, 2008 | 04:33 AM
  #2122
allensteiner21's Avatar
Originally Posted by Nismozx720
not much, european market engine and maybe japanese (?). there's a vq25 for sale on ebay. the kit will fit a vq30 if it's really made for the vq20.
Old Oct 16, 2008 | 12:31 PM
  #2123
Coolsaber57's Avatar
Noobie question:
Can I use a 97-99 catback on my 96? Would there be any modification I'd have to do?
Old Oct 16, 2008 | 12:37 PM
  #2124
Originally Posted by Coolsaber57
Noobie question:
Yes you can. However, keep in mind that the rear bumper cover is slightly different from 95-96 to 97-99. Therefore, the tip of the muffler will either stick out more than normal, or be recessed in. (Sorry, can remember which) Hopefully someone will chime in and clarify.
Old Oct 16, 2008 | 12:38 PM
  #2125
ROCKART's Avatar
wants an I35
the 96 is shorter than the 97-98, so it will stick out more than your stock setup.
  #2126
Thanks man. I read that 97 b-pipes will be shorter since they have the s-pipe.
However, if it's aftermarket, they just make the b-pipe the same length as the 95-96 correct? To get rid of the s-pipe?
Old Oct 16, 2008 | 01:04 PM
  #2127
maxud's Avatar
I just replaced catbacks on my 95 max and dad's 97 max.
I bought replacement Walker b-pipes for both, and 97 b-pipe was shorter and did not include the short piece of pipe (you called it s-pipe). It is the little piece right after the catalitic converter that had the rear oxy sensor in it.
So, I guess it all depends on the manufacturer of the aftermarket pipe. Walker replacements were direct copies of Nissan parts.
good luck,
Max
p.s. why not just order the part for your car year?
Old Oct 16, 2008 | 01:06 PM
  #2128
good luck,
Max
Because I could get a good deal on the 97 aftermarket. Just curious, are the stock inlet/outlet sizes 2.5"?
Edit: it seems like they are 2.25" can anyone confirm?
Old Oct 16, 2008 | 02:03 PM
  #2129
Thanks for the clarification.
2.25" is OEM. Since it's an odd size, most AM companies go with the more common size of 2.5". All bolts up together just fine with no leaks.
Old Oct 16, 2008 | 02:05 PM
  #2130
B_Eaze's Avatar
Wizard is the Sensei of this thread. you are the like the shinning light of hope for noobs
Old Oct 16, 2008 | 03:49 PM
  #2131
haha, yeah, but you missed the part where ROCKART told HIM whether it will stick out or not.
Thanks guys, I appreciate the help, it made my decision easier.
Old Oct 16, 2008 | 03:54 PM
  #2132
lol. I'm just filling in for NmexMAX and the the other gurus.
Old Oct 17, 2008 | 09:55 PM
  #2133
whiteSE's Avatar
hey guys. i got a problem...im scared lol....anyways, i got a 4th gen Maxima SE 5 spd...driving today, i was pulling to a red light, stopped, green light, my car doesnt go into first gear....weird, but ok, i start from 2nd. try 3rd, doesnt work. and neithr does 5th...so 2,4,R work and 1,3,5 dont.....and ideas?
car has 108k on it. clutch and tranny fluid replcaed 5k ago
Old Oct 18, 2008 | 10:29 AM
  #2134
HallD's Avatar
I'm looking to see if there is any benefit to clearing the computer on the car now that I changed the sparkplugs.
I think the plugs were the originals in the car and I replaced these with coppers.
Thanks ahead of time.
Old Oct 18, 2008 | 10:58 AM
  #2135
B_Eaze's Avatar
No need to reset ECU for spark plugs as long as you don't have a Check Engine Light on, then you probably have some other issue
Old Oct 18, 2008 | 11:52 AM
  #2136
B_Eaze's Avatar
anyone have a 5spd write up. The link to vqpower isn't working int the how to's
Old Oct 18, 2008 | 11:57 AM
  #2137
ALEXAZ.'s Avatar
I JUST GOT MY 95 MAX ON THE RD. AFTER TWO YR'S. IT'S BEEN TWO WEEK'S NOW, THE ALARM KEEP GOING OFF. I HAVE NO REMOTE. WHAT SHOULD I DO?
Old Oct 18, 2008 | 12:27 PM
  #2138
B_Eaze's Avatar
it goes off when? is it the factory alarm? more info needed
Old Oct 18, 2008 | 12:33 PM
  #2139
ALEXAZ.'s Avatar
HAVE ALARM , BUT NO REMOTE.
95 MAX FACTORY ALARM , IT GO OFF TWO OR THREE TIME A WEEK . I DONT WANT AFTER MARKIT. TRING TOO KEEP IT ORIGINAL....
Old Oct 18, 2008 | 12:38 PM
  #2140
B_Eaze's Avatar
i shoulda been more clear. when exactly does it go off? when your driving? when u try to open it? or just randomly?
Old Oct 18, 2008 | 12:52 PM
  #2141
ALEXAZ.'s Avatar
95 MAX REMOTE FOR FACTORY ALARM. ALARM GO OFF AT THE WRONG OR WORST TIME. WON'T START HOT IN AZ.
Old Oct 18, 2008 | 12:58 PM
  #2142
ALEXAZ.'s Avatar
WHEN MY WIFE GO TO GIT IN AFTER I HAVE UNLOCK WITH KEY, YES IT, S FACTORY.
