Suspension. replacement or modified?
Old Oct 10, 2001 | 10:34 AM
MacGyver's Avatar
I've got a 97 se with 120k miles. Basicly I need new struts. My question is should i just replace it with stock or aftermarket struts? The shocks determine the front end roll to an extent, right? I have a FSTB, but how big of a difference would aftermarket performace struts be compaired to new stock struts? Also what are some rough prices? thanks
Old Oct 10, 2001 | 10:37 AM
MacGyver's Avatar
Re: Suspension. replacement or modified?
i messed up on something...the STRUTS detrmine the front end roll...taking turns etc., right? The shocks are the comfort...the bounce.. do i have it correct?
Old Oct 10, 2001 | 10:58 AM
mzmtg's Avatar
Minister of Silly Walks
Not quite...
Maxs dont have shocks in the front, they have struts. Anyway, the main difference you'll feel with stiffer struts will be harder bumps and the steering response will be quicker. The springs control how much the body rolls in a turn, but the struts control how quickly it rolls.
OEM struts are very expensive compared to aftermarket. If you plan on keeping the OEM springs, then Tokicos or KYB GR-2's are recommended.
shox.com can give you a quote.
Old Oct 10, 2001 | 11:43 AM
Eric L.'s Avatar
Shocks and struts basically perform the same function...they dampen out the motions of the spring. The spring stiffness, suspension geometry, structural stiffness, and antiroll bars determine cornering stability (i.e. body roll).
Ride quality is a combination of suspension geometry, spring rate, and strut/shock dampening force. In a well designed car, you can engineer a suspension which delivers a smooth ride and good handling. Like BMWs. They ride well, but are also very responsive. The Maxima, on the other hand, is a compromise...we start with a smooth ride but if you want handling, you need to opt for a stiffer combo which will jarr your kidneys over the bumps.
PH98I30
29
Feb 10, 2025 12:03 PM
cruce91
Sep 20, 2015 10:23 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
