How Much Nos Is Enough
Old May 27, 2002 | 04:58 PM
SLC I30t's Avatar
Ok how much can I run on a dry set up with out having to replace vital parts with biger parts? Meaning can I run a 50-75 shot on a stock B pipe? I know if I go higher than 75 it is recommended to use a larger fuel pump for pressure concearns.
ALSO is it safe to run these with out the JWT board? It's just a window switch right? Those can be bought seperate if I'm not misunderstood.
Old May 27, 2002 | 05:19 PM
mtrai760's Avatar
'Trynna' is not a word
You can run a 50 shot pretty much stock, but i would recommend at LEAST a fuel pressure guage. You don't need the JWT board, but you should get one step colder plugs, and a window switch. The MSD one cost about $105 after modifying it to work on our cars. You can run with the stock B-pipe, but you'll make more power with a larger exhaust.
Cumalot
Nov 28, 2000 09:38 AM
Cumalot
Nov 26, 2000 04:30 PM
ereet
Nov 26, 2000 03:44 PM
Slickismax
Nov 5, 2000 08:51 PM
MardiGrasMax
Oct 27, 2000 12:40 PM
