K&N question....
Old Dec 9, 2000 | 11:34 PM
CLIMAX
Is the K&N filter a replacement for the stock filter and does a create a difference??
Old Dec 9, 2000 | 11:46 PM
MaximaZero's Avatar
Needs non-Maxima Friends
there is a k&n filter that just drops into your stock air box, and there is a k&n that comes on the stillen intake. the drop in has almost no performace gain (none on the butt dyno) and isnt much louder than stock. the stillen on the other hand should add a few hp and will definitely be louder.
Old Dec 10, 2000 | 12:11 AM
MrBurner's Avatar
the k&n drop in has been dyno'd by turbo magazine to add 4hp to the wheels which is roughly 6-8hp overall...i had an intake on my car (not stillen, it was custom) and it had problems w/ water which cost me $1000 to get it fixed and restored to stock...i have recently put the k&n drop in filter in (since i am done w/ intake after that $1k) and i have defenitely noticed a difference. you are able to notice quicker throttle response...the only problem is that it is not much louder than stock (at over 5000 rpm, it omits a sort of whiney tone and you can actually hear the air coming into your engine...in stock form, you couldn't hear this)
my friends have all also noticed the difference and they say it feels faster, too...4hp to the wheels for $50 is a really good deal...i'd go w/ the k&n drop in
Old Dec 10, 2000 | 01:23 AM
PIONEER's Avatar
I don't know how accurate that figure is. Turbo Mag drivers can't drive worth a damn. The Max SE they had 5spd couldn't break 15z 1/4mile times stock. 4hp at the wheel is a lot from a drop in filter when U consider U get about 3hp from the Stillen Piece and thats an intake. don't mean to start anything but I don't think the dropin filter makes 6-8 FWHP. I've seen Dynos on the Intake and its about 2hp with an intake so don't see how a dropin is making 6-8hp.
Old Dec 10, 2000 | 07:59 AM
2000MaxSE's Avatar
K & N drop in
I have to agree with Pioneer regarding only getting 3-4 HP from the stillen intake and that is only above 6000 rpm, so I don't know how a K&N drop in is going to net you 6-8 HP.
Old Dec 10, 2000 | 08:52 AM
y2kse's Avatar
Regarding the Stillen Intake . . .
Check out my question to Sprung.
The K&N Panel Filter does seem to yield a little better throttle reponse. There is some controversy as to how good a job it does at removing fine particulate matter, however. Guess it just depends on whose data you choose to accept.
[Edited by y2kse on 12-10-2000 at 12:16 PM]
Old Dec 10, 2000 | 09:48 AM
NYC2SD's Avatar
Regardless of how much horsepower you gain (which we all agree has to be at least 2HP), the filter lasts a hell of a lot longer, and is less than $50. The filter pays for itself (if it truly does live up to its standard of lasting 100,000 miles).
Old Dec 10, 2000 | 10:41 AM
The New CLIMAX's Avatar
I think Someone needs to change their name, ppl will start to get confused
on our names.
Old Dec 10, 2000 | 10:54 AM
98se's Avatar
i have heard that the drop in filters aren't much of an improovement...id maybe look at other options to increase your air flow!(not so much the filter brand)
Old Dec 10, 2000 | 01:37 PM
2000MaxSE's Avatar
K&N filter after cleaning
As someone said the K&N filters should last 100,000 miles but every time you clean the K&N filter the cotton has a tendency to develop small holes in the cotton fibers. So the more times you clean the filter the more holes that develop in the cotton. As a result the more dirt that can get through to your engine.
Old Dec 10, 2000 | 01:43 PM
Paul6speed's Avatar
I dyno'd +6 HP with my JWT intake. I think the drop-in filter would give more HP with a turbo, since it's requires much more air inflow. In the Maxima I would say the panel filter would give 2 HP tops.
Old Dec 10, 2000 | 02:00 PM
MrBurner's Avatar
in the turbo magazine article, they dyno'd the drop in filter when they only had an exhaust on the car...i realize that some mags may not have the best drivers (and i trust you that turbo is one of them)...they turbocharged the max and could only run 14.7 i think...did i mention it was also intercooled? for money you put down to get it turbo'd and intercooled and have it only run .2 secs better than someone on these boards and have it run .6 secs better than turbo's original time isn't worth it
alright, anyways, back on the subject...i believe that dyno's don't lie...i had an intake about 6 months ago, and after about 3 months of use, i started up my car one night, and the service light was on. i figured it was something minor and i would bring it to the dealership in the morning but once i started going around the block, my engine wouldn't go over 3k rpm...when it got upto 3k, it would make this sound (the sound the car makes when you forget to shift and it goes upto redline and can't go any farther and it just stays there for a couple seconds)...i brought it into the dealership and they said the intake had let water or dirt in and my mass air flow meter was busted...it wasn't even a CAI and it let water or dirt in...so basically it took them about 2 weeks and $1000 and they restored it to stock...i then decided that i would not deal with an intake again because i have friends who have had the same thing happen but worse (they blew their entire engine...and since the intake voids the warranty, that was $8k out of their pocket)...when i saw the turbo magazine article about the k&n drop in filter, i immediately bought it and put it in...i could feel the difference much more (i never really felt a difference w/ the intake but i hadn't had the car for too long then...i'm pretty sure that was why)...w/ the filter, i took a test drive right after i installed it, and i loved it...there is a quicker throttle response and after 5k rpm, you can actually hear a whistling sound of wind coming into the engine...the one thing i liked about the intake (other than the fact it looked a lot better) was the fact that it gave me some really nice sounding noise above 3k rpm...
i'm not sure if anyone has seen my other post about an intake silencer, but my friend told me his friend took his intake silencer off of his mustang gt and it made it a lot louder...he looked at my engine and showed me my intake silencer...i'd love to take it off and get a much louder sound, but i don't want to run the risk of dirt or water getting into my engine again...has anyone ever heard of an intake silencer?
Old Dec 11, 2000 | 07:53 AM
silvermaxd's Avatar
I heard the Amsoil panel filter is alot better at removing particle's from the airstream. The part no. for the 2000 maxima's is TS74. I plan on getting one soon
kmcgill
Jan 27, 2015 06:02 PM
aguynamedpat
Nov 26, 2013 01:32 PM
ntjoe
Sep 22, 2004 07:45 AM
BeRTo175
Jul 28, 2004 12:23 PM
Ndo125
Jan 5, 2002 05:34 PM
