Tweaks
Old Mar 27, 2002 | 08:33 AM
pm0riarty's Avatar
Tweaks
Ok, on my 95 Maxima SE, fully loaded, stock except for Michelin Pilot Zero tires.
I'm wondering if there are any smalls tweaks I can do to get better acceleration out of my car. Any recommendations would be much appreciated. Thanks.
Old Mar 27, 2002 | 09:02 AM
SuDZ's Avatar
Re: Tweaks
You mean like mods? Like air filters things like that? If so there are cone filters,hybrids,CAI. Those will give you anywhere from 3-12 HP which will help you out.
SuDZ
Old Mar 27, 2002 | 09:17 AM
pm0riarty's Avatar
Re: Re: Tweaks
SuDZ
No....I have almost 100k miles on the car, and I'm wondering more if there is stuff I should clean out to make it run smoother and faster. I have noticed that starting it when cold, it makes a loud buzzing noise. I think there is something that needs to be cleaned, because I don't think it's getting the power that it should. I.E., I'm losing to cars that I should be beating, with even a stock maxima.
Thanks again.
Old Mar 27, 2002 | 09:20 AM
SuDZ's Avatar
Re: Re: Re: Tweaks
Thanks again.
What kind of tunups if any have you given your car? Fuel filter, Spark Plugs, clean the throttle body, oil filter/change, pcv valve, throttle cable check? Any of this lately? What grade gas are you using?
SuDZ
Old Mar 27, 2002 | 09:27 AM
pm0riarty's Avatar
Re: Re: Re: Re: Tweaks
SuDZ
I just bought the car about a month ago. The guy said it was tuned up at 70k miles, and he had platinum spark plugs put in. Is it due for a tuneup again? I have no clue what exactly he had done. I started using regular gas, but I moved up to premium now, for the last few fill ups.
Old Mar 27, 2002 | 09:46 AM
pocketrocket's Avatar
Re: Re: Re: Tweaks
Are you talking about cold weather or cold engine? Also, how long is this sound?
I am wondering if it's the starter motor sound you're talking about. It happens in cold weather, after you release the key, the starter motor whines for another 1/2 second. If yes, www.motorvate.ca has a good write-up on fixing it.
That should not affect your power though, just your engine starting ability (or lack of when it finally quits on you).
As for the tune-up at 70k, do you have any service records to show what was done? A tune-up means a lot of different things to a lot of different people
Old Mar 27, 2002 | 09:54 AM
pm0riarty's Avatar
Great link, that sounds exactly like the problem.
Old Mar 27, 2002 | 10:45 AM
kvzeyde's Avatar
try throttle body cleaning
Many people don't include a throttle body cleaning as part of a tune up. With as many miles as you have, the time checking and cleaning the throttle body would be time well spent. I bought my Max used and have come to believe you can't take a previous owner at their word. Do a search for "throttle body cleaning" and you will find many discussions and instructions.
hot04
Sep 18, 2015 06:14 AM
Turbo95Max
Nov 22, 2002 10:54 PM
CJLax
Sep 25, 2002 03:17 PM
MAXXspeed18
Aug 18, 2002 09:25 AM
Horsepower
Mar 3, 2002 07:07 PM