Old Oct 18, 2008 | 06:14 PM
  #2143
internetautomar's Avatar
mod or sell?
sounds like a rod isn't engaging.
Old Oct 18, 2008 | 06:16 PM
  #2144
mod or sell?
have you tried to disarm it from the passenger door?
once you have it disarmed, pull the fuse and viola' no more nuisance alarm.
Also, please:
a. learn to speak proper english so we can actually understand you, not everyone speaks ghetto.
b. don't type in capitals, it is considered yelling.
Old Oct 18, 2008 | 08:01 PM
  #2145
Eshelon's Avatar
Originally Posted by allensteiner21
i've read somewhere that if the timing chain skips a tooth or more that messes the ecu up and will cause spark problems. i haven't looked into that too much though. make sure that those 2 cylinders have a spark - pull the sparks out and leave plugged into the coil, then star the car and see if they spark - if they don't then i guess it would be a possible timing chain issue. when people replace the tc tensioner the chain will sometimes skip.
Just wanted to say a quick thank you here Allensteiner. Just finished re-setting the timing. Runs like a dream now. Thanks.
And if anyone in the future runs into a problem with coils 2 & 3 not sparking, check your timing... Brilliant!
Old Oct 18, 2008 | 08:05 PM
  #2146
etuero's Avatar
I have now had my 09 Maxima for about 2 months, great car and very good all around. Lately I purchased a new Nano iPod and connected it with the Nissan Supplied cable, apparently the new version of the iPod is not supported by Nissan and therefore the iPod will not recharge while connected. Has anyone found a different cable that will charge the iPod? worse comes to worse I suppose I can go back to the old iPod but would rather not.
Thank you for your help
Erick
new member
Old Oct 18, 2008 | 08:14 PM
  #2147
B_Eaze's Avatar
Erick
new member
This section is for maximas from years 1995 - 1999. you'll probably getta a better and quicker answer from the 7th gen section
Old Oct 18, 2008 | 10:07 PM
  #2148
glad i could help.
Old Oct 18, 2008 | 11:11 PM
  #2149
whiteSE's Avatar
so thats a rebiult?
Old Oct 19, 2008 | 06:58 AM
  #2150
mod or sell?
so thats a rebiult?
depends on if the rod came loose internally or externally.
Old Oct 19, 2008 | 11:26 AM
  #2151
J RO 9's Avatar
where can i get a oil pan for my 97 maxima?
at my last oil change, i was told that it has a bad dent, not leaking tho.
i want to get that replaced before my next oil change in 500 miles or so.
Old Oct 19, 2008 | 11:46 AM
  #2152
HallD's Avatar
Look on the for sale side of the forums to find someone parting out their car.
http://forums.maxima.org/4th-generat...-1995-1999-43/
The other option might be a "u-pull-it" yard.
Old Oct 19, 2008 | 06:51 PM
  #2153
whiteSE's Avatar
we looked at it and its inside the tranny. so i guess that is a rebuild
Old Oct 20, 2008 | 05:19 PM
  #2154
opmogollon's Avatar
97 won't start
ok so she was working fine all day. I made a stop and when i went to start her up she fires but won't start and I just get this sound like its not getting gas. autozone told me to change the spark plugs, no good. when I give her gas she justs smokes from the tailpipe. Fuel Injectors? i also have a bad egr valve that I haven't replaced yet could that be the problem?
Old Oct 20, 2008 | 06:14 PM
  #2155
shudson's Avatar
Why is cylinder 1 dead, but ecu throws 0606 - Cylinder 3 misfire?
why? WHY?
Old Oct 21, 2008 | 12:03 PM
  #2156
Could be lots of things. Starter, battery, bad fuel pump etc.
What? The spark plugs were no good? What kind of spark plugs did you put in? Or no good as you couldn't change them?
So now the car is started and running???(rhetorical q) Before you said it wouldn't start?? What color is the smoke??
Nope, that won't cause any of the symptoms you've described to my knowledge.
Old Oct 21, 2008 | 12:04 PM
  #2157
Originally Posted by shudson
why? WHY?
How do you know cylinder 1 is dead?
What year max do you have?
Old Oct 21, 2008 | 02:26 PM
  #2158
opmogollon's Avatar
The battery is fine, the starter I haven't checked yet. I meant that when I changed the spark plugs that didn't fix the problem. It never actually started. As I tried to start the car after changing the plugs I gave her gas and she started smoking but never really started, just kinda "whirred". when I tried to describe the problem to the people at autozone they stood there looking like a box of rocks, so I have no idea whats going on. A mechanic I know told me to clean the fuel injectors but didn't sound too sure.
Old Oct 21, 2008 | 02:38 PM
  #2159
ok. let me think about this.......
Do you have a 99 Max by chance??? If so, the dreaded immobilizer problem got you.
EDIT: nevermind. I see you have a 97.
Old Oct 21, 2008 | 02:57 PM
  #2160
opmogollon's Avatar
No it's definitely a 97. i even checked the vin after I read the immobilizer horror story.
