Best aftermarket struts front and rear
Old May 8, 2017 | 12:03 PM
Maxie40's Avatar
Max40
It has been 10 years since I last replaced all four of my strut assemblies. I used Nissan OEM back then made for the 1995 SE. I did not want my Maxima to float high and they looked good and worked great for 10 years. I was looking at Monroes, would anyone on the forum have better recommendations?
Old May 8, 2017 | 01:46 PM
KP11520's Avatar
NOT Monroe would be my first suggestion!
IMO, there are no easy complete assembly options worth considering.
Rebuilding OEM assemblies, reusing the few parts that are still good (Springs usually and maybe a few other hard parts with no rubber to degrade) based on taking them apart and inspecting and replacing the struts and "consumable" parts with OEM only. Struts don't necessarily need to be OEM, but use something decent.
There's a discipline to getting these right for years of a quiet and comfortable ride. IME, quick fixes don't go the distance, especially on the quiet side.
You'll need to rent a spring compressor and torque wrench if you don't have them, along with the rest of the wrenches and sockets required.
Old May 8, 2017 | 02:55 PM
maximaxi's Avatar
Monroe's quick struts are a good choice. They are complete assemblies that come with all the required components. You get a new strut, spring, strut mount, and all the rubber things. You do not need a spring compressor.
Gabriel also makes quick struts for these cars.
But DO NOT get the cheap Chinese struts! They are horrible.
Old May 8, 2017 | 03:17 PM
flynlr's Avatar
I bought 4 Monroe Quick struts in 2009 for my 95 replacing the oem items at that time.
they have been flawless since then
Old May 8, 2017 | 09:53 PM
max ride 41's Avatar
get some coils, drop it like its hot!
Old May 14, 2017 | 07:46 PM
Hutch's Avatar
I have never replaced my struts on my 99 GLE. I am considering it seriously now. It is a hard ride and always has been. but now I have different rims and tires that need a little more room as they bottom out over rough roads. Is there a difference between the SLE and GLE struts? Any suggestions thanks
Old May 16, 2017 | 05:00 PM
maximaxi's Avatar
The difference between SE and GLE is much, much less than the difference between old worn struts and brand new ones. Quick struts make it much easier and they include everything you need
Old May 16, 2017 | 06:27 PM
surban1's Avatar
I went with kyb's and they have been good to me; get all new associated hardware and you won't be unhappy.
Old May 17, 2017 | 05:28 PM
I<3 A32's's Avatar
kyb agx are goood!!
Old May 17, 2017 | 07:33 PM
sanford7575's Avatar
I have to recommend Monroe quick struts, but not the economatic! Make sure to get the ones based off of the OEM Spectrum line. I've used a set of 4 on two Maximas and an I30 and they perform well. Ride is a little softer than OEM, but they provide good comfort without noise of chinese crap.
Old Jul 1, 2018 | 12:16 PM
Maxie40's Avatar
Max40
I finally replaced my front struts with KYB assembly. Rode high for a couple of weeks and now it settled down. Rides close to my OEM for my SE, need to replace the rears in about 6 months.
Trying to keep the rubber bellows on the struts from breaking in the future. If I spray with silicone, would that work?
Old Jul 1, 2018 | 08:08 PM
JvG's Avatar
JvG
How much did you pay for those, and which company did you buy them from? Did you shop around for the best price?
Old Jul 1, 2018 | 08:17 PM
Maxima 97 SE's Avatar
Tokico blue are the best and they are the oem struts for our 4th gen maxima's. Nissan used Tokico struts on the 4th gen maxima. I got one original oem nissan front strut that was 323.00 from nissan for $69.00 on ebay which is made by tokico. Then i bought a tokico blue strut for $49.00 which is the exact same as my oem nissan strut and bought two rear tokico blue struts for $163.00. All made in japan and oem nissan manufacture. Heres the link below to the listings. I installed the struts last month in May and the car rides like new again and it has the exact oem ride for an SE model. If your buying struts buy only Tokico as I even read reviews online that there much stiffer and stronger and has more stable ride than others. Also cause there the oem manufactures for Nissan.
https://www.ebay.com/itm/NOS-OEM-Nis...72.m2749.l2649
https://www.ebay.com/itm/Tokico-HP-b...72.m2749.l2649
https://www.ebay.com/itm/Tokico-HB31...72.m2749.l2649
Old Jul 1, 2018 | 11:39 PM
CS_AR's Avatar
Koni Orange STR.T if you are looking for a performance oriented strut that also supports lowering springs. I'm running Orange on both 4th gens.
Note: It's all of the other strut related parts that drive up the cost of a replacement job and make the difference in the end.
Old Jul 22, 2018 | 04:47 PM
caseymaxima's Avatar
I purchased FCS strut/spring assemblies on Rockauto for my 1996. I wanted to go as cheap as possible since my car is in very sad shape. I have had no issues in roughly 10,000 miles. I can't complain for the price.
Old Jul 22, 2018 | 08:25 PM
CMax03's Avatar
Best to replace, bellows, bumpstops, and strut mounts when replacing strut assys.
Old Jul 23, 2018 | 07:23 PM
CS_AR's Avatar
Here you go with those thick OEM SE "Top Hats" .
Old Jul 23, 2018 | 09:35 PM
KP11520's Avatar
Twin strut assemblies form different...... Mothers? LOL
Attached Thumbnails Best aftermarket struts front and rear-resized_20170718_212246_001.jpeg   Best aftermarket struts front and rear-resized_20170718_212328.jpeg
Old Jul 24, 2018 | 02:14 PM
RA030726's Avatar
I'm nutty for Nissans
I'm partial to Koni Sport, aka yellows. Not much to see when assembled.
Old Jul 24, 2018 | 02:47 PM
sb001's Avatar
I needed all new suspension parts for my 99 Maxima when I bought it. Along with front end tie rods, control arms, sway bar links, etc....I bought a set of the cheapo FCS off RockAuto for the rear struts and went with the Monroe QuickStruts for the front (figured that would be a little more important.)
The bottom line is, it rides just fine, BUT the handling around corners leaves a bit to be desired (fairly significant body roll.) I had the same problem with a 2001 Honda Accord I bought new, and solved the problem on it with an upper strut tower brace, so I'm wondering if the same thing here would do the trick. Problem is I've looked around a bit and can't really find any made for the 4th gen Maxima. The only one I can find is this:
https://www.ebay.com/itm/Ultra-Racin...LH_TitleDesc=0
Jim298
Aug 9, 2018 07:50 AM
hooloovoo
Jun 16, 2018 03:57 PM
the_tags
Dec 12, 2015 07:39 AM
user-90
May 31, 2012 05:57 PM
Dominicanaso
Aug 12, 2011 10:01 PM
